Question about KitchenAid KUDS01IJ - Multiple Color Dishwasher
The child lock is on and I can't remember what buttons to use to turn it off......
    President:
  • 949 Answers
Press and hold the 'Heated Dry' button for 4 seconds. it should turn off. If that does not work let me know.
Posted on Apr 25, 2010
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
Jun 07, 2013 | Televison & Video
Child safety lock feature is on. how do you take it off
im not sure if your model of dryer but here is some instructions
Child lock
When activated, the child lock prevents the dryer from being operated by locking the control panel functions.
The dryer can be turned on but not started. The "Child lock" indicator will flash.
The door can be opened.
To activate the child lock
1. Make sure the dryer is turned off and
the door is closed.
2. Press and hold the "Anti-crease" and "DRYNESS" buttons at the same time, hold until step 5.
3. Turn on the dryer with the "On/Off" button.
4. Press the "OPTIONS" button 3 times. 5. Release the "Anti-crease" and
"DRYNESS" buttons.
The "Child lock" indicator will flash and the dryer is now locked.
6. Turn off the dryer using the "On/Off" button.
To deactivate the child lock Repeat steps 1. to 5.
The "Child lock" indicator will go out. The control panel is now unlocked.
Dec 15, 2012 | Bosch Washing Machines
I have an AKAI TV CT-2877A (M) and the "child
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching regular TV ....
  1. Bring Up TV Menu ; Power on the television with the activated child lock on. Push the "Menu" button on the remote control. A series of features appears on the screen, ranging from the overall TV functions to the video display and the audio setup features ,Choose "Options" and a new menu appears on the screen. From the new menu select "Child Lock." The exact setup selection is going to vary slightly, although the child protection is always referred to as either "Child Lock" or "V-Chip." The V-chip is the actual chip built into the television that blocks out certain television programming.
  2. Try a "factory reset" action... This should be somewhere in the TV menu system. However Please note that will clear everything, so you may need to re-program every things..the channels etc.
  3. Hold the lock key in the remote for few seconds . you will get the lock tool bar . you can unlock it there
  4. Hold the display button on the remote for 10 seconds.
  5. As a The last solution which is common for all TV sets..
    • Try to find the User manual for your television. The section In the manual about how to set the child lock feature will also explain how to unlock it.
    • Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A commonly used code is "0000."
    • Unplug your television for at least 1 hour . The internal memory battery of the TV is what helps remember what your code. When TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code back to "0000 " again...
if the problem still continues you have to email to : http://www.akaiusa.com/
Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Jun 26, 2011 | Televison & Video
How do you turn off the child lock on a RinnaiRCE229H natural gas Heater?
Basically hold in the child lock button for two seconds. If the child lock was activated and you then turned the unit offt the child lock remains set and will stop you turning the unit on. To deactivate, make sure you have the power lead pluggeed in and turned on. Before you depress the ON/OFFbutton, hold in the child lock button for two seconds. This will deactivate the child lock and allow you to turn the heater on.
Here is a link to a users manual, check out page 11.
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/150.pdf
Aug 15, 2010 | Heating & Cooling
Model # KUDM25SHBL1 Child lock is on and can't remember what button(s) to use to turn it off
Press and hold the 'Energy Saver Dry' button for 4 seconds to either turn on or off the child lock
Apr 25, 2010 | KitchenAid Dishwashers
My dishwasher has a child lock and i cant turn it off. is there a way to reset it?
usuall ther are two button that you need to push in order to activate and deactivate the child lock.look for a small line that connects two separte buttons witha smal child face or hand and press those buttons at the same time for 3 to 5 seconds.this should unlock this feature
Feb 07, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
My kenmore elite washer just stop working. My mom
When activated all the buttons will be disabled and a child will not be able to alter any wash programme or option settings. Once selected this feature remains activated, even when the machine is ‘off’.
To use this feature press the ‘Child Lock’ button and hold down for 2 seconds. The child safe icon will begin to flash. When the icon stops flashing the feature is activated. If any of the control buttons are pressed, the child safe icon will flash and the machine will bleep 3 times: no alterations to the control settings will be allowed. If power is interrupted, at any time, pressing any button will reactivate the child lock feature.
To deactivate this feature hold the ‘Child Lock’ button down for 4 seconds. You will then hear a bleep and the child safe icon will go out.
If this is not the problem than turn off the AC power for 30 mintes and then power the machine back on an everything should be OK to use as long as no Error Codes are displayed.
Nov 13, 2009 | Kenmore Elite 45986 Front Load Washer
How to turn off child lock without remote on LG tv.
hi..To do a Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit....
ur problem will be solved.. rate me!!!!
thank u
Apr 10, 2009 | Televison & Video
Child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
Jul 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Child Lock continuously flashing
the solution is to change the electronic control.....cost 110$
Sep 02, 2006 | KitchenAid 24 in. KUDS25SH Built-in...
KitchenAid KUDS01IJ - Multiple Color Dishwasher Logo
59 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
