Question about Amana NDE2330AY Electric Dryer
When dryer is turned on squealing noise is heard. possible reasons for?
  • Amana Master
  • 2,128 Answers
There's a few things this could be,check the pulley that the belt raps around,the rollers and also there are glides on the front bulkhead that could be worn or a worn blower wheel.most likely it will be and you can get it in a kit is the belt roller and pulley,but while you're in there check out all the parts and vac out the dryer,you should clean the dryer once a year also clean out the duct that the lint filter slides into and blow out the vent line if it's a long run and check the outside vent every couple of months to make sure it's clear.let me know what you find and make sure the dryer is unplugged before you touch it
Posted on Apr 25, 2010
What might be wrong with my gallery dryer #gleq2152eso it does not heat?
Hi friend, I appreciate your post!
Based off the information you have provided your Frigidaire dryer, GLEQ2152ES0, is no longer heating. I understand that you heard a noise like pennies hitting the drum and then it stopped heating. Some possible reasons to why your dryer is not heating could be that your vent is restricted, an issue with your thermostat, or heating element. I would recommend having a technician come out to diagnose and repair your appliance because with the noise you heard he may need to disassemble the dryer. I hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire Dryers
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
There is a squealing noise when I turn the steering wheel.
Possible solution may be a new serpentine belt. When you turn the steering wheel it is an added torque/tension against the belt from the power steering drive pulley. A worn and dry belt may tend to squeal as the extra grip on that pulley is applied. You would have to pinpoint just where the squeal is coming from to be sure the power steering pump is the origin of the noise. There may also be other reasons if its due to a worn out belt, idler and tensioner pulley's could be making noise as well.
Nov 27, 2011 | Hyundai Motor 2002 Elantra
Frigidaire model FDE336RES2 makes a squealing noise and won't turn with a full load in dryer.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Frigidaire Dryers
When the drum spins with a large load of clothes a thumping sound and a high pitched squeal is heard
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 14, 2011 | Dryers
Dryer heats however will not turn, prior to it stopping it was making a loud squealing noise for weeks
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Feb 12, 2011 | Maytag MDE308DAYW Electric Dryer
There has been a squealing noise in our dryer for a while, and now the dryer won't start when I push start. I can hear a slight noise like it wants to start, but it won't.
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 18, 2010 | Kenmore Dryers
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
My Maytaag dryer has a loud intermittent squeal. It will often work for 10-15 minutes with a quiet squieak or no noise, then the loud squeak starts up. I can turn the dryer off, but the squeal immidately...
I think the drum drive belt is slipping because it occurs more with a large load. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 21, 2009 | Dryers
Squealing noise
heatman101
98f
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Amana NDE2330AY Electric Dryer Logo
74 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
