Question about Mitsubishi VS-60705 60" Rear Projection Television
Picture is rolling sometime double images after awhile it stops and then starts rolling again
  • Mitsubishi Master
  • 8,457 Answers
Ur tv convergence are dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Posted on Apr 25, 2010
Testimonial: "thank you for quick response i don't know what this is but i will research it and hope for the best thanks dawn"
Why does my car start most of the time,but not all the time?
Are you sure it has spark, next time no start condition happens try spraying some starter fluid in throttle body and see if it starts.
I say this because if your fuel pump is weak and failing the jiggling of the car when you move it could cause a weak pump to work.
press the helpful button and check link below
1998 Lincoln Town Car Fuel Pump Replacement
Jan 16, 2016 | 1993 Lincoln Continental
When playing the system it will start out with a very clear picture then after awhile the image will start going out like going into black and white, fading, or just going to straight static. How do I fix...
dirty contact surfaces on the end of video cable or the switch box terminal are suspect. you can use very fine sandpaper rolled to clean inside the plug on end of cable. a wiggle test should find the poor contact.
other cause, overheating video in game unit. clean vents
Sep 11, 2013 | Atari 2600 Console
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
Vcr picture rolls
bad head or dirty try head cleaner
Jan 16, 2012 | JVC Televison & Video
I have a problem with my webcam sound. I recorded my assignment speech and when i try to listen to the speech, there was no sound coming out from the webcam. i tried everything and nothing worked. Can you...
Hi chinonsobeau,
First off, you to list the model number of your HP web Cam, as well as your OS, and the software you using to record your sound. I will assume that you have Quickplay which HP ususally send out with their web cams.
To access QuickPlay, just press the "blue QuickPlay button" next to the power button. If it doesn't load QuickPlay, just do "Start" - "All Programs" - then you will see QuickPlay listed there. If you still can't find it just do a search, you will find the short-cut. If you still don't find it, then HERE is a place you can download it and use it. It also has instruction on how to use it.
Or sometimes HP sends out Cheese, another camera software. You can download that HERE.
These are the instructions for QuickPlay:
Once launched QuickPlay, click on the 2nd icon from left (between DVD and TV icon), then double-click on "HP Pavilion WebCam" from the left side panel, then you will see the blue LED light lit and you should see yourself on the screen. (Double-click "yourself" to enlarge image)
To take a picture or record video, just press the corresponding buttons on the top. (the red circle icon is for recording video (press "Stop" icon to stop recording), the camera icon is for, well, camera)
Videos and pictures are saved at:
Pictures -- C:\Users\Public\Pictures\My Snapshots
Videos -- C:\Users\Public\Videos\HP Webcam
I'm less familiar with Cheese, so I'll give you their website HERE to go to their support and they can guide you through their program.
Anyway, I hope this helps,
Don't forget to leave a raing,
Thanks
Mark
Videos -- C:\Users\Public\Videos\HP Webcam user_offline.gif
Oct 11, 2009 | HP Computers & Internet
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
Tv picture and sound
Sometimes you just have to shoot the old girl.
Mar 13, 2009 | Televison & Video
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
Picture jumping
sounds like a capacitor and or the convergence IC's
for a tech to come out it's normally 300- 400
Dec 02, 2007 | Televison & Video
Mitsubishi VS-60705 60" Rear Projection Television Logo
378 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
