Question about Hoover F7431-900 SteamVac Vacuum
Cleaning brushes will not turn. I have cleaned the filter
  • 438 Answers
Hi There,
Here's how you can fix the problem of your brushes not spinning on your Hoover SteamVac:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
Hope that helps you,
Chris Jones
goVacuum.com
Posted on Apr 27, 2010
How to open to clean
Hello! The dirt cup, filter and brushes need to be cleaned to ensure continued cleaning effectiveness. Below are steps for cleaning your Hoover Slider.
Turn switch to OFF position.
1. Press button and slide latch towards outside of cleaner. Rotate dirt cup toward back of cleaner.
2. While holding dirt cup, grasp filter frame and lift out filter. Empty dirt cup after every use. Dirt cup can be cleaned with a damp cloth. Allow to dry thoroughly.
3. Pull middle section of filter out of filter frame. To remove debris from filter, tap it on a hard surface or brush it with a soft brush.
4. Remove lint, strings, etc. from the brush roll located on the underneath side of the nozzle.
5. Replace the brush roll when the brushes do not touch the edge of a card as it is moved across the opening on the bottom of the nozzle.
Further disassembly of the cleaner is not recommended. Hope this helps!
F
Aug 13, 2014 | Hoover S2105 Slider Bagless Stick Vacuum
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes will not turn
(1) Remove the brushes by pulling down at the ends.
Is the square pin present on the top of one brush? It should be approximately 1/4 inch square, and two inches long. That connects the brushes to the drive mechanism.
(2) Assure the manual shutoff on the hood is not set to OFF, for the Brush Speed
(3) Remove and clean the filter screen under the cleaner. This should be a red panel, behind the brushes. Squeeze the two tabs, pull down the panel, and clean the hair/debris off the filter screen.
Sep 29, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Irobot 4100 brushes do not turn & bin is empty but filter is full. does the roomba need a new cleaning head module?
Yes, it probably needs a new cleaning head module, if your bearings are clean and the brushes still don't turn.
Mar 28, 2009 | iRobot Roomba Red 4100 Bagless Robotic...
IRobot not picking up dirt
try to replace the filter, that should work.
Feb 23, 2009 | iRobot Roomba 530 Robotic Vacuum
Thr brushes are not spinning and it smells
That is your belt burning, turn the vacuum upside down and make sure your brush is spinning freely. Something may be wedged in your brush.
Dec 27, 2008 | Kenmore 85920 PowerSpin Upright Wet/Dry...
Hoover steam vac model 7210-900
Did you clean both filters? There is one on the tank and the other is from the bottom, it ha a red frame, pull it out to clean. Pull the brush block out, is the shaft that goes up into the machine broken off? If so replace the brush block. While it is out, trn the machine on and see if the square hole up where the brush block goes, is turning. If not then the turbine has gone bad. You can sometimes clean the turbine out, otherwise replacing it may be the best option.
May 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Scrubbing brushes
your turbine might need to be replaced
Nov 03, 2007 | Hoover F5881-900 Vacuum
Vacuums Logo
220 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
