Question about Refrigerators
My servis m7665 keeps freezing everything in the fridge.
SOURCE: the fridge part of my fridge freezer keeps freezing everything,
I tried solution 1 without success, so I resorted to switching the whole unit off at night and on in the day to stop it freezing up. After about a week of doing this it started working properly again. One month later it is still OK
Posted on Mar 20, 2009
  • 47 Answers
SOURCE: fridge freezing
sounds like your thermostat is buggered mate
Posted on Nov 11, 2009
Toad tool
  • 33 Answers
SOURCE: bosch fridge keeps freezing all food
put some beers in there
Posted on Dec 15, 2009
BMT60
  • 126 Answers
SOURCE: Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Posted on Apr 25, 2010
SOURCE: fridge keeps freezing
Can't solve your problem, but just to report we have exactly the same issue, a huge block of ice forms on the upper rear panel. The compressor seems to be running 24h, not matter where the 'thermostat' is set.
I suspect that there was/are a faulty batch of thermostats. Or (since there is no metal cooling plate to bolt it to) that the T/Stat probe has somehow come adrift from its correct sensing area and is not correctly sensing the temperature inside the fridge.
If I get to the bottom of the problem, I will re-post here.
Posted on Sep 13, 2010
My Samsung RL39WBMS fridge on m fridge freezer keeps freezing food. Why is this happening all the time and how can I prevent it?
maybe the fridge is set on a colder setting and if that's not it then stick it on the lower shelves and that might help from not freezing because are fridge is the same way when it is stuck by the coolant fan
Nov 02, 2014 | Refrigerators
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
I have a servis fridge freezer m7664 and the fridge is freezing over I have it on setting 4 out of 6 I have tried to defrost it is there anything else I can do
If the fridge is in a position where it is in contact or near a heat source the sensors will not function correctly. I assume it is a modern day fridge which are over sensitive. I had a similar problem and now run the fridge on low and defrost every few weeks after emptying it.
Hope this helps. Regards
Apr 16, 2014 | Refrigerators
Have a servis fridge freezer and it kept over freezing no matter what setting, ice would keep forming on back of fridge, and the motor never seems to go off. so i replaced the thermostat yesterday but...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Mar 30, 2011 | Refrigerators
Hi i have a servis fridge freezer, the freezer is fine but the fridge does not get cold, any suggestions?
Try clearing everything away from the bottom venting in the freezer and check for ice build up in the vents. Defrost it like you would in the "good old days" and to ensure it doesn't happen again, keep a 1" to 2" clearance in front of the vents in the freezer. If need be, set a cookie cooling rack on it's side to act as a barrier for the vents to ensure proper air flow.
Sep 22, 2010 | Amana ATB1832AR Top Freezer Refrigerator
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
I have a servis fridg freezer and the fridge is
sounds like the thermostat has packed in, it works as a switch for the compressor (which will be constantly on) if its a conventional model and should be replaced. if its a frost free it will be a control module thats faulty.
never work on a live appliance and get expert advice if you are at all unsure when replacing parts as if not isolated properly you will give yourself a nasty shock.
Jul 22, 2009 | Freezers
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
