Question about Kenmore 22642 Top Load Washer
Oil on floor under washer
Older model GE top load washer, with oil under it. Is the problem a costly one to repair. Should I replace washer?
Bar
  • Felt Mar 24, 2008
    Will take you advice, thanks so much for saving us some money.
    You suggested Whirlpool, what about Maytag or LG?
    Thanks
Thank tou very much you were of great help.
Posted on Mar 27, 2008
    President:
  • 331 Answers
Oil is generally not a good sign. It means that the tranny seal is blown OR it means that the tub seal is bad which allows water to enter the tranny (water is heavier than oil... if water gets into the tranny it will displace the oil and force the oil out)
This being a GE? I'd wager that a tranny job is in order. If the machine is less than 5 years old it's under warranty so you'd call GE at 1-800-GE CARES. If it's more than 5 years old? Your washer is no more than a boat anchor. Get a new washer, preferably a Whirlpool. The repair cost for a new tranny will out-weigh the value of the machine.
Hope this helps.
Posted on Mar 23, 2008
  • Tracy Farrell
    Tracy Farrell Mar 27, 2008
    Felt,
    Up until a couple of years ago, Maytag was actually "Maytag". Whirlpool bought them in October of '05, so all the new Maytags are actually Whirlpool machines.
    LG's are good until they break down. Servicers are, by and large, staying away from them because LG isn't making their parts available and tech support is impossible.
    So, until things change in the market Whirlpool is, in my opinion, still the best way to go.
    (Sorry to have given you the bad news about you GE, though)
GE Top Load Washer WLSR2000G3WW~leaves oil residue on clothes and bowl
If it is grease that is in the tub then the trans is shot. Thats the only part that would result in this. Very pricy part but if you want to order it go to marcone.com with your model number and you can get the parts. I would not recommend fixing this, costs almost as much as new unit.
May 22, 2012 | GE WBSR3140DW Top Load Washer
I am finding oil under my washer.
your transmissions lower oil seal is leaking and needs to be replaced,if the top seal goes,you will start to see oil droplets on your clothes when washed and this is called "wash-back"
Jan 01, 2011 | GE WBSR3140DW Top Load Washer
Hi! GE top load washer model number wwse5240 is leaving grease stains inside the machine after laundering and of course on clothes. Not sure how old this machine is.
Your transmission is leaking oil. It's probably 10 to 15 years old for the transmission to be leaking. It can be replaced but it's not a small job. Part 320 in this diagram is your transmission. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5224109&diagram_id=22255027#d22255027
Jan 30, 2010 | GE WDSR2080D Top Load Washer
My washer has had streaks of grease coming from under the agitator. It is getting on my clothes and I cannot remove it. I took the agitator off and the inside of it is coated with this grease (black,...
GE style washer Common problems: - greeseOil on the clothes or floor. In most cases a new transmission will be required. You can rebuild the Trans for oil on the floor, but I find it best just to replace the transmission with a rebuilt one = less problems and faster repair. I have a parts breakdown of the old style transmission here. How to access the washer information.
Change transmission in GE washer-Take transmission out for repairs. - Unplug washer. Remove agitator from washer by pulling straight up on it, some agitators have a bolt under the cap, remove cap and look for a bolt first. Remove the agitator bearing from transmission hub. Get top up by pressing on 2 clips located about 6 in in from side between top and cabinet. Putty knife or flat blade screwdriver works well here. Take the filter flow tube off. Lift top. Remove three bolts holding basket to hub, and use a 12 POINT 1/2" socket to remove the bolts. Lift basket out of washer. Remove the two clamps holding the black boot to the tub and to the transmission. There are six bolts holding the transmission in the washer. Remove the bolts and lift transmission out of the machine.
To replace bottom seal - Turn trans. upside down in a bucket, put in vice, etc. Remove the nut holding the drive pulley on. Take drive pulley off. You can now pry the oil seal out of the trans. bottom and replace. If you wish to put the proper amount of oil in the trans. you will need to remove the bottom cover. Unless you have lost a great deal of oil, I would bypass this. I would estimate the oil loss and put in a lesser amount through the opening where you will be putting the new seal. When replacing the pulley, do not turn the nut holding pulley on. Hold nut stationary and turn pulley in the direction that nut will tighten. This will keep you from separating the hub, torque spring, and drive collar in the transmission. If you see evidence of water in the transmission, my recommendation would be to purchase a rebuilt transmission and repair in that manner. You may wish to do this regardless of the condition of the trans. You will receive a one year warranty with the rebuilt trans. I have a parts breakdown here for the transmission if you need it.
Usually you have to only add a little oil to replace what was lost...not much...really!!
The oil used is a Non-detergent, Gear oil approximately 90 weight. The main pulley seal is WH8X281 and foam nut seal is part # WH2X671.
Jul 13, 2009 | GE WPRB8050D Top Load Washer
Transmission noise
Washers normally don't have much grease in them at all....the transmission is full of oil....which on GE washers often gets dumped onto the floor.Remove power, tilt the washer back and check on/around/near the large center pulley under the tranny....often the belt and pulley throw the oil around inside the cabinet.
Some of the oils they use are a synthetic oil....acts a little diff than some other oils....sometimes if water gets into the tranny the oil can change foamy or black due to the moisture.
Feb 10, 2009 | GE WHRE5260E Top Load Washer
My washer is leaking grease or oil on the floor under the machine
Hello and welcome
You said, My GE washer is leaking a tan colored oil underneath the unit. I suspect it's the gear case leaking. How difficult is it to replace the gasket or seal. I like to fix things and have tools. If the gear oil is leaking this usually means the transmission is shot and on it's way out. It is not cost efficient to have it replaced. 99.9 % of the time you throw it out and buy a new washer.
For the cost of the Transmission and the labor.
you can buy a new washer.
How old is the washer ?
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Feb 09, 2009 | GE WBSE2090A Top Load Washer
Hotpoint washer top loading has oil dripping on the floor
The only place oil can be coming from is the transmission. If left as is, leaking oil will eventually result in full transmission failure. Yes, you can replace the transmission, but the repair is costly and moderately difficult. I'd save the expense and put the money toward a new machine. Please don't bother rating this solution as anything but a FixYa will drop my rating.
Oct 28, 2008 | Hotpoint Washing Machines
Grease or oil on floor under washer
try putting a new coupler in it its between the motor an the transmission
Mar 22, 2008 | GE WNSE5260D Top Load Washer
Oil on floor underneath washer
jeffnew The oil which you see on the floor is coming from the gear case. The gear case is not repairable and it has to be replaced. If your washer is less than 1 year old do not wait and call Whirlpool - it is under full warranty. If your washer is between 1 to 5 years old, then the part is still under limited manufacturer warranty but you are liable for any trip and labor charges. It could be much over $200.00. If you are handy and willing to save money, you can buy the part for less than $150.00 and replace it yourself. In that case, I can find the best deal for you and help you with step by step instructions. Gendos...post back
Feb 09, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Grease/oil under washer
Hi, there. Get some one to fix that leak ASAP. The lack of oil will ruin your machine's transmission and/or motor. If you've noticed that your machine runs louder than it used to, then ***stop using it*** until you get the leak repaired. I kept using mine and when it stopped working I couldn't get the parts (a transmission) so I have to get a new one.
Nov 30, 2006 | GE WDSR2080D Top Load Washer
Kenmore 22642 Top Load Washer Logo
187 people viewed this question
Sal De
fordexpert
Robert Rankin
