Question about Bosch & Tankless LP Hot Water Heater
I have a Bosch GWH 425 HN Tankless Hot Water Heater...On 2/28/2010, it began intermittant exploding when demand for hot water occurred. Local technicians worked on the unit several times, changed and serviced various parts, consulted with Bosch and never did figure out what was wrong. At one point, it suddenly began working OK and has been flawless for about 2 months. Now, suddenly, it fails to ignite again and a minor explosion occurs. What's the problem?
  • vicki sullins Aug 12, 2012
    Mine is doing the same thing! IT"S SCAREY! Bought it in March,2009. Any more on this problem ?
I have the same problem with the same model. The problem has been identified by a friend of mine, correctly, I think.
This is a very dangerous problem involving Bosch's much touted safety feature, ironically enough. IT IS THE FLAME SENSOR IN THE GAS VALVE. The flame sensor is supposed to confirm that the pilot has lighted BEFORE the main gas line sends gas to the main burners, after which the pilot shuts off. The pilot light is not coming on, the sensor that shouldn't let gas fto the main burners is failing and the main gas is flowing and ignighting from the spark that is supposed to light only the pilot in a big explosion.
This is the 2nd unit of this model that has failed. I think Bosch should do a recall
Posted on Feb 04, 2011
  • vicki sullins Aug 15, 2012
    Wondering if this actually did fix the heater. Mine is doing the same thing.
Find manual for 425 ng tankless
http://www.ps2netdrivers.net/parts/bosch.gwh.425.hn/
Nov 10, 2014 | Bosch & Tankless LP Hot Water Heater
Where can I download a Boschw14 b31 gas Heater Manual
Is this a water heater? Bosch site might have manual. And service bulletins, but I have not heard of that model.
http://www.bosch-climate.us/Bosch-Hot-Water/
Call local service technician who is qualified to work on tankless computer that heats water.
You can fix any brand tankless computer, any problem, same day, yourself by replacing 1 part: the whole thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
l
Aug 05, 2013 | Bosch ProTankless GWH 715 ES LP Tankless...
Bosch gwh 425 hn
Fix problem immediately same day, yourself, for $385, by replacing whole thing:
Bosch posts some service manuals: or contact Bosch. Lack of error code indicates failed PC board? or bad single-handle faucet cartridge?
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Check for crossover where bad faucet cartridge allows cold water to enter hot pipe, so hot water is not drawn through tankless and burner does not activate... but this might not be problem since you hear the tankless clicking
http://waterheatertimer.org/Crossover.html
Call local service technician to catch up on required yearly maintenance.
Jun 09, 2013 | Water Heaters
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
Aug 14, 2012 | Bosch & Tankless LP Hot Water Heater
Water temp flucuates from hot to cold, esspedially on very rainy days.
Gas water heater problem based on weather could imply atmospheric interference, which might indicate venting problem. Check vent specs for that model. Make sure roof or side wall vent are installed correctly, and lenghts do not exceed maximum.
Problem might also be associated with elevation setting, since water heaters are sold to match expected conditions at that elevation.
If rain is associated with cooler temperatures, and more gas appliances run at same time, then unit might be starved for gas or home does not have enough ventilation.
Problem could also indicate that tankless unit needs to catch up on yearly maintenance, including clean burner and combustion parts, check loose wiring, test ignition system, clean air intake, bleed gas line, check gas pressure and check for correct vent, etc.
Before calling service technician, open following link for Bosch troubleshooting resources including Bosch contact, typical manuals, etc.
Aug 09, 2011 | Bosch GWH 425 EF L Water Heater
Bosch Pro tankless water heater overheating
The vent pipe you use is the correct size for the heater.Longer runs require bigger pipe.I also would check to see if the water is getting to hot.
Mar 16, 2009 | Bosch ProTankless GWH 715 ES LP Tankless...
Tankless Water Heater - Frozen???
I had them same problem with my AquaStar 125 back in 2005......it hasn't been that could around here since then until last night and it froze up again. The problem is the negative draft. This can be solved with the Power Vent Module and the AQ1 flapper....at least with the 125. It prevents the back drafts.
Dec 21, 2008 | Water Heaters
Bosch & Tankless LP Hot Water Heater  Logo
742 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
