Question about York Yankees Bedding MLB Comforter
How do I wire an accessory blower into the air handler so it comes on with the main blower?
  • 1,284 Answers
Hi, you can check out this site, it might be of great help...
http://www.luxaireac.com/PDFFiles/035-14502-001-B-1208.pdf
Take care
Posted on Apr 25, 2010
What causes my AC to sometimes stop cooling & can hear a buzzing from the motor?
The blower motor probably needs very badly to be cleaned, lubricated, or replaced, Michael.
Aug 06, 2014 | Heating & Cooling
Air handler blower/fan wont come on.
open it up and vacuum and blow out the fan and other areas
Feb 28, 2014 | Amana ASPF183016 Multi-Position, Air...
I need to replace my blower motor on my air handler
Turn off power to machine and have a 5/16" or 1/4" nut driver handy take off front door of machine. Take a rubber coated Screw driver and place across the terminals of the Capacitor to discharge any stored electricity. Cut wires for blower Black, Red, white, two browns one with white lines on it probably. Look inside machine and locate where bracket holds squirrel cage to air handler and there you will find either 5/16" or 3/8" screw remove pull bracket out. Then you will need a 1/2" socket and a crescent wrench. Remove screws for motor bracket that is attached to squirrel cage. Also you need to loosen the set screw that attaches blower wheel to motor. Apply wd-40 if needed to remove blower wheel from motor. Then install new motor on the flat part of the shaft comes through wheel attach set screw to motor shaft at that position. Install new cap that goes with motor. place entire housing of motor back into air handler and then follow wires that where previously cut back to either relays, sequencers, or fan timer board located in top section of air handler. Tighten everything up and turn power on and make sure air is coming out of vents. Then your good to go.
Apr 29, 2011 | Heating & Cooling
How to adjust blowed speed on a rheem air handler
There are probably six wires coming out of your air handler blower motor. There are 2 brown wires which are capacitor wires, one white wire which is neutral, and probably red,black, and blue. Look behind the door of the air handler to see the wiring diagram. They should have the color coded speeds marked on the diagram. There is probably some sort of control board that the blower speed taps plug into. By changing these wires around on these taps you can adjust the speed of the blower motor.
Jun 05, 2010 | Heating & Cooling
I have air handler nordyne the blower dont stop
check thermostat make sure fan is not set on on, if thermostat is right the fan relay may be stuck closed or thermostat wire can be touching
Oct 27, 2009 | Heating & Cooling
Is EDF5 required to have intermitant running of Fantech HR 2005R?
The SHR2005R will turn on the furnace Blower if the furnace is not running to circulate the fresh air. The reason the furnace will not trun on the HRV is, the purpose of the HRV is continuous Ventilation in your home. It should not be turned off when your furnace is not running. That why Fantech has not design the HRV's to run that way. I hope this helps.
Jan 18, 2009 | Fantech EDF5 Intellitek 5MR Control for...
Connecting electronic air filter to furnace fan
You may need a "current sensing relay" to clip around the neutral wire on your blower.
Run the 120v power to the main power (the power switch- hot,neutral and ground) . Run the Hot wire through the "Current Sesing Relay" wires to the EAC unit's 120v. power input. The unit will only run when the fan is on.
Hope this helps,
Matt
Dec 31, 2008 | Goodman Heating & Cooling
Air handler circuit breaker
WITHOUT ANYTHING TO LOOK AT I WOULD SAY HE CONNECTED HALF THE LOAD TO ONE OF THE PHASE WIRES AND THE OTHER TO THE OTHER PHASE WIRES , PHASE WIRES MEANING 120/240 SINGLE PHASE , SO IF THAT IS THE CASE TAKE THE WIRES HE HAS BUNDLED TO ONE PHASE OR ONE TERMINAL ON THE BREAKER AND THE OTHER TO THE OTHER TERMINAL OF THE BREAKER IN SOME CASES IT IS NECESSARY TO CONNECT THE WIRES WITH CONNECTOR, APPROVED TYPE AND THEN TO THE BREAKER TERMINAL ,THIS JUMPER SHOULD BE RATED THE RATEDING OF THE BREAKER YOU ARE INSTALLING ,GOOD LUCK
Nov 19, 2008 | Gb Electrical 1 30 Amp Ground Fault...
Ruud air handlers
Check the name plate amperage on the air handler. The air handler only has the blower motor as its main current draw. #12 wire is rated for 20 Amp service. If the amp draw by the unit supplied by the disconnect is under 15 amps it should be fine (but) once again check the name plate for ampacity rating.
May 27, 2008 | Ruud UBHC Air Conditioner
York Yankees Bedding MLB Comforter Logo
35 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
obsteiner
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
