Question about Whirlpool DU1055XTS Built-in Dishwasher
Machine was running and just stopped. no lights on display almost as if no power. checked connections and have full voltage at the incoming connection box
    President:
  • 949 Answers
If you are getting no lights no power or any sounds the first thing to check is the power to the dishwasher, make sure there are no wall switches in the kitchenmachine was running and just stopped. no lights on - 2_bing.gif that have been turned off and that the breaker has not tripped if those are fine then the most common component to fail and cause this symptom is the thermal fuse.
It is located in the console attached to the control circuit board. The fuse is about $20.00 in cost. The part number is W10258275
If you want to replace this part your self I would be happy to walk you through the process, a little mechanical ability some hand tools and a basic understanding of electricity is needed.
Here is a picture of the part
Posted on Apr 25, 2010
I have Samsung front loader washing machine that stop working suddenly there is no power no nothing and I checked power supply and nothing wrong with power supply .
Your power supply normally connects to an EMI filter immediately upon coming into the washer. If you have a voltmeter and are comfortable with electricity, you should remove the top cover of the washer to access the connections. Unplug the washer and shut off the water while dismantling. Remove the 2 screws at the back of the top portion (lid) and push the lid towards the back to dislodge it.
At this point, you should be able to locate the incoming power cable and see where it connects to the EMI filter. Once you have identified the connections, plug it the washer and verify that there is voltage both before and after the EMI filter. If there is no voltage at the incoming side of the filter, then your cable is broken and should be replaced. If there is voltage on the incoming side of the filter and none on the outgoing side, your filter is open circuited and should be replaced. If there is voltage at all locations, look for wires that may have shaken off during operation. When poking around inside the washer, looking at wires, pull the plug first. If this does not help, take a picture of the schematic diagram that is affixed to the top of the soap dispenser/water inlet box and post it for our reference. I have attached a typical diagram from a older Samsung washer. section-yodzb2tavlblrpvbck4ieuwo-2-1.jpg
Jan 10, 2015 | Samsung WF337AA Front Load Washer
Tip
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
on May 14, 2015 | Xantrex Technology Electronics - Others
Electrolux model eied55hiw no power or display lighting, or dryer light when door is open. Therm Limit ohms good. Any ideas from here?
check your terminal block for short if it checks ok then i would start at the control , check incoming voltage and voltage to your display , use the tech sheet to follow wires .
Feb 17, 2013 | Electrolux Eied55hiw Eied55hiw Front Load...
Amber light is flashing on my computer and it won't turn on at all. Help!
The Dell Dimension 300 gets the amber blinking light when there is power to the computer (the power supply) but the motherboard isn't getting the correct power. Sometimes it can indicate a motherboard fault or that the power supply is not set to the correct incoming voltage.
Check the back of the computer. If the power supply has a switch for incoming voltage, make sure that it matches your incoming voltage. Next check that the main power cable (20 or 24 pins depending on the computer) is fully seated on the motherboard. (It can only be connected one way and should lock onto the connector on the motherboard.)
Next check that the power supply is providing the correct power. You can simply install another power supply (known to work on another computer). Make sure that the PSU is correctly sized for the computer components. Alternatively use a multimeter or a dedicated power supply tester or put it in a different machine.
If the problem is not cured with a new PSU, the motherboard has a failure. Unfortunately, it's difficult to identify the exact bad component. (If a major component other than the CPU on the motherboard had failed, the diagnostic lights or beep codes could help identify the issue.)
I hope this helps.
Jun 10, 2012 | Dell Dimension 3000 PC Desktop
The power light comes on our econotig but not welding, all connections are secure and grounded, whats the problem?
checking incoming power supply voltage,if its right check output voltage(DC voltage showing in the manual)if not working,,,machine has to be checked thoroughly
Apr 17, 2012 | Miller Welding Tools
My incoming voltage is only reading 200v, will this stop the unit from running??
If it needs 208 or 220 then yes it will stop the unit from running.Check the voltage at the circut breaker to verify its not a wiring issue.
You may need to get a new circut breaker.Also check a 115 volt outlet if its is also reading low ,like 100 or 105 volts then the power ccompany is cutting power back and theres nothing you can do.
Jul 20, 2011 | Dayton (3UG73) Electric Utility Heater
Craftsman snow thrower. headlight stopped working. i tested voltage from alternator and have nothing
The voltage from the alternator is AC, and will increase/decrease with the engine speed, so when checking, run the engine at full throttle. 1/2 of the alternator is not used, the other 1/2 is used to power the light. Also, inspect the light harness plug-in just above or below the starter. Check for being disconnected, burnt, or wiring pinched around the starter mounting area. Lastly, check the bulb with a 12 volt battery, connecting one bulb spade to the + connection of the battery, and the other spade to the - connection.
Nov 22, 2009 | Craftsman Garden
Amana PTH073B25AM has no control and the PCB display will not light up or display temp. I have checked and verified Line voltage @ 240vac and control voltage to the PCB to be 24vac. The unit was bought 2nd...
If you are able to open the side of the Case that supports the Pc board, and get a flashlight, there is a Fuse that is usually connected inside that area. Of course make sure the power is off before looking.
Good Luck!
Nov 03, 2009 | Amana PTH073B25AJ Heat Pump,7000BTU, 230V,...
Air not working
The first thing to check is incoming 120VAC power to the unit. This voltage must be 115Volts domestic USA with no less than -10% allowable. If your voltage is below this point, the unit will not work. If your voltage is ok, check the thermostat or selector switch. Make sure that the thermostat (if wall mounted) has 12VDC running to it. If it does not, fix that problem first. If it is manual control, check the selector switch for ok. You should have incoming 120VAC power to the switch and when the High/Cool is selected, check the following.
Terminals LI and C, and L1 and 1 should have continuity. If not, replace selector switch.
Hope this helps,
Jeff
Apr 25, 2009 | Dometic 57915531 Air Conditioner
Whirlpool DU1055XTS Built-in Dishwasher Logo
146 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
