Question about Samsung SyncMaster 740N 17" LCD Monitor
MONITOR DOES NOT COME ON,ONLY AFTER VARIOUS TIMES OFF SWITCHING O
Monitor does not start up immediatly on cold start
  • Samsung Master
  • 1,684 Answers
Slow displaying displays is a common symptom of a failing power supply board. Parts called capacitors will start failing which causes the power supply to not stabilize the voltage and power the monitor. The monitor power board keeps resetting and trying and finally it will stabilize and you get a picture. If you checkout this article on our web site: http://www.ccl-la.com/blog/index.php/capacitors/ this will give you information about what needs to be replaced with pictures and specifications. The repair will require soldering the new parts onto the power supply board. If you do not want to do the repair yourself we do offer a repair service, most repairs run $30-35 plus shipping. Information can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Apr 25, 2010
Computer monitor cycles on and off when the computer boots up but seems to have constant power when just turned on
The boot process goes through various display modes. Each time it switches, the monitor has to set itself for that mode. This causes the monitor to flicker while it's adjusting. Perfectly normal operation.
Sep 02, 2014 | Acer Computers & Internet
Refresh rate will not switch to 60 hertz from 59 hertz. Hence my hdmi connection from my desktop to my display keeps showing "out of range" error
turn off the computer restart it and press F8 immediatly before start and keep pressing untill menu appears then highlight on" enable vga mode" and press enter your problem will be solved
Apr 05, 2010 | Westinghouse 25.5" Widescreen Flat Panel...
03 ford powerstroke fuel lk. on top of engine, behind the fuel filter housing,fuel sits on top of valley area. can't see any lk. must be slow. cleaned area, can't see any lk.
It ended up being the fuel filter housing drain / shut-off valve. waited for the engine to cool overnight/started engine & rechecked immediatly before engine started warming up & it leaked immediatly. It apparently was a cold only leak. thanks for your attention..
Jan 07, 2010 | 2002 Ford F250 Super Duty SuperCab
I cannot get rid of OSD
sylvia2265, My best guess is that the unit's power supply (internal) is bad or at least a bit on the "Almost Bad" condition. When "strange" and "unexplained" things start to occur with a CCFL back-lit LCD monitor, I would immediatly suspect the units "switch-mode-power-supply/ CCFL inverter" printed circuit board as the first place to look for problem. You or someone will need to inspect the printed circuit board for component defects. If Westinghouse warranty not solution, then try to locate local tech that knows forwards and backwards all there is to know about common problems with SMPS/inverter circuits in LCD monitors and TV's. 12fixlouie
Dec 30, 2009 | Westinghouse Electric L2210NW Monitor
Brightness controll keeps appearing on screen
zxroche, If unit is LCD w/CCFL backlighting I would first suspect the SMPS as the failing culprit. When very strange things start to occur on the LCD screen, I would immediatly suspect the "switch-mode-power-supply" and check it out with meter and oscilloscope for proper operation. 12fixlouie lmistyrel @ aim. com
Nov 24, 2009 | BenQ Computers & Internet
HARD TO START ENGINE WHEN IS VERY COLD
I read the other two solutions top your problem and I have to say, some people should not give advice, because the advice they are giving is not worth anything. NOW, let me tell you what is wrong with your car. You have a defective IAC (Idle Air Control) value. The IAC value (sometimes called a cold start value) is used as a means to quickly start your car when it is cold outside. Replace the IAC (easy to do) and your problem will be solved..
Oct 28, 2009 | Cars & Trucks
Fisher & Paykel GW703 wont stop!
It sounds like your machine has been programmed to automatically run through the various cycles continuously. Most likely in error.
Oct 07, 2007 | Washing Machines
Samsung SyncMaster 740N 17" LCD Monitor Logo
310 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
