Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer stoped running and wont drain
There is power to it but itjust stoped
  • 5,911 Answers
Check you lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. If the model number you posted this question under is correct, the part number for a replacement switch is 8054980.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If you would like to purchase a Repair Manual to assist you with all your repairs, repairclinic.com has one that you can order on line for about $20. The part number is 1170635. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Posted on Apr 25, 2010
Washer wont drain or spin
I don't have a code book on this washer but sometimes they list some codes in owners manual. I think the code is drain problem..u will have to take the panel off locate the pump there should be a cleanout that might be clogged. the other day I found two kids socks in a clean out and it stoped it from draining. that is where I would look first, I hope this helps
Apr 08, 2014 | Maytag Neptune MAH5500B Front Load Washer
Washer stops mid cycle
ur drain is stoped up. the drain emptys into the sink plumbing...
Oct 17, 2013 | Admiral Washing Machines
My whirlpool washer seems to be letting water back flow from the drain line.
sounds like the drain line is too low it needs to be higher than the water level when running a full load...you can check this buy filling with water and stoping the cycle and see where the water stops draining im sure it will stop at the level of your drain line in the back of the washer. the drain line in the back of your washer should come out of the bottom of the washer and then go up to a drain pipe..if its lower than the full water level of the washer then gravity will take over and drain the water... i hope this helps
Sep 09, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Wont drain
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
May 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag top loadind washer. Won't stop filling up.
Make sure your drain hose to the drain pipe is higher than the water in the tub if not it will keep running and going out the drain.
Also try taking the hose off the level switch and blow in it to be sure it's not stoped up. If is it won't let the level sw cut off. air should go through it. Good luck
When you unpluged the power and it ddn't keep runing the water valve should be ok.
Mar 25, 2010 | Maytag PAV2300 Top Load Washer
Casio tk 3200 cash register as stoped responding
Hi.
Try a flag clear:
Turn key to PROGRAM mode.
Turn power off at wall.
Hold RECEIPT FEED down - keep your finger on it.
Turn power on at wall.
Wait 5 seconds, then let go of RECEIPT FEED.
You should see "FFFFFFFFFF" on display.
Press SUBTOTAL.
Now turn key back REG mode and try it.
May 08, 2009 | Casio Parts Cash Register PC Desktop
The washer was running and it stoped, it didnt drain and the door is locked.
press/hold stop/clear
then select drain/spin
press start
allow unit to complete cycle, door will unlock.
Feb 17, 2009 | Kenmore 43142 Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Draining
if you select drain spin and you hear the pump running then check all the hoses for blockage if you dont hear the pump running then make sure your door is locking
Jan 19, 2008 | Maytag Neptune Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
