Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
Need a drive belt diagram for a 13am762f7765 bolens
How do I change the belt on a bolens 3.5 25 cc model lv148ea
The LV148EA is the model number of the Tecumseh engine.
Please look again for a Bolens model number.
Sep 21, 2016 | Garden
Free belt diagrams
There is no way to get the diagram without knowing the model number. The model number will be under the seat most likely.
Jul 17, 2014 | Bolens 13.5 HP Manual 38-in Riding Lawn...
I need a diagram of a bolens 15.5hp 38'' belt
i am looking for a spring and belt diagram for my bolens 38" cut lawn mower
Jul 29, 2012 | Garden
I need a diagram of how to put the Blade belt on my Yardman 42' riding lawnmower
Yeah, these belts can seem impossible to figure out. There are idler pulleys that press against the back of the belt. The routing is sometimes not obvious. Do a search for your particular model.
May 11, 2012 | Craftsman Bolens Yardman Front Tine Tiller...
How do I put a genuine factory parts deck drive belt O.E. 954-04062/754-04062 on 38"Bolen's lawn tractor model#13AM762F765
To start with, the easiest way is to remove the mowing deck from the tractor. It will really be tough if you don't or can't. You may need an owners manual to guide you through all the steps.
1. Remove the cutting deck from the tractor 2. Work the old belt off (if not broken) the mandrel pulleys and idler pulleys 3. Pull the belt away to reinstall a new one 1. Work the new belt around both the mandrel pulleys 2. Make sure the belt is in all the pulley grooves and inside all the belt guides 3. Now you have to reinstall the mowing deck. Here are some diagrams that should help you.
http://www.ereplacementparts.com/bolens-13am762f765-2005-lawn-tractor-parts-c-27272_27390_27402.html
Apr 19, 2011 | Garden
BOLEN RIDING LAWN MOWER 13AN683G163 TRANSMATIC DRIVE. REPLACED BELTS AND THE MOWER RUN IN 7TH SPEED AND SLIP WEHN I TRIED TO PLACE IN LOWER SPEED
Either the belt routing is incorrect or there is a tensioner which needs adjusting. Recheck your belt installation. Oh, it could be the wrong belt, too.
May 01, 2009 | Garden
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
113 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
