Question about Mustang 100 Manual PullDown Projection Screen
69 mustang with drum brakes all the sudden pedal
69 mustang with drum brakes all the sudden pedal goes all the way to the floor but i still have fluid in the master cyl.
Sounds like air in the line, you need to bleed them
Posted on Apr 25, 2010
Brake pedal is mushy all the way to the floor. Have already replaced front calipers, master cylinder, and bled all the brakes. Pedal still goes all the way to the floor when stopping the car.
If the car has drum brakes in the rear, Jack the rear up and have someone push the brake pedal hard and you try to turn the wheel. If you can turn it you need to adjust the rear shoes. They may be traveling out so far that the fluid level drops causing the pedal to go to the floor. You must adjust them with the drum on till you hear and feel the shoes rubbing against the drum. Hope this helps.
Dec 30, 2010 | Honda Accord Cars & Trucks
1993 ford mustang brake pedal goes down on its own and brakes
Check the vacuum brake booster and check valve maybe there is a problem there that is amplifying the vacuum inside the booster and applying the brakes. I hope this helps, let me know.
Aug 02, 2010 | 1993 Ford Mustang
My brake pedal goes all the way to the floor
could be the seals in the master cyclinder
Apr 07, 2010 | 2003 Ford Escape
Brakes spongy after shop replaced rotors braked pads on 2001 buic
Sounds like air is still in the brake lines, the air sound that you hear is the power assist, but the brake pedal needs to be "high and hard".
if the pedal goes to the floor, that is not good. Sometimes, when pumping brakes for bleeding purposes, the master cylinder gets damaged, as the piston goes past it's normal "travel zone" and gets damged on deposits.....
Now, with that being said, if everything was perfect, brakes are typically not as firm after replacement, due to differences in new pads/shoes and old rotors and drums. Pedal to the floor, however, is never okay.
Doc
Sep 18, 2009 | 1995 Chevrolet Blazer
Brake pedal goes down to far abs brakes
Hi I'm litoshop if you bled the system and get no results then your brake pump needs to be replaced now before replacing make sure your pads are installed correctly because if there not this to can cause this problem good luck. if this information has been useful please let us know thank you.
Aug 11, 2009 | 1998 GMC Sierra
69 mustang brakes
one of two things. first you need to make sure the star adjuster is adjusted the same on both sides. the reason is that when you hit he brake the right side is trying to stop you and the left side isn't.. or you brake line or wheel seal on the right side is sticking..i would try to adjust the little star spinner i think thats your problem..good luck keith...
Mar 15, 2009 | Ford Mustang Cars & Trucks
2001 Mustang GT rear brake job
yep this is a two man job, onece you get air in the lines is better to do all four, my has abs and i was able to do it, but next time don't take anylines lose just turn the piston clockwise and you should be able to push it in.
Sep 11, 2008 | 2001 Ford Mustang
97 ford e350 brake pedal goes to the floor...
are your rear drums set up? why did you bleed the brakes. when only when you installed new pads?
Sep 11, 2008 | 2002 Ford E350
Mustang 100 Manual PullDown Projection Screen Logo
248 people viewed this question
Top Mustang Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Mustang Office Equipment and Supply Expert? Answer questions, earn points and help others
