Question about Bosch Ovens
My bosch oven HBN 2551 is tripping mains. I tried
My bosch oven HBN 2551 model is tripping mains. I tried bottom and top heaters separately; the same thing happens. It takes about 1 to 3 minutes of heating before it trips. What could be wrong? Thanks
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
  • 1462 Answers
SOURCE: Main oven tripping the fuse
probable fault to earth of circular element - gets worse when element hot. you will need a megga to confirm this.
Posted on Jul 06, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 1462 Answers
    SOURCE: Main oven problem
    I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
    Posted on Sep 22, 2008
    barkencoa
    • 3463 Answers
    SOURCE: SMEG DO4SS-5 double oven not heating up
    If the fan is running, then it is safe to say that the oven element has gone.
    Replace with a new one,(element that is).,
    Plz rate this solution.
    Thanks.
    Posted on Dec 15, 2008
    Why wont fan turn off after use in oven bosch model hbn 13n5,1b
    It should turn off after a while. The fan is actually the cooling of the case, it runs longer if I have used a higher temp setting. If it does not stop after app. 20 min something is broken.
    Sep 03, 2014 | Bosch Ovens
    Bosch HBN 91 Sticky Fan
    Yes you can oil the shaft...but the problem is within the bearing itself. You might be lucky and only have to oil it once...but chances are your bearing will sieze again...I suggest you remove and replace the fan.
    Dec 02, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
    Bosch hbn 13n5.1b bottom oven temperature control knob not working
    Yes they can be and if your savey they have universal oven switches that do the same thing only much cheaper than OEM parts.
    Apr 07, 2012 | Bosch Ovens
    Its cuts electricity off
    I need more inforamation , dose the top burners work, dose any of the oven work top or bottom , Make model, serial number if you can find it
    Dec 07, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
    Bottom oven not working only fan & light works - top oven works fine
    The ovens have separate heatin elements. Sounds like your bottom oven element needs replacing
    Jun 30, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
    I HAVE A HBN 43M5.OB DOUBLE OVEN AND THE MAIN OVEN WILL NOT HEAT UP AND THE RED LIGHT STAYS ON .THE GRILL WORKS ON THE MAIN OVEN AND SO DOES THE SMALL OVEN WORK.
    Most likely the heater element has burnt out. This is accessible by removing the panel in the back of the oven.
    *** ENSURE POWER TO OVEN IS OFF BEFORE ATTEMPTING REPAIR ***
    Nov 14, 2010 | Bosch Ovens
    INSTRUCTION MANUAL
    you can obtain the instruction manual for this directly from the bosch web site free of charge if it is not listed there try the BSH Home appliances ltd site they are the manufacturers repair service in the UK
    Feb 23, 2009 | Bosch HBN 131560B / 131520 hot-air...
    Bosch hbn s gb
    oven element would need model and ENR No. to supply
    Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
    Dear customer,
  • Test the element
    Jul 08, 2008 | Ovens
    Ovens Logo
    71 people viewed this question
    Top Bosch Ovens Experts
    ashburton
    Oloyede Monsuru
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
