Question about LG Flatron L1919S LCD Monitor
Blue on indicator light not working
When turning monitor on the blue on indicator light does not light up monitor working ok just not indicator light
    President:
  • 1,561 Answers
If turned on and working good, just the indicator light that does not show.
This indicates that the indicator bulb is bad or burnt.
All you need to do is to replace the indicator bulb of your monitor.
Take care.
Posted on Apr 25, 2010
Testimonial: "thank you very much "
Hp pavilion modelp6510f press power switch on top of pc does not light computer fans blow but compute does not turn on
ok th p6000. complete range when they were made had to be recalled as they put the copper expansion pipes ran across the gpu & cpu hence a massive overheat problem. they put copper shims over the cpu & gpu but this worked for a short time but it was inevitable and both units ended up being cooked i had this problem with mine. so if you have tried external monitor with no images it would sound or more likely to be the gpu cooked sorry for the bad news.
Jan 28, 2014 | Computers & Internet
Nothing displays on the monitor when I turn on the computer
is there power to the monitor? is the monitor in standby(yellow light on monitor)? is the monitor on (green light on monitor)? how is the monitor connected to the computer, VGA (square fat cable, the end may be blue) or HDMI cable? When you turn on the computer is the power light on and HDD light flashing / showing activity? this would indicate that the computer is booting up. If you have power light and activity on the computer, I would unplug the data cable to the monitor. If the monitor is plugged in, i would press the power button to try and turn on the monitor / take it out of standby. If the monitor is ok you should see a message like "no signal" or "no input". This would tell you that the monitor is fine, but you may have a problem with the video card or video port on the motherboard. If you have no activity light on the on the computer, you may have a problem with the OS not booting up. You really didn't provide much detail on what has been done, but this is how I troubleshoot out in the field when working on something like this.
Oct 09, 2013 | Computers & Internet
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
HPvs17x power flicker on/off no image, 3-10min after image ok!
More likely to have failing power supply problem due to bad caps, look for caps with bulging top first and post back what you see inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 02, 2010 | Computers & Internet
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
Can't get monitor to power on
I have a similar switch on mine, although mine is a Gateway. So my solution is going to assume the same indicators and functionality.
On mine, a blue-violet power switch indicates it is off, red indicates standby mode, and blue to indicate it is on and/or searching for a signal. When turned on (blue), the monitor will go to standby mode (red) after 3 to 4 seconds if it does not detect a source signal. So if you toggle the power switch to blue and it soon changes to red, you'll need to check your signal, cable, or possibly for a bad source connection on the monitor.
Oct 12, 2009 | LG L206WTY-BF Monitor
Monitor and keyboard won't turn on
A couple of things here:
1) The flashing light and signal message indicate that the monitor is functioning but is not receiving a signal from the computer.
2) The memory that you added is liklely to be incompatible with the computer itself and is preventing the system from booting. The computer will perform a selftest when powered on. Normally when there is a memory issue, the unit will beep. In some cases, there will be no action.
Remove the added memory and attempt to boot the system. If it starts up OK, then the memory you have added is the problem.
Update this if you require additional assistance.
Thanks,
Dan
Apr 15, 2009 | Computers & Internet
How to connect to external monitor?
You need to determine the fault first.
Can you determine exactly where the boom came from (the adapter or laptop)?
When you turn on your laptop does the LED lights indicating that there is power to the laptop and you can hear the hard drive spinning as well as the fan?
Do you know the power adapter is OK (you can test it with a multimeter)?
If the laptop is dead then the external monitor is of no use.
The laptop normally has a blue video output connector, usually on the back edge of the laptop where you can connect an external monitor or a data projector. When a monitor or projector is powered up first and then the laptop the display goes to the external video first. You can switch between the laptop screen and external video by clicking the blue Fn + F4 function keys.
Mar 01, 2009 | Compaq Computers & Internet
LG Flatron L1919S LCD Monitor Logo
386 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
