Question about Microsoft Xbox 360 Console
Xbox360 1 Red light, sometimes 2
I just got an xbox 360 off of ebay (bad idea i know).... well i went to crank it up and got a top right and bottom left red rings. Then it goes from two to the top right just being red. I had it working for about 10 seconds. The guy I bought it from had a Thermaltake liquid cooling system put on it. Any ideas on what I can do to get it to work?
  • Tommya77 Mar 23, 2008
    sorry. instead of top right blinking it is top left.
    Sergeant:
    Champion:
  • 427 Answers
There are two things that those light mean.
-the best solution is to VACCUM the dust out of the xbox before you get other problems. The collecting dust is making ur xbox overheat. So keep it clean before you get the 3 or 4 rings of death!
-also, take off that cooling system because the 360 works best without cooling fan.
-Finally, make sure your A/V cables are securely plugged in.
Posted on Mar 23, 2008
2 RED LIGHTS ON XBOX 360
Two red lights sometimes means power to console troubles. There is a code you can get from machine and this can direct you better to cause of failure. When the machine is on press the sync button then the eject button at the same time. The 2 red lights will go and lights will appear and this will be youre first digit of the 4 digit code. Do this 4 times. 1 red light is 1. 2 is 2. 3 is 3. 4 red lights is 0. Let us know the code and i may be able to put you in the right direction.
Jul 01, 2010 | Microsoft Xbox 360 Console
Red flashing lights
If you have 4 lights, check your A/V cord. 3 lights is the Red Ring of Death. Call Microsoft. They have an extended 3 year warranty for this problem. hope this helps AJ
Nov 16, 2009 | Microsoft Xbox 360 Console
My xbox 360 ha 2 little bars on the power button
Do you have two controllers? If it's the top left and the top right one that's probably the case. They light up in order top left, top right, bottom left, bottom right based on the number of controllers connected to it
Oct 15, 2009 | Microsoft Video Game Consoles & Games
Wont load,blinking red light on the power button
if it is the top left, bottom left and bottom right lights blinking red, this means that there is a hardware failure in your xbox 360 and there is no current way to fix this. i recommend that you send it in to xbox to see if they can do anything, and if not, they will possibly send you a new xbox 360.
Sep 27, 2009 | Microsoft Xbox 360 Console
2 RED LIGHTS
Here is a website I used when my 360 went haywire. It helped me out, maybe it will help you or at least lead you toward the right direction.
http://forums.xbox-scene.com/index.php?showtopic=484726
Aug 03, 2009 | Microsoft Xbox 360™ Premium White Console
Bottom right corner red flashing light error e 74
From the Xbox website sounds like you have a HDD failure / issue.
Try the following steps to resolve the problem: 1. Turn off your Xbox 360 console. 2. Removethe Hard Drive. For more information about how to attach or remove theXbox 360 Hard Drive, click the following article number to view thearticle in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/ ) How to attach or remove your Xbox 360 Hard Drive 3. Reattach the Hard Drive. 4. Turn on your Xbox 360 console.Ifyou continue to experience this problem, obtain the latest automaticupdate for your Xbox 360 console. To do this, follow these steps: 1. Turn off your Xbox 360 console. 2. Detach the Hard Drive. 3. Connect the console to the Internet through an Ethernet cable.Notes • Toobtain an automatic update without your Xbox 360 Hard Drive attached,you must have an Xbox 360 Memory Unit or an Xbox 360 that has built-inmemory. • If you cannot connect to Xbox LIVE, running a recent game (2007 or newer) causes an automatic update to be installed. • You can also obtain the latest Xbox 360 system software from the following Xbox Support Web site: http://www.xbox.com/support/ (http://www.xbox.com/support/) If applying the latest automatic update does not resolve the problem,please contact Xbox Customer Service. If the Customer Service agentcannot help you resolve the issue, you may have to replace the HardDrive. Discuss your replacement options with the agent.
For moreinformation about how to contact Xbox Customer Support, or to submit arepair request, please visit the following Xbox Support Web site: http://www.xbox.com/support/
Jul 25, 2009 | Microsoft Xbox 360 Console
Red Ring of Death : 1 Red Light
Well the why part of your question can be answered here - http://www.xbox.com/en-US/search.aspx?keyword=one+red+light
They go into many of the error codes, as to how to fix it without voiding the warranty; If it's under warranty send it in to be fixed, or if you're dying to play right now try the 'towel method' shown here -
http://www.xbox360rally.com/the-red-ring-of-deathcure-found/
Beware- purposefully overheating your xbox 360 may damage your system further.
Please rate my response :)
May 30, 2009 | Microsoft Xbox 360 Console
Xbox 360
I would recommend sending this back to microsoft if you can. If you can't for some reason. Ebay has many sellers who will fix 3 lights of death for much cheaper that MS will.
- John
Jun 21, 2008 | Microsoft Xbox 360 Console
As playing Xbox 360 system shuts off two red lights occurs.
Two red lights mean your 360 is over exceeding the inside temperature. Your fan must not be working at all and your 360 is overheating tremendously. That is what I know about the 2 red lights. Im not sure what to tell you to fix this but to just call 18004myxbox.
Mar 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
74 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
