Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
CPU running at 100%. Computer very slow. - HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
    Problem Solver:
  • 11 Answers
Run task manger and try to end some of the programs that is run by you do not end the program that is given user name like this"system" and svst host try to end programs that take more than 10.000kb
Posted on Apr 26, 2010
Why will my fan not run during use but i hear it when the computer powers up?
Fans, mainly the CPU fan, have a speed control which slows the fan down. This is usually controlled by the BIOS. The speed is based on temperature of the CPU. If it's cool with little load the CPU fan will run very slowly and you won't be able to hear it. On startup all fans ramp up to 100% until the BIOS takes over and slows the fan down.
Jul 27, 2014 | Dell Inspiron 531s Desktop Computer
Tip
Computer CPU/Processor maxed 100%
Is your computer experiencing a CPU that is running at 100% Is your computer experiencing slow performance?
You can view your CPU utilization and other performance stats using Windows Task Manager. Press Ctrl + Alt + Delete and bring up Task Manager. Go to the performance tab.
The top of this screen should show your CPU stats.
In Linux you can use the TOP command,
Type the top command:
$ top
A CPU that is running at 100% utilization is not necessarily a problem. When the computer is booting up, or coming out of sleep mode, it may max out the CPU which is normal. The CPU will be utilized fully in order to bring the computer up as fast as possible. Some computers will even utilize the CPU while it is idle, to complete background task such as disk cleanup and file reallocation.
A problem will occur if the CPU stays maxed out. If it stays at 100% for more than a couple of minutes, you may be experiencing degraded computer performance.
Steps to reduce performance degradation.
-In a limited number of cases, software bugs can cause CPU utilization to spike. You will know this is the case if you are using a computer program(that is not hardware intensive like photo/video editors) and notice degraded computer performance. Check your CPU stats while running the program. If this is the case, check online for solutions and possible upgrades which resolve bugs in the software.
-You can reduce Windows start up programs, which will speed up the boot/wakeup process. You can do this from the MSCONFIG window. Go to Start > and in the run box type "msconfig". Go to the "startup" tab and you can uncheck which programs you do not want to start with Windows.
-A majority of the time a computer will get to a point were the hardware will need to be upgraded in order to handle the work you are doing. Common computer upgrades are memory, cpu, motherboard and hard drive.
-G33k
on May 15, 2011 | Computers & Internet
100% cpu usage
In Task Manager, go to the Processes tab and sort by the CPU column. See what is hogging up all your CPU. It may be a virus, if so, I recommend downloading Malware Bytes and doing a full scan. Warning, it could take several hours to scan depending on the size of your machine. Good luck!
Nov 23, 2013 | Patrick M. Kolla Spybot - Search &...
My Intel D945PVS motherboard has become very slow. I tried to add memory (4g) but no help. I think it could be the motherboard or cpu. I see the cpu running at 100% a lot of time. Can you help.
I will suggest to see running processes. It will show you what processes are running and which uses more memory (also cpu usage). It might be some virus or unwanted program.
May 09, 2012 | Intel Desktop Board D945PVS - Mainboard -...
My Toshiba satellite pro M10 very slow.
check your system performance thru task manager. check for CPU usage. usually COU usage is 1% to 10%. if your CPU usage would peak from 10% to 100% there is a huge possibility that there is program running on your computer that eats up your memory. Or it could be spyware/malware
Mar 27, 2010 | Toshiba Satellite Pro M10-S405 Notebook
Dell Dimension 8250 PC running Windows XP SP2 has CPU always at 100%
I guess it could be a virus, avast is not the best antivirus in my opinion, try to get a norton antivirus or NOD32 update it and run the scan, it ocuurs when a replicating virus copies files to all your HDD and is always busy...making system busy...and one more thing there could easily be a copy of the virus in your pen drive as well...
Jan 19, 2009 | Dell Dimension 8250 PC Desktop
Advance Bios Set up (CPU frequency (MHz) setting)
Your computer is telling you there is a problem with either the memory or the interface between the motherboard and the memory. There is a utility you can use called memtest. I would run that and see if you get errors. Often it is easier to simply try a different piece of memory in the slot, because even if you detect errors it could be due to the interface and not the memory itself.
But the first thing you should try is power off the computer, remove the cover, blow all the dust from inside the case, remove the memory and blow all dust from the memory sticks and slots, then put it back together and try again. This is free and solves the problem about 20% of the time.
Good luck.
Jan 11, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
