Question about Reebok 8700 ES Treadmill - Silver Service Delivery!
Hello. I have an 8700 es treadmill. The keypad for adjusting speed, incline, start and stop are not responding. The power is fine the digital screen lights up, but when i hit start, speed or any of the buttons nothing happens. Help Please.
  • duaner700 Apr 25, 2010
  • duaner700 Apr 26, 2010
  • 10,319 Answers
A capacitor is embedded in the circuit which keeps a charge to run the this unit. A capacitor is used for holding extra voltage needed to run all the working functions at a higher voltage. The display works off a very low voltage which is provided by the invertor plug into the wall socket. Whe a capacitor goes bad itwill show a hairline crack in it. The crack provides the voltage to leak out since the seal has been broken.Capacitors are sold at Radio Shack amd electrical suppy stores. Yours will have nubers on it with the letter u between the numbers. That will be the item number needed for replacement if done by you
Posted on Apr 26, 2010
  • 821 Answers
Hello,the speed keypad control board is kind of faulty,so it has to be serviced or replaced.it might be kind of due for servicing or probably if water or any other form of liquid is poured on it,this could also make them not to function.Try calibrating the console. If it doesn't work, you'll need a new motor control board.then the main control panel or board is bad. This is like the brain of the machine. You may have to test the circuits with a volt and ohmmeter to figure out which buttons are not responding.
thanks for using fixya,
take care.
Posted on Apr 25, 2010
  • Hammid Disu Apr 26, 2010
    hello,With the key in the console, press one of the incline buttons. While
    the incline is changing, remove the key. After a few seconds reinsert
    the key. The treadmill will automatically rise to the maximum incline
    level and then return to the minimum level. This will recalibrate the
    incline system.
    take care.....
  • 1,284 Answers
Hi, you have a failed control board panel, which the keypads are attached to. Once you press the keys and they don't respond, then you need to change the board..
Take care
I believe that my Reebok 8700es was plugged in during a power surge. I bought a dedicated extension cord and plugged it back into the wall and turned it on. Nothing happened. There were no sounds a
Step 1:
1) Please NEVER use extension cord, this will bring dangerous spikes, glitches, that will affect to your treadmills.
Disconnect it and use the specific outlet wall, for your machine
2) I recommend that you use the Software calibration for easy diagnose, troubleshooting and fix it. This will be clear the information code appearing the display.
Go ahead
Step 2:
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Step 3:
Jan 07, 2013 | Reebok 8700 ES Treadmill - Silver Service...
Healthrider 500i. The screen lights up with no belt, fan, or key pad response. I manually started the belt then it wouldn't stop or change speed.
adjust the Reed Swith see the diagram:RESET, clean, and tight cable connector.
2) Run the software calibration for easy diagnostic, troubleshooting, and fix it.
God bless you
Aug 28, 2012 | HEALTHRIDER Pro H500i Exercise Workout...
The control panel does not respond
Dear Sir>
Adjust the reed switch , attached is the diagram for adjust it 1/8-1/4'
2) Tight very well the flexible cables from keypad vs lower board.
3) After everything is o.k Run the software calibration. sincerely. God bless you.
Apr 03, 2012 | Exercise & Fitness
Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
How do you shut this thing off . the lights on the display stay on. reebok 8700es
Hols the stop button and the speed decrease button down while inserting or attatching the key (magnet). There should be a "d" on the screen, press the incline down button and it should go away. As soon as it disappears, your done. Just pull the key off and your display will shut off.
Hope this helps
Nov 06, 2010 | Reebok 8700 ES Treadmill - Silver Service...
My wife's Reebox 8700 treadmill is NOW stuck on the highest incline. Please help. It's under warranty. Thank you.
The problem is most likely a malfunctioning incline motor. It is still under warranty, therefore you can contact iconservice.com and they will send a technician to your home to install the new motor. Contact them through their website at iconservice.com and they will be able to help you. Thank you for using fixya and please let me know if there is anything else I can do for you.
Aug 17, 2010 | Reebok 8700 ES Treadmill - Silver Service...
Treadmill is plugged, lights are on but does not work
The standard calibration procedure to calibrate an Icon treadmill is done by holding down the speed up and stop keys while inserting the safety key or putting the key in place (if magnetic). If your keypad is not responding, because your treadmill keypad has failed or the console computer has failed. In these cases, the keypad can be replaced in limited instances or the console has to be replaced.
Now if you are able to get in calibration mode then Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, This means that it passes the EPROM test. If it shows ff or 2f your upper console will need to be replace.
Next step if eprom passes: Press either incline key and the incline will calibrate automatically.
DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). if you get the the number to 85 and the belt does not move , on the lower board you will see a like flicker that would be the speed control this tells you that the upper console and terminal cable is good ,but lower board defective.
May 20, 2010 | Epic View 550 Treadmill
My console does not allow me to change the incline, speed, etc. The control panel does not acknowledge the buttons pushed. I've turned it off and on.
my treadmill is doing the same thing. the only buttons that work are the start; incline up. 4 incline; 8 incline; and 11 incline.
Sep 26, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Incline problem
Make surt that there is nothing under the treadmill that could get caught in the mechanism.
Feb 05, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Reebok 8700 ES Treadmill - Silver Service Delivery! Logo
162 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
