Question about HP w1907 LCD Monitor
Bought it in 2008, now it comes on for 90 seconds then goes out. Probably a bad inverter or power supply board. Are parts available for this monitor?
  • Lin0
    Lin0 Apr 28, 2010
    JUMUAH,
    I have several service centers in Ann Arbor, MI including BPI, so as you said: I walked in, and they literally told me it was a "throw-away" monitor and that parts were not available.
    Yeah screen blanks out after 90 seconds or so, and led lit power button remains lit up.
    President:
  • 1,561 Answers
Is it the screen that goes blank or the power of the monitor? is the power led button on?
If the power led button is on, and it is the screen that goes off, this indicates that the picture board of your monitor is malfunctioning and will need to be replaced.
But if it is that everything goes off, it means the inverter is bad and will need to be replaced.
For the parts, yes, Being HP is even advantage, because virtually,most service centers do have the parts
Just walk to any hp service or any service center within your vicinity to get them.
Take care
Posted on Apr 25, 2010
Westinghouse sk32h240s. the screen goes black after a few seconds.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 23, 2016 | Westinghouse Televison & Video
My TV gets power and sound. The picture is on for a bit and then goes blank, then comes back on, then goes blank. What parts do I need to order to fix it?
May 17, 2016 | Vizio Televison & Video
My picture goes black after a few seconds
The contrast and brightness are controlled by the main board. If that board is not sending the right signals, the picture is dark.
Nov 29, 2014 | Computers & Internet
Apex LD4088 LCD Power but no picture
If you have replaced the inverter board and the power board with known good parts the the panel itself is bad.
May 31, 2013 | Apex Digital LD4088 LCD TV
Tv goes balck and sound goes off but green poswer lite stays lit
If this is a reoccurring problem, it's most likely caps in the power supply that went bad. If it only happened once, you probably have a bad inverter board.
http://cgi.ebay.com/10pcs-Electrolytic-Caps-KIT-16V-50V-0-1uF-1000uF-/290505738749?pt=LH_DefaultDomain_210&hash=item43a37dc9fd#ht_1734wt_905
These are the caps in the power supply that usually go bad, however, check the values on them if they are puffed.
http://www.youtube.com/watch?v=8l0AUj8QUkg
Good video.
If it's the inverter board, you'll have too look up the board number on the circuit board. It's going to be along the side. Type it into E-bay to see if any of the boards are available.
Jun 19, 2011 | Sony KDF-E55A20 55 in. LCD Television
LT2020 screen goe black after five seconds but sound and power is available
Hello Paul, its the inverter board failure, this board supplies power to the LCD back lamp, this needs to be replaced, i'm nor sure about the availability of the part. Try www.usefulparts.com under the manufacturer box. If the board is available have this installed by a technician. Also check out ebay, or do a goggle search for the part.
Feb 24, 2011 | Norcent Technologies LT-2020 20 in. LCD...
Philips 19pfls422d/27 LCD tv. Turns on for a few seconds, everything is great, but then shuts off (power light goes from blue on to yellow standby) Was told it's the power supply board, but I can't find...
It may have gone into protection shut down mode because it sensing overload by such thing as the backlight inverter board. You may want to inspect the power supply module first for bad DC filter caps, then check for shorts in the inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 28, 2010 | Philips Televison & Video
BSOD on DELL E228WFPc - goes black in a few seconds
You could have a faulty inverter board. The inverter supplies high voltage to the CCFL lamp/s, these lamps are mini fluro tubes approx 1,5mm dia. and the length of the screen.
Check the inverter output and you maybe able to get parts from
www.lcdparts.net
or from DELL
Dec 13, 2009 | Dell E228WFP LCD Monitor
After three seconds power it on the back light goes off. At this point if the display is turned off and on again, the image gets back and gets dark again after three seconds
There seems to be bad solder connections either on the power supply or the inverter Board. You may even have a bad capacitor on the power supply board. When caps go bad sometimes the yswell at the top of them, if you take off the back cover look for swollen capacitors in the power supply. The inverter board has small inverter transformers on it, check for bad connections on it, caution tho this board has high voltage on it. One good way to check the inverter board is while you have the back off. Darken the room as much as possible, even total darkness is good and turn on the monitor while looking at the inverter board for small arching or sparks, if you see any then this is your problem area.
Oct 01, 2009 | NEC AccuSync LCD71VM 17" LCD Monitor
Sylvania 42
Check the fuses on YSUS & ZSUS boards, if found the fuse blown on that board, just try to replace the board.
Dec 30, 2007 | Sceptre X23gv-Komodo 23 in. LCD TV
HP w1907 LCD Monitor Logo
215 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
