Question about Canon imageRUNNER 5570 Copier
Ir5570 error code e000804-0000 - Canon imageRUNNER 5570 Copier
  • Canon Expert
  • 1,326 Answers
A E000804-000 is a fan error code. I would first check the connector for the fan that seats in front of the Primary Charge unit. The connector seats right above the fuser unit in side the front inside cover. I've seen the connector get pulled out with the fuser cover. It has 3 wires in the connector, The code will not rest till the problem is resolved.... Good Luck
Posted on Apr 26, 2010
  • Mr Be Dec 12, 2011
    I need more info.... front fan turns on (wen main motor drives) but code pops up.... is there a second motor that is a main drive fan, help. Austin. :-)
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
How to fix the Canon Image Class Printer 4750 error code e001-0000
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
5570 error code e000005
That's a Cleaning Web Counter error code.
To clear it press * 2 and 8 * in that 2&8 are pressed simultaneously.
Go to the Web counter and clear the counter back to Zero (0).
The machine will reboot and Ur problem will be solved.
Please check the below service manual for ir5570 it will help u much in the future if u will have other problems the link is below:
http://goo.gl/nXRXBt
All the best....
Jul 18, 2013 | Canon imageRUNNER 5570 Copier
I have a ir 6570 xerox prtinter. but i do not known error code list. so i seeking the list of full error codes ,please help me
I put the operators guide up on my server temporarily. Grab it quick.
http://www.itrsva.com/IR5570-6570M.pdf
Look starting at page 9-76.
Jul 20, 2011 | Office Equipment & Supplies
Canon ir5570 error code e000110-0001
Hello crystal... on ir5570 error E000110-001 indicates that the polygon motor is not functioning and must be replaced. Joe
Thanks for choosing Fixya!
Mar 10, 2011 | Canon imageRUNNER 5570 Copier
E0004-103
This problem is caused by the fuser unit that fuses the ink to the paper. You will need to reset the service error in the service mode before the code will be reset. The procedure for resetting the service error is in the manual but is entered by pressing the * 2+8 buttons together and then * again. Then select FUNCTION - CLEAR - ERR Then exit service and turn the machine off and on and the code should go. If not then replace the thermistor suggestedin the manual for such codes.
You can find the ir5570 service manual here.
Aug 20, 2010 | Canon imageRUNNER 5570 Copier
Canon iR5570 Error E000732-001 Can you help me with this code please?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} scanner communication error
Jun 28, 2010 | Canon imageRUNNER 1023iF Black and White...
Er code E00025-0001
BOS BAGAIMANA CARA MENGHILANGKAN EROR E000025-0001
PADA MESIN CANON IR5570?
SUDAH SAYA COBA PAKAI *28* FUCSION-CLEAR-ERR-OK
TIDAK BISA JUGA BAGAIMANA SOLUSINYA BOS
Jun 06, 2010 | Canon IMAGERUNNER 6570 Copier
ERROR E840 FOR CANON IR5570
This is a fuser shutter error. Subcode 0001 is that the shutter is not being detected by the shutter sensor. 0002 is that the shutter is moving but on/off detection timing is off. When the copier is powered up you should here this shutter trying to find the home position. If the error occurs then, most likely the sensor is bad or unplugged. Have you done any fixing repairs recently and got this error?
Nov 04, 2009 | Canon imageRUNNER 5570 Copier
Error code E0540-8002 on canon ir5570
hello sir; The error code you display, it means the finisher top tray lift motor, sensor problem, check the sensor see is on right place.
Mar 17, 2009 | Canon Office Equipment & Supplies
Canon imageRUNNER 5570 Copier Logo
1,531 people viewed this question
old marine
old marine
