Question about Kenmore 774 sq. in. Cooking Area Gas Grill 15337
The handel to lift the top of our grill broke off it had lights you could turn on at each end. It is a Kenmore but we have no papers on it so I don't know the # of it.
    President:
  • 512 Answers
Grill will have a small plate with all grill info on it. Model, btu's, serial number, etc. Then go to sears.com and you can find replacement parts for kenmore grills.
Posted on May 03, 2010
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
How to replace nissan murano 2011 front driver side turn light
Lift hood, remove grill plastic screws on top, jack car left hand side, remove corner screw on end of bumper, undo lower splash shield screws, slide bumper away from car {about 4 inches}, remove,top bolts on headlight and lift out, the is a locating slot that you will need to manipulate it from, assembly is the reversal. good luck.
Oct 20, 2013 | 2007 Nissan Murano SE
On a kenmore 5 burner grill when lighting the fourth burner all of the grill shuts down, regardless of which is the fourth burner?
Sounds like the pressure regulator is malfunctioning. Try disconnecting your gas line. Open/Close all burners then reconnecting gas. If propane, don't turn bottle off before burners. Always turn burners off first, then bottle. then bottle on before burners. This primes the regulator to the proper pressure.
Jan 09, 2012 | Kenmore Grilling
How do I lift the stove top to turn off pilot model # FGF366DCB?
there isn't a pilot in it,it has an electronic spark module in it.what problem are you having?when you turn it to lite it you'll hear a clicking sound,that's the sparking that lites the gas just like you're gas grill.if you want to remove the top you have to remove the two phillips screws out of each burner head,sometimes they don't come out and you have to drill them out,if the burner isn't shutting off the gas valve could be broke or the knob could be broke,if it's clicking just unplug it and you can lite the top burners with a match or bbq clicker to lite them until you get it fixed depending on what problem you are having.if the gas won't shut off by turning the knob you'll have to shut down the gas at the valve that feeds the stove.but like i said if you want to lift the top you have to remove all the screws in the burner heads.hope this helps you out.http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Range-Parts/Model-FGF366DCB/1428/0124002?pathTaken=&prst=0&shdMod=FGF366DCB go to this site and you can look up your machine.
Sep 03, 2011 | Frigidaire Ovens
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
I have a Pfaff 7570 and I would like to adjust the thread tension. Most of the time when embroidering it is set at 1 or 0...and never higher than 3-4. Also I can't get the light bulb end out. it broke...
Lift top cover. remove top cover (flat springs on each end of cover - move one with your finger and top will come off. Lift handle. Look to right of handle end over the head. There is a screw there. LOOSEN screw and front cover will slide away from head. Bunch up a paper towel or napkin and press into broken bulb socket and turn same counter clockwise to get bulb socket out. Good Luck!
Jul 01, 2009 | PfaFF Creative 7570
Removing Head lights
If this is a 1996 model. When you lift the hood you should see 3 or 4 screws in the top of the grill. Take these out then the grill should tilt forward. then pull up to release from the tabs on the bottom. The headlights have 3 or 4 nuts behind them under the hood. When you remove these the headlights and turn signal will pull out towards the front. You will have the disassemble them off the truck. You will have to remove the battery also.
Mar 13, 2009 | 1996 Ford F150 Regular Cab
My Grill will no longer lift
I just had mine apart today because the cable broke. There is only one damper, in the left side where the pedal is. The other side is controlled by a cable that is strung on rollers. My cble broke so i had to replace it with one from a hardware store. I noticed that everything needs to be oiled for the system to work good. The gas strut/damper is inside of the lift tube. I would think it could be matched up with one from an automotive store. Autozone has a pretty good selection of them. But, The strut that is in the grill has a special end on it to fit the lift tube, you would have to somehow fabricate a new end or try to cut and weld or braze the old one onto the new strut. I have not had the strut problem yet because when I store the grill I leave it in the up position. this takes the stress and pressure off of the strut. Hope this helps.
Sep 26, 2008 | Thermos Grill2Go Fire+Ice
Older Style Top Loader Washing Machines
if the image on your posting is correct and model number 2 there is no belt washer is driven by coupler between motor and transmission it could be broke if washer drains but won't agitate or spin ..remove end caps on console by pulling up remove screws on each end of console lift console up and roll back remove clips on each corner and lift cabinet forward and off remove pump clips remove motor clips by removing screws first drop motor remove coupling and replace
Aug 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 774 sq. in. Cooking Area Gas Grill 15337 Logo
65 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
paulcarew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
