Question about Sony KV-20S42 TV
Tv will not come on. stand by light blinks no
Tv was working fine @ brother's house moved it to my house and it will not come on.no picture no sound. standby light blinks.
  • 10 Answers
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If
the timer/standby indicator is blinking, this could be an indication of the
problem with the unit. The diagnostic blinking will occur automatically with no
action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses for 3
seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the
number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault is
corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on Apr 25, 2010
Sony TV WEGA wont turn-on. stand by LED
line o/p transformer &transistors are gone .. any service person can replace them
Apr 22, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Standby/stereo light blinking no picture or sound
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
Aug 31, 2008 | Sony KV-36FS100 36" TV
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
No picture or sound
Sounds like you have bad solder connections on the 5 and 9 volt regulators on the power board. They should be marked 7805, 7809, and possibly 7812. The 78 on these IC's mark that they are positive regulators and the other 2 numbers signify what voltage they are. Very common problem.
Feb 18, 2008 | Sony KV-35S66 35" TV
No picture or sound
The most common reason for no power on your set is a shorted hori output NTE 2353 , and right behind that part is a 1200pf 2kvolt capacitor check it also check out STK-392-150s one of them may control part of start up.
Dec 23, 2007 | Sony KV-35S40 TV
Dopped tv, worked fine, now not picture but has sound
Most drop damage is in/around the area of the flyback xformer.My Motto==PVAT! With magnifier examine PCB for crack(s).May still be fixable.
Jul 31, 2007 | Sony KV-36FS100 36" TV
Sound fine, but absolutely no picture?
it seems that your tv has a problem in horizontal circuit (with sound but no pictures). since you moved your tv from one place to another, the tv might have shaken causing to loose some soldered components particularly in horizontal circuit. if u have exprience in this stuffs, try to resolder the circuit, if not, bring it to a service technician.
Jan 09, 2007 | Sony KV-36XBR250 TV
Sony KV-20S42 TV Logo
360 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
