Question about Whirlpool GR465LXLS Electric Kitchen Range
What do codes e2 and f1 mean? - Whirlpool GR465LXLS Electric Kitchen Range
    President:
  • 949 Answers
Here is what the manufacture says about it, my comments are below.
F1 E2 - UL A/D error(s)
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Phil's comments----->
F1 Codes are related to the control itself, if there was a storm, power outage, surge etc it could have damaged the control. Try resetting the board by unplugging the range or turning off the breaker for a couple minutes. Restart and see if that helps. If not you will need to replace the control.
The part number for this unit is 4453614 and runs just over $300.00
Posted on Apr 25, 2010
Testimonial: "i am very thankful for the fast and accurate service. i am a maint. tech, and i will definetley pass this site onto my colleagues. thanks again! "
4 Suggested Answers
SOURCE: range displays e2 f1 and beeps every so often
what control?
Posted on Nov 04, 2008
blueextc3221
  • 15935 Answers
SOURCE: kenmore range code f1 e2
F1-E2 - UL A/D Error(s) - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Daniel S
  • 4323 Answers
SOURCE: Message on stove top reads E2. F1 what do these
Hi
Error code F1-E2 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 31, 2011
What does error code E2-F1 mean?
E2 F1 - UL A/D error(s)
1. Disconnect power longer than 30 seconds.
2. Re-apply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control.
Mar 30, 2016 | Kitchen Ranges
Fault code F1:E2
Thanks
Oct 10, 2011 | KitchenAid KGST307 Gas Kitchen Range
Roper Range error code message with beeps for F1 E2
F1 - E2 UL A/D error(s)
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Aug 20, 2011 | Roper Refrigerators
Panel says E2 F1
Hi
Thanks for using FixYa. F1-E2 error means that the oven is too hot & the oven temperature sensor has gone bad and should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Whirlpool Ovens
Whirlpool Oven Model RF365PXGN getting a error of F1 and E2
HELLO, I HAD THE SAME PROBLEM. ALL YOU HAVE TO DO IS FIND YOUR CIRCUIT BREAKER BOX AND LOOK IN IT FOR THE BUTTON THAT SAYS KITCHEN. TURN THE KITCHEN POWER OFF FOR 30 MINUTES THEN TURN IT BACK ON. ONCE YOU TURN IT BACK ON THE OVEN SHOULD RESET ITS SELF. TRY THAT AND IT SHOULD HELP.
Oct 31, 2008 | Ovens
Range displays e2 f1 and beeps every so often
F1 E2
Oct 26, 2008 | Whirlpool GS460 Gas Kitchen Range
Kenmore range code f1 e2
Aug 05, 2008 | Kenmore 72002 / 72004 Kitchen Range
Codes
F1 E1 N/A EEPROM checksum error Replace control no code posted for e2 f2
Mar 04, 2008 | Kitchen Ranges
Kitchenaid range
could i get a more complete mod num on this range my tech data shows no f1 e2 code f1 is usually the eoc there should be more numbers after 307 theses are the engineering codes and are model specif
Dec 28, 2007 | KitchenAid KESC307 Electric Kitchen Range
Whirlpool GR465LXLS Electric Kitchen Range Logo
421 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
