Question about Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony kv-34hs510 stuck in standby - Sony FD Trinitron WEGA KV-34HS510 34" TV
  • 10 Answers
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If
the timer/standby indicator is blinking, this could be an indication of the
problem with the unit. The diagnostic blinking will occur automatically with no
action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses for 3
seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the
number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault is
corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on Apr 25, 2010
BMW Rider
  • 232 Answers
SOURCE: kv-34hs510 standby light blinks six times over and over
Doorman45, common failure for your model, replace both IC`s with the following number stamped on the top of the IC,
MCZ3001D, the new & improved version ends in DB but I have installed the originals several times with no call backs, good luck
Posted on Nov 27, 2007
  • 106 Answers
SOURCE: Sony FD Trinitron WEGA KV-34HS510 34
  • Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board). This may help !!
Posted on Mar 24, 2009
SOURCE: Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Posted on Jun 01, 2009
  • 178 Answers
SOURCE: have a kv-34hs510 wega that will not come on. red
This is a common failure with this set, it is in the power supply, switch mode regulators in the ps need replaced, the repair would be typically cost around 200 - 250 from a shop to repair. if you want to fix it yourself i can get the part numbers just post back and let me know if you are a do-it-yourself er.
Posted on Sep 25, 2009
Benimur
  • 6966 Answers
SOURCE: Sony Wega KV-34HS510 standby blinks
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Posted on Aug 19, 2010
Sony Wega KV-34HS510 standby blinks 7 times in red
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony Trinitron won't turn on
this is the (OVP) over voltage protection,the unit goes into standby mode,there is a problem in power supply circuit,you need a ohm meter ,check T603 & R672.......you can get parts at Encompass Disturbution #1-800-638-3328 hope this helps.good luck
Feb 15, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Changing wide screen
possible on a cable box, if so hd cnan are automatic on certain hd channels
Aug 10, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Apr 11, 2009 | Televison & Video
Sony FD Trinitron WEGA KV-34HS510 34" TV won't turn on. Standby light blinks 7 times
Feb 20, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony FD Trinitron WEGA KV-34HS510 ... does not power up.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.This may help the solution or let no what is wrong!!
  • Jan 16, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
    I have a Sony Trinitron KV-34HS510 with a blinking standby light but I cannot turn on the TV. It sounds like it wants to power up but it won't. Is this a relay problem or a sensor problem and how do I fix...
    Please post the blink count of the standby light. That will indicate the circuit in which the problem was found that triggered the "protect" mode. Further details can be provided once that count is available.
    Thanks,
    Dan
    Dec 04, 2008 | Sony KV-32S45 32" TV
    Sony trineton KV-34HS510
    let me know how many times standby light flashes. this info will help me to assist you to resolve tv problem.
    Sep 05, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
    Sony FD Trinitron WEGA KV-34HS510 34" TV Logo
    1,930 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
