Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52W20 has no picture only sound. - RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca 52w20
deads lamp replace it
Jul 06, 2013 | Televison & Video
Have ghosting on my 50 inch RCA projection and lines at the top of sreen
convergence issue. Press the menu button then scroll down to setup and enter the setup menu and see if the Auto convergence feature is still listed under setup options or has it disappeared. Let me know and I will assist with what to do to fix the issue.
Mar 18, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an rca 52w20 rear projection tv. Lost the red and thats the only problem. What could be the cause
chuck_shiple,
You more than likely lost the red tft panel in the optical engine. Repair would require a new optical engine. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the process and where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 06, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52w20
it should be around 21 v so chances are the main filter ( Power supply) is functioning
Sep 18, 2008 | Televison & Video
RCA 52w20 question
Check 3 capacitors on FBT board 2200uf 16v and two 220uf 35v replace all of them,also CK all ribbon connectors and plug ins on board they can be defective also make sure second ribbon connector is in right on FBT board this will keep it from coming on also.
Sep 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rca 52w20 powers up with three high pitched noises then nothing
sounds like the flyback which is the number one component that fails on that model. You need flyback 259296 and you can get a replacement flyback at the following with step by step instructions on how to replace it. heres the link.
http://servicemanuals.vstore.ca/
Sep 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCD 52W20 with no green...
Re-check hook up on focus/screen adjust assembly.Adjust RGB screen controls.All green/ no control can be bad green CRT==check w/CRT checker.CRT OK/==diagnosis required.Green video drive circuit??
Jul 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
109 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
