Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My gx95 riding mower will not start...
It does turn over and when I jump the switch, it will start.....I put a new switch on and no deal....could it be the seat safety switch?
  • 376 Answers
SOURCE: Poulan Riding Mower won't crank, battery OK.
Forget the safety switches for now.The first thing I would check would be the fuse. It will be located on the battery side of the solenoid. Follow your positive battery cable to the solenoid. There will be a small red wire coming off of that post with an inline fuse. If the fuse is good, check your solenoid. There are two wires plugged into spade terminals at the bottom of the solenoid. Unplug the one that is insulated, the other one is a ground. Hook a test light from that wire to ground. When you turn the key to start (with the brake pedal held down), it should light. If it lights, your solenoid is bad. If not, then you can start looking at switches. Probably will be one of the two. Hope this helps. Dwain
Posted on May 21, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
SOURCE: Murray Riding Lawn Mower won't start or move
Did you check the fuse?
Posted on Jun 24, 2009
  • 33 Answers
SOURCE: disabling pressure switch under seat on riding
First off, the safety switch is there for your safety, if you disable this feature and fall off of the tractor you could possibly be "mowed" over by it, but if you must....I assume that you know where the switch is, so there are two types of switches possible, you are either completing the ignition circuit by making the switch (seated) in which case you will need to pull the plug off and jumper the pins with a piece of wire and secure the wiring with a strap tie so it doesn't flop around (if no plug, simply cut and splice together the two wires) OR, more likely you are opening an ignition ground out circuit by making the switch in which case simply remove plug from switch and secure (or cut one wire and cap if switch is hard wired). So first pull plug off of switch and if that doesn't work you will need to jumper. Good luck
Posted on Apr 02, 2010
  • 760 Answers
SOURCE: scotts 2554 mower wont start
Does the engine turn over?. The pto switch you mentioned is this the POWER TAKE OFF switch? In other words starts the deck? If so, it must be off when starting the mower. Any internal combustion motor needs fuel and spark. If it cranks over check for a spark. If no spark determine if it has points or breakerless ignition. Also check magneto coil. If you have spark then, be sure fuel is getting to the carb. With today's gasoline, you can't let it sit in the tank long without adding an additive. If the PTO switch you described, is blowing a fuse, then it cold be a bad coil on the clutch. You can disconnect this coil to see if it stops blowing the fuse. you didn't mention if it is a Kohler or BS engine. Try this link:http://manuals.deere.com/cceomview/OMM141871_D0/Output/OMM141871_D014.html#34531
Posted on Jun 30, 2010
What will not let my mower start?
try the brake switch unhook and jump if does replace swtch that how you check the safty check the one under seat leave un jump then try jumped check al like this you will find bad switch 3 to 4 switchs all lawn mowers
Aug 26, 2014 | Garden
I have a John Deere D130 riding mower that will not start. When I turn the key I get nothing. When I jump from the battery + to the solinoid the motor cranks. I have replaced the seat switch, the brake...
check out all the safety switches , they make a circuit on closed , = make sure your safe not in gear etc , put a shunt direct and make sure you have cuircuit
Jul 19, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
Why won't my riding lawn mower crank over?
Hi if you have got it cranking remove the plug and check for a spark the plug must be earthed to do this if you have a spark it must be fuel pore a small amount in top of carb make sure ign is switch on hope this helps.Ron.
Jun 20, 2014 | Craftsman 420cc 30 6-Speed Rear Engine...
Yardman mower
Try this. Disconnect the one single wire going to the solenoid. Use an ohm meter to see if there is 12 volts DC at this wire when you turn the key switch in the start position. If you have voltage then your solenoid is bad and needs to be replaced. If you dont have voltage, check the safety switchs for proper operation.
Apr 27, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Put new battery in 20 hp 42 in cut Yard Man Riding mower but cannot get it to sart
use jumper cables and jump it dirrect to the starter if it cranks check the safety switches
Apr 20, 2012 | Garden
Engine will not turn over
If you can jump and start it, then ignition switch or circuit is faulty
Sep 10, 2009 | Garden
No fire to sparkplug
you may not be getting electricity from the battery. you can check this but it is kind of dangerous. you stick a metal object in the spark plug cap and hold onto the other end. crank it over just a little bit and if you get a small shock then it works. you may just need a new spark plug.
Jun 20, 2009 | Garden
Murray Riding Motor Running but not Starting
does it have spark & gas let me know at wadembly@aol.com thanks,wade
Jun 07, 2009 | Garden
Mower won't start
May 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
169 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
