Question about Toshiba 51WH36 51 in. TV
I wohuld like to know how to watch the internet on my tv as my note book only has a vga port but my tv does not
  • kbergene Apr 26, 2010
    my tv does not have hdmi ports
  • Toshiba Master
  • 8,457 Answers
Ur Laptop have USB ports?Ur tv have HDMI ports? Use the HDMI cable plug in the USB port in the laptop side,plug the other end to the the tv HDMI port with the other side.
Posted on Apr 25, 2010
  • Chi Chu Apr 26, 2010
    Sorry! Than ur tv is analog tv.U can't combine with digital devices,to use as a monitor.
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Feb 03, 2012 | Panasonic VIERA Televison & Video
How do I hook my Direct TV up to Dell Dimension 9100 so I can watch TV on my computer?
Hi
For this one you need VGA enable TV if your TV have VGA port then, bring the one VGA cable from market and plug the Tv to Pc, enble to VGA mode in you TV. you get the screen you TV now enjoy to watch the TV, & do the work in big screen.
Cheer
Jun 22, 2011 | Dell Dimension 9100 PC Desktop
How to connect pc to sony tv laptop has vga and
hi may that can help you
http://www.youtube.com/watch?v=tkTVzfahNS8
i'm sure this will help youuuuuuuu
please a rate
Jun 19, 2011 | HP Computers & Internet
RCA model#L32WD12- Hello, is this model Nexflex ready?
This TV is not internet ready (either wired or wireless). However, you can connect it to a set-top box (like the Logitech Revue or an internet-connected Blu-ray player that can access Netflix) using HDMI port. Alternatively, you can use the TV as a monitor for your computer (VGA) and watch your Netflix streaming video that way.
I hope this helps.
(note: the HDMI ports on the L32WD12 do seem to be capable of understanding content from a computer on that input.)
Apr 19, 2011 | RCA Televison & Video
I have a usb port and I want to watch nexflex can
Hi - No, that would not be how to set it up (It wouldn't work) You would plug a VGA cable like the one most likely plugged into your monitor (15 pin connector on each end) from your PC video card (this is with both machines powered off) into the VGA port which you have on the TV.
With the PC on turn on the TV and with the remote select your source (would be called VGA or PC) and there would be your PC display on the TV. Bring up your browser and login to Netflix. The sound would come through your PC speaker and you would be watching movies on your 42 inch display.
Enjoy, Mikeywaf
Mar 08, 2011 | Sylvania LC420SS8 LCD TV
Element LCD TV owners - Using the VGA port may crash your TV!
I bought two of these tv's and they worked fine,I hooked up a computer to both of them and blam smelt smoke in one and the other wont come on either. The computer takes them out. It is a common problem with this TV.
Nov 01, 2009 | Element Electronics FLX3210 32 in. LCD TV
I am trying to hook up my tv with a vga to av(rca) cable,but I can't get it to work.What do I have to do to get it to work?
If your notebook has RCA composite video out, you need to hook it up to TV composite video input jack, usually the color of this RCA jack will be yellow. Why do you not use the VGA port on the back of the note book to feed the signal into the TV's VGA connector, just mke sure to set the resolution of the laptop to be at TV native resolution.
Sep 26, 2009 | Toshiba Satellite A105-S4334 Notebook
Philips 42PF9946 connect with laptop
Connect to the VGA port on the laptop, using a standard video cable.
Here is how VGA port looks like on your TV:
Note on some laptop you need to activate external video output by pressing a combination of keys, this will swap between laptop LCD video and external video.
Sep 13, 2008 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Enhanced video/TV missing in Device configuration
After looking at the specs of the think pad T43 i think you need a new laptop. The port you need to transfer video from a computer is called S-video. Your laptop don't have it. Srry.
You could look into some sort of breakout box that you could plug into your VGA out port and from there to a TV. The VGA out port is for adding a stand alone monitor and is not compatible with most TV's.
Jan 25, 2008 | IBM ThinkPad T43 Notebook
Connecting to a P.C
It it really has 11 pins I'm not sure but then my guess is that this is the service port connector which normally should have 9 pins. A vga connector has 15 pins and LG (as far as I know) uses standard 9 pin serial ports for service and plain old dvi or vga ports for connecting a computer.
Please visit Hardware Book for more info on connectors and cables.
Jan 15, 2008 | LG RZ-20LA70 20 in. LCD Television
Toshiba 51WH36 51 in. TV Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
