Question about Frigidaire FGF326AS Gas Kitchen Range
Frigidaire oven/broiler will not ignite.
Neither the oven or the broiler will heat. I can see the pilot light glowing but it will not ignite the gas. How can I fix this problem? The gas is on so I know that is not the problem. The unit itself is 8 years old but should still be in wking condition.
catriver
  • 878 Answers
SOURCE: frigidaire oven wont heat?
Wheely, more than likley it's the ignitor. Just check the burner and make sure there are no large holes, rust, etc. Part number is 5303935066. Easy job. Catriver..post back.
Posted on Apr 04, 2007
catriver
  • 878 Answers
SOURCE: FRIGIDAIRE GAS RANGE FGF378WCC
sl, because it't happening to both broil and bake the first thing I would suspect is the temperature probe. You should ohm it out. You can do this either at the board or at the harness connection in back. For the board, remove the back panel, there should be a 8 pin connector to the left of 3 relays. On the harness measure the resistance of the wires going to pins 1 and 2. On the shemantic it shows them being the 2 on the bottom. Should read around 1100 ohms at room temp. If you cant get a good reading on it there, Remove the probe from the inside oven, remove the screws and pull it out until the harness connector comes through, disconnect it and ohm it out from there. I don't think that both ignitors would fail at the same time so Im leaning toward the probe. Catriver.
Posted on Dec 11, 2007
SOURCE: Oven does not heat
I am having the same problem right before the holiday...can this be by myself or do I need a technician??
Posted on Dec 16, 2007
bestdarngood
  • 3037 Answers
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
Posted on Mar 22, 2008
jsrock516
  • 5911 Answers
SOURCE: oven will not ignite, but broiler and stovetop
Most modern stoves no longer have a pilot. The problem is more than likely caused by a bad igniter on the bake manifold. The following link explains igniter types and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Modern stoves are equipped with either a glow-bar or spark type igniter. These igniters do become weak with age and fail. This tends to be more common with the bake feature because it gets used more often. If the igniter is worn to the point that it longer produces the correct current potential or spark, the gas valve will not open and you will not have ignition. This is actually a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. Such a condition would be dangerous and could cause a flash ignition or explosion.
If the model number you have this listed under is correct, you can see an illustration of your stove at appliancepartspros.com. Just type in the model number and look under the "Gas Burner Parts" section for item number 28 (part #AP2014008).
If you have questions, or require additional assistance, please post back and let me know. I hope this is helpful to you.
Posted on Mar 03, 2009
On my GAS stove and broiler work fine but my OVEN does not light. I do not hear the pilot light or spell any gas. Where or how can I check
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 29, 2011 | Frigidaire Ovens
My GE JGBP32GEL Gas oven will not light. Electric pilot does not glow. Broiler work fine.
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 07, 2010 | GE Ovens
I have a Maytag gas over/stove, Model number MGR5755QDW. The broiler heats, but the oven does not. What are the possible causes and how do I troubleshoot?
If you are having problems with the oven, the first thing to do is figure out if you have a pilot light system or a glow bar system.
Problems with the pilot light system.....The flame has gone out, re-light the pilot. The pilot flame will not light - possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's a internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Problems with the glow bar system.....You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works -click here.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Jan 26, 2010 | Kitchen Ranges
Where is the pilot on an old Tappan oven? The top burners work and light, but the oven isnt turning on. There is something under there that is glowing .
That thing that is glowing is your oven igniter. Most modern ovens do not have a pilot light. The way the burner assemblies for the oven and broiler work is by an electric igniter with a gas safety valve. When the igniter reaches a certain current potential, it opens the gas safety valve, gas flows and you have ignition. This is a designed safety feature that prevents free flowing gas from entering the oven without ignition. If you can see the igniter glowing and the oven still does not light, more than likely you have a weak igniter. They do wear out with age and require replacement from time to time. There is a separate igniter for bake and broil. Usually, the oven igniter wears out faster than the broiler because of the frequency of use. the following link explains a little theory about igniter types and how they work. It also explains how to replace a defective one:
This is a very simple repair that anyone can do. just make sure you follow al the steps in the link provided. If you have questions, or require additional assistance, please let me know before you rate the solution. If you need assistance in locating a replacement igniter, let me know also. I hope this helps you.
Jan 29, 2009 | Kitchen Ranges
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Gas stove
The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
Sep 04, 2008 | GE JGRP17 Gas Single Oven
Oven Burner
try this,when you see the ignitor glow use a match and try to light the burner itself BE CAREFUL!! if the burner lights the problem is its clogged or low gas pressure.remove the burner and use brake cleaner to clean the burner AND pilot.if your using propane youll have to do this occasionally.let me know.
Jan 04, 2008 | Ovens
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire FGF326AS Gas Kitchen Range Logo
284 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
