Question about Sony BRAVIA KDL-52W3000 52 in. LCD Television
When we turn on the tv, the left side of the screen has a double vision/temporary burning of multiple images on the screen. This lasts 15-30 minutes. We called Sony and were advised to contact a TV repair shop in our area (no extended warranty and the tv is now 3 years old) and after $280 they STILL have no clue what's wrong with our TV! From the look of the web sites we've come across in our search for a solution, this appears to be a common problem and these TV's should be recalled or repaired at Sony's expense. Has anyone had this problem successfully diagnosed and repaired?
  • justmelanee Dec 04, 2010
    Sony ADMITTED to us that they are fully aware of the problem; that's why they extended the original warranty. It's, apparently, according to their customer service department, unfortunate for us that our televisions didn't 'show symptoms' of the problem until after the warranties expired. We wrote to the local office AND to the corporate office in NYC; no response. We will NEVER, EVER purchase another Sony product EVER. These people are fully aware that they sold us a junk tv and could care less that it only lasted 3 years. We wouldn't have spent $2800 on a tv for only 3 years of use. We have gone to every website, including Amazon.com, that would allow us to 'review' the tv and slammed Sony by telling the truth about this defect that they refuse to fix. Unless you want to spend $3000 to repair your tv, it's actually cheaper to buy a new one.
    We will tell you that after being on for an hour or so, it WILL recover but even that will stop eventually. Sometimes if we let the tv warm up and press on the upper left corner of the frame it'll fix it too. The problem is the adhesive. It's terrible. Don't waste your money.
    We're looking for as many people as possible to complain about this so Sony's reputation will be what it deserves to be; they're a junk dealer.
    Good luck.
  • Ralph A Apr 29, 2013
    Yes I also Have the same problem. I am very disappointed because we saved all our vacation money and used it to buy this TV. Only lasted three years right after the warrenty was over this TV decided to start acting up. I will never purchase a Sony product again. SONY knew about this problem and should have discontinued this item.
  • 178 Answers
I think 80% is the panel, and other 20% maybe the t-con board or LVDS cable. rock the cable or cool down the t-con to test it.
Posted on Apr 27, 2010
Testimonial: "We had sent it out to a repair shop and was told that, after replacing the board, it WAS the panel..which is $3000 for the part and $300 for the labor"
  • Shukai Fung
    Shukai Fung Aug 10, 2010
    First you can see SonyStyle Extended Warranty information
    http://www.sonystyle.com/webapp/wcs/stor...
    hopefully it can solve your problem.
    The t-con board is not available at Sony, replace the whole panel includes the t-con cost approx $2300.
    If you buy a t-con board from other seller, be sure it match with your panel’s model, otherwise it will not work.
    The LVDS cable and the FB1 board could cause this problem too.
    FB1 board cost approx $280~380 (NEED THE SERIAL NUMBER OF THE UNIT FOR THE FB1 BOARD ASSY
    ***A-1362-638-A FOR SERIAL NUMBERS: ALL UNITS HAS SERIAL FROM 8000001 TO 8099999 and 8500001 TO 8599999 ONLY
    ***A-1419-002-A FOR SERIAL NUMBERS: ALL UNITS HAS SERIAL FROM 8100001 TO 8499999 and 8600001 AND UP ONLY).
    Parts reference: Andrews electronics, 800 289 0300.
Have the Same Problem with mine. It's 3 years old.
Posted on Aug 07, 2010
  • 6 more comments
  • justmelanee Aug 08, 2010
    Ours is 3 years old, as well. We let a tv repair company take it...they had it for 3 weeks, charged us almost $400 and then told us they had NO idea what it was. They changed the t-con board out and everything. We're thinking about having another company give it a shot. There was a man that posted that his started showing this problem while his was still under warranty and that he had sent the tv back to Sony and that he would post the results but never did. We found a lot of people *on the internet* complaining about the same problem with this particular tv...we can't believe that Sony hasn't figured out the problem and issued some kind of repair order. It stinks that our expensive tv is broken and no one can figure out how to fix it...and it happened RIGHT out of warranty! If we can get ours fixed for less than 1/2 the cost of a new one, we will post the repair results..if not, we'll let it blow up and buy another...but I can promise you it WILL NOT BE A SONY!!! Good luck.
  • Shukai Fung
    Shukai Fung Aug 09, 2010
    Many people think that big companies charge very high, but it is not, I recommend you call Bestbuy, they could help you. And if you gave me the model #, I can give you a estimate.
  • justmelanee Aug 09, 2010
    tvhelp_dave..here's the model no. BRAVIA KDL-52W3000
  • ktanner74 Oct 31, 2010
    My TV is starting to do the exact same thing. Have you gotten any answers or help?
  • mckinneydt Dec 03, 2010
    Same thing with my tv. It just started happening. Is there any solutions yet before I spend any money on it?
  • mgaray9273 Dec 03, 2010
    No Solution, It just Gets Worst. Sony will not accept there is a Problem. The TV Repair guy told me to Buy a new TV.. It's upsetting!!
  • absludo May 08, 2011
    absludo@embarqmail.com___ mine has the same problem and i am totally disgusted!! i spent 2800.00 for a sony so it would last and give me years and years of good service. this issue should be taken care of by sony, give us all new tv's and if they dont lets get a law suit together with all of us buyers and sue them, if your in contact me at absludo@embarqmail.com
  • Michelle Savochka
    Michelle Savochka Jun 30, 2011
    SAME HERE!!! Bought March 2008. KDL 52 w3000. We are so distraught, especially because we thought we we're buying "top-of-the-line" being Sony. And that our investments would last for many many years...not 3!!!!
    For now, since I am unwilling to pay 2 grand to repair, I played with the menu, picture display...changed it to custom and maxed out the brightness and white balance and made the picture smaller "standard" so we can kind of see a half-quality image!!!!
    I am so dissapointed with Sony and will NEVER purchase their brand again!!! Walmart he we come...
Sony kdl52xbr4 tv has double vision on right side of screen perfect picture on left side is this a timing control board issue?
Fault with its T'Con board itself. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 14, 2015 | Sony Televison & Video
Does prolonged pausing of a Samsung LCDTV cause any problems with the screen/TV?
There may be a temporary residule image left on the screen but it should disappear within a few minutes. LCD screens do not "burn in" an image like the older Plasma's would.
Jul 19, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Toshiba LCD TV: Double image (right side) on power on
HEllo,
Did you find a solution to your problem?
Thanks
May 21, 2010 | Toshiba Televison & Video
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
I am getting double images while watching TV;
There maybe some loose components on the circuit and that needs resoldering. Bring it to the repair shop to done.
Dec 02, 2008 | Zenith C27A24T 27" TV
Ghost image
You will have to replace both the convergence IC's on your TV..
Oct 23, 2008 | Sanyo PLC-XR70N 70" LCD Monitor
Samsung lcd tv wont turn on
My Samsung LCD 32" 540 has two screens side by side. It worked fine last night, turned it on this morning and now double vision.
Aug 17, 2008 | Televison & Video
Mitsubishi platinum plus ws-55857
Solder connects = temporary fix.......Replace IC's..best
order two STK392-570 good quality.....16 to 22.00 each
...............................T.
Dec 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Video burn
Unfortunately, there is no fix for burn in on Plasmas. There is image retention, which is like temporary burn in, but it goes away within minutes of normal viewing. If this won't go away, there is no real fix.
Apr 29, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Sony BRAVIA KDL-52W3000 52 in. LCD Television Logo
1,946 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
