Question about Vacuums
Eureka powerline gold
The brush is rotating, but it is not sucking.
  • realgal17 Mar 24, 2008
    I downloaded the manual from my vacuum from the manufacturer's web site, and followed the instructions for finding the clog in the hose, and voila, I found it and fixed it!
    President:
  • 1,673 Answers
If no suction, then you have a clog either in the hose, the dirt inlet by the brush roll, or bad filters.
Posted on Mar 24, 2008
Spinbrush not working on eureka as1104
If the belt is intact, the brush roller ends may be so jammed (usually with hair) that it cannot rotate. Also, if the brush roller cannot rotate, the motor shaft may be rotating in one spot on the belt and eventually will burn it out. The solution in the case of the brush roller is to remove it and check for free rotation. If the ends are binding, the brush roller will have to be disassembled to remove debris.
Aug 10, 2014 | Eureka Vacuums
Brush will not spin on the eureka airspeed gold vacuum
must be the belt
http://www.emerusa.com/eurekastyleuvacuumbeltsrepalcement.aspx
Apr 07, 2014 | Eureka Vacuums
Doesn't pick up and blows dust forward
Check for clogged hoses, dirty HEPA filter, animal/human hair, carpet fibers/threads- build up on brush head or inside underneath the brush head.
Sep 23, 2013 | Eureka Powerline Cyclonic 4484 Upright...
How to change the belt on a Eureka powerline limited edition vacuum cleaner.
The belt is directly connected to the brush roller. Remove the brush roller cover. Pull out the brush roller. Remove all carpet strings. Change the belt.
Jun 11, 2011 | Vacuums
Eureka lightspeed dirt comes from underneath vacuum cleaner
Usually this is either a broken belt or a clog in the tube that leads up from the brush head.
Feb 28, 2010 | Eureka Powerline LiteSpeed 5845 Upright...
I have to check the belt in the ereka powerline plus. how do I do that?
Below I have listed a link that will open the owners manual that has step by step instructions on how to change the belt. Also I have listed links for the replacement belt you need. Eureka recommends replacing your belt at least every 12 months.Hope this helps you.
Eureka Powerline LiteSpeed Owner's manual
Eureka Powerline LiteSpeed Replacement Belts
Oct 29, 2009 | Eureka Powerline LiteSpeed 5845 Upright...
My eureka 437 stopped sucking
I believe the filter on your vacuum is clogged. Bagless vacuums require the filter be brushed or washed and dried, If they are not, the filter will clog, resulting in the reduction of suction. Clean filter about every 3 months or sooner if the same problem happens again. Hope this helps.
Aug 20, 2009 | Eureka Vacuums
Have eureka 9734 replaced belt, put back together,brush rotates well but vacuum is not picking up anything, no suction.
It sounds like the machine is clogged. Check the port behind the belt and any and all hoses for obstructions and remove.
Apr 13, 2009 | Vacuums
How do you remove the vacuum roller off
I assume this an Eureka? If it is then there are 2 screws on the top cover, take them out and the cover will come off, the belt and brush roller are out in the open now. Brush roll Part #54941-1 and belt part #54312.
Nov 12, 2007 | Vacuums
Vacuums Logo
226 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
