Question about HP Office Equipment & Supplies
F4400 Deskjet MY PRINTER WILL NOT PRINT
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
1.check power supply connection
2.check usb connection
3.check drivers
4.check cartridges
5.check paper
or be more specific
Posted on May 01, 2010
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
I have a HP Deskjet F4400 All-in-one series. Under the icon for it, there is a box that says the printer is stopped. I can click on it and it will say "Start" but below there is a line that...
Hi rjrust958,
The easiest way to correct this problem is by uninstalling and reinstalling the software and driver of the unit. Please visit this link for the updated driver of HP Deskjet F4400 All-in-One Printer series. For additional information on how to uninstall/reinstall software and drivers please visit this link.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | HP Office Equipment & Supplies
HP Deskjet F4400 able to install software on Windows 7 Home Premium 64-Bit but printer will not connect. Printer worked well previously on Windows XP operating system. All connections are secure and the...
Okay, we need to uninstall the printer. Go to Devices and printers~right click on the HP printer and left click on Remove device. Then reboot. The correct drivers should get installed automatically. If not use the installation CD that came with the printer or better still (if the printer is old) go to the HP web site and download the Win 7 drivers/software for the F4400.
May 19, 2011 | Computers & Internet
How to instal HP Deskjet F4400
use the link below to install the driver so the scanner will operate for you
http://bstdownload.com/tagged/hp%20F340%20driver/
Jul 30, 2010 | Visioneer 4400 Flatbed Scanner
I bought a hp deskjet f4400 from best buy and tried to in stall and it would not let me install
Dear friend please follow the step.
1. start PC and run the printer driver cd.
2. after a while your system ask your printer, thenm you connect in in USB connector then plug in for power connection. Wait for while, your system auto detect the printer , that time you received some Msg just read that all and go as per instruction.
3. Finish installation.
4 restart your system.
5 . 1st gives test print from printer properties option.
After these hope you seen good working printer with you.
Waiting for your feed back.
Jan 30, 2010 | HP DeskJet F4280 All In One Printer InkJet
How do I lighten color on hp deskjet F4400 series?
Explain what you want to accomplish please.
If yor printer soaks plain paper with too much ink, go to printer properties and change the media type to plain paper, and the print quality to Standard or even Draft.
If however you want to print pictures on photo paper, and they are too dark/saturated, you need to adjust the photos using some picture edit/touchup application - there are plenty of them available free online, or on computer magazine CDs etc.
Dec 30, 2009 | Office Equipment & Supplies
Press the Scan button on the printer and it asks me to insert the
the software was not completely installed, that's why. do a complete uninstallation first of the said program/software driver and then restart computer, then do a complete installation this time.
Jun 09, 2009 | HP Deskjet F340 All-In-One Printer
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
