Question about HP Computers & Internet
Re BCM - sometimes it saves attachments, and sometimes it does not. Any suggestions? Could this be an installation problem?
  • lynda366 Apr 28, 2010
    BCM is business contact manager - a program in which one can save email correspondence
  • Jael Saavedra May 11, 2010
    Are you talking about an email client?
  • 62 Answers
Okay it depends about the program try to use Outlook express or windows mail.
If you're still having the same problem, look at you security.
Sometimes the anti-virus its going to block some emails maybe that can be your problem, but you can try to use another email client if you like.
That's the 2 options you have ;).
Posted on Apr 29, 2010
How do i remove bcm in 2007 pontiac g6?
Why ? If you replace the BCM it will need to be programmed . Dealer !!
This vehicle's body control module (BCM) has a bussed electrical center integrated into the housing. Body control relays and fuses are installed directly on the BCM, which simplifies wiring and junction blocks on the vehicle. The body control system consists of the BCM and its associated controls. Battery positive voltage is provided to the BCM from IBCM BATT 1 fuse and the IBCM BATT 2 fuse in the underhood fuse block. The module grounds are wired to ground G201, G203 and G305. The BCM is wired to the GMLAN High speed serial data buss, and the GMLAN Low speed serial data buss, as well as discrete input and output terminals to control the functions of the vehicle's body .
Trying to save you some agravation an wasted time an money . For a do it yourselfer , this is nothing you should be messing with ! You don't have the training to be messing with the BCM .
A new body control module (BCM) must be programmed with the proper regular production option (RPO) configurations. The BCM stores the information regarding the vehicle options and if the BCM is not properly configured with the correct RPO codes the BCM will not control all of the features properly. The Tech 2 software will automatically prompt you with the various RPOs available for the vehicle. Ensure that the following conditions exist in order to prepare for BCM programming:
This entire procedure has been reviewed before starting
The battery is fully charged.
A CANdi module is installed between the vehicle and the scan tool.
The ignition switch is in the ON position.
The data link connector (DLC) is accessible.
All disconnected modules and devices are reconnected before programming.
Oct 23, 2016 | 2007 Pontiac G6
Rear doors will not unlock
Door Lock System Components
The power door lock system consists of the following components:
The driver door switch (DDS)
The passenger door switch (PDS)
The body control module (BCM)
The driver information center (DIC)
The rear door lock/unlock relay (LBEC)
The door lock actuators in each of the doors The rear passenger doors are controlled by the BCM through the rear door lock/unlock relay which is incorporated onto the printed circuit board in the LH BEC. The BCM controls the unlock relay by providing ground to energize the coil and controls the lock relay by providing battery voltage to energize the relay coil. The energized the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. Since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
Do you know what the BCM is , body control module ! If you do not know about this stuff I strongly suggest you to it to a ASE certified repair facility ! Save yourself some money an aggravation !
Apr 17, 2015 | 2007 GMC Sierra 1500
Were is the BCM of a Saturn ion 2003 transmission manual
Above the glove box. It's attached above it.
Feb 25, 2015 | 2003 Saturn ION
How to installbcm & ground wire
This is not very specific on the problem but, anything negative can attach to the frame as ground. I have no clue what you mean by "BCM".
Mar 29, 2014 | Chevrolet Corvette Cars & Trucks
Lock door using key. only drivers side door locks remaining doors stay open. why?
I just answered this same question few hours ago...
The culprit is the foolish decisi?n of using a BCM (Body Control Module) to control the door locks with only two wires to the actuator on the lock. In order to "save" a few feet of copper wire, the too-intelligent automotive designers decided to use a costly, heavy, unreliable, complex electronic module instead of the third wire. Therefore, it now needs to multiplex the lock-unlock commands on only two wires. This BCM fails miserably in every Stratus or Sebring and Chrisler Minivans I've seen using this design approach.
As the BCM is VERY expensive and a real pain to remove from the dash, I resorted to disconnecting the wiring from the doors to the BCM, and paid a lot less to a car alarm installer, who installed an inexpensive car alarm with remote. Now I have to carry TWO remotes: the original one to set the original Chrysler alarm/inmovilizer, and the second to be able to remotely actuate the locks. It was much less costly (I saved about $350 USD) and a lot of pain to get the BCM from the car, additionally, I have heard that the repaired BCMs tend to fail again in a matter of two to three years after repair... sooo.
Best Luck. Amclaussen.
Jan 23, 2014 | 2004 Dodge Stratus
I have a 2006 dodge caravan and the rear turn signals will not work. fronts work fine, headlights and fog lights work fine. I checked all fuses and bulbs and none are burnt out. the turn lights on the dash...
Hello Durant.
Your rear signal lamps are turned on by the body control module (BCM).
You could have some broken wires from the BCM to the rear signals or the BCM isn't providing power to them. The BCM must be getting a signal input because the front ones are functional.
If you want to trace the wires here are the colors you are looking for.
Left rear wire is white/dark green.
Right rear wire is white/brown.
You may need to have your BCM scanned to verify.
If you would like more information to solve this yourself ask me.
Mar 27, 2010 | 2005 Dodge Caravan
Won't start - Turns over but won't run. Happened quickly. Is there a rash of faulty ignition switches in this vehicle?
sometimes the passlock in the ignition goes bad and will casue this,sometimes the BCM goes bad and will cause this,,,i suggest go to dealer
Oct 02, 2009 | 2001 Saturn L-Series
Electrical
the actual proble is in the BCM which means body control module, i will first check and make sure that all the grounding cables to this vehicle is tight and clean and if they areok and the problem continues it is time to get a new or rebuilt BCM.
Oct 26, 2008 | 1999 Dodge Grand Caravan
Computers & Internet Logo
21 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
