Question about Bosch Dryers
I have a bosch classix condenser dryer ENR no. WTE84107GB/02 and we do not seem to have a manual for it. The filter light keeps coming on. I have cleaned the filter inside the door and wiped the part (don't know name of it) that is behind the door to the left bottom front of machine. Not sure if this can be washed? or if there is another filter behind the panel bottom front right of the machine - which I cannot seem to get open? Worried about breaking the plastic if I force it? Please can you help?
SOURCE: How to clean the bottom filter
Don't know how old your machine is but on my wtl5400 the bottom flap is opened by:
1. open the drier door
2. note small round button on the lower right hand side of the drum surround
3. press the button which will spring forward then
4. lower filter cover springs off giving acess to filter drawer
NB if the filter is over full the button will spring open itself as a gentle hint
NNB YOU CANNOT CLOSE DOOR WHILE THE BUTTON IS EXTENDED so take care door will only close when lower cover has been correctly replaced relocating the button flush with the front of the machine
Posted on Sep 25, 2008
svicari124
  • 21 Answers
SOURCE: I have a Bosch Maxx condenser tumble dryer that wont work.
Have you taken the condenser itself out from the bottom of the machine? Remove the condenser from the bottom door and rotate the clamp tags which secure it in. Slide condenser out (aluminium mutli-finned box assembly) and carefully take it outside. Use a garden hose with lots of water pressure to spray each vent passage carefully to clear lint and dust away. Passages must be cleared in both directions, long ways and cross ways. Cross ways is the problem area and once you finish clearing the air ways you should see daylight through the condenser easily. Reassemble and always clear lint filter in the door /drum area.
Good luck.
Sam
Posted on Sep 20, 2009
SOURCE: LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Posted on Dec 05, 2010
news775
  • 699 Answers
SOURCE: I have a Bosch Classixx Condenser Dryer which wont
Check the door interlock, this could be sticky or broken.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 14, 2011
SOURCE: When i start the Bosch WTE84107GB/02 is showing
Having spent two nights trying to resolve the same issue with ours and having searched the internet for help. I would check the following,
Check lower filter and ensure its all clear.
Remove the back of the machine, the pear shaped steel cover part, held on by 10-12 torx/star bolts. Once removed you should see two sensor, one has a red reset button, press the centre and if it clicks you've reset it. Now you could be lucky and just refit the back and it will work o.k but the likelyhood from my experience is that the senors tripped out due to an overheating situation occuring. If it trips out after the reset, remove the cover again, the two sensors are mounted in what is the heater element. I removed this unit but to allow access you need to remove the lower steel duct below the heater element unit, held on my 4 torx/star bolts. Once the ducts removed you can remove the two torx/star bolts that hold the heater unit in position. Once the heater unit is removed, blow out any dust and dirt from the heater coils. With the heater unit removed you can see both the sensors from inside the heater element housing and both mine were caked in dirt so i cleaned the surfaces with a soft cloth and a drop of WD40 (not to much just enough to remove the dirt).
The next part of the machine i'd check is the air intake side. There's a grill area and the right lower side of the dryer to the right of the lower filter housing. Now you can probably remove this grill by resting the machine on it's side and releasing the clips from the underside of the machine but I took off the right hand side panel of the machine, you'll need to remove the top (two screws at the back of the machine slide back and lift off), then you need to remove the control panel, remove the water tank, and then remove the two screws on the left side, on the right side and on the right had side of the control panel, there's one screw, remove this and pully forward gently. You can then access the right side panel forward screws x 2, remove the rear screws, top screws and there one on the underside in the middle. The side panel pulls away backwards away for the front of the machine as it has three locating pegs at the front. Once the panels removed you'll no dout find the area around the motor and drive belt is covered in fluff, just hoover out. with the side panel remove you'll notice the motor unit drives two fans, one you'd have seen when you removed the rear cover and on my machine that was all clear, but the other fan is towards the front of the machine and is covered by a semi circular white plastic cover, which has 4 release clips on the outer egde and one at the rear towards the middle at the motor end and one at the front close to the middle and you won't get you hand into this, you need to release the clip form the underside of base of the machine.Once all clips are removed you can remove the cover, but it's a tight fit but it does come out. Once removed you'll see the fan unit, it's like a hamster wheel and on my machine this was fully choked up with fluff in the middle and in between the fan blades and this is what was stopping air circulation and hence why the machine overheated and cut out. You can hoover out the fan and in the intake system and refit in reverse order, making sure you get the screws back in the right order.
Whilst you have the machine half apart, Once you've refitted the right hand side panel and before you refit the front control panel i'd remove the left hand panel, hoover out. At the bottom left side you'll see the pump unit. There's two pipes going to it, remove the cover retaining screws and remove the cover. Remove both pipes and the two electrical sensors (ones pump and ones the float level senor) Once removed, clean the float sensor and pump you can remove the end cover off the pump and you can also remove the float from the cylinder housing ), remove the filter unit/heat exchanger and clean any sludge etc from inside the pump sump area. Refit
We found that on completion of this the machine was a lot more efficient and made less noise and it's nearly 11 years old so it owes us nothing !!
Posted on Nov 08, 2011
My bosch classix dryer is saying container is full but its not and machine keeps turning off. Any suggestions?
Owner's manual no manual? Try MFG website or email their customer service, or try
manualslib.com
What does container mean? Water condensate bucket? or similar?
Apr 12, 2015 | Bosch Washing Machines
Bosch installation instructions
find this on their web site need the enr no
Jul 16, 2014 | Bosch WTE86300US 24" Axxis Series...
I need a user manual for the Bosch KGE3512/02
go to their web site but you will need the ENR no from inside the door label
Feb 06, 2014 | Washing Machines
My Bosch classix dryer is not drying the clothes. The drum is turning & it feels very hot on the inside & on the outside of the machine. There is a lot of condensation around the edges & where...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 11, 2011 | Audiovox Bosch 718 World Cellular Phone
My Bosch wtl6304 condenser tumble dryer keeps indicating empty filter light and bleeps rapid. It warns me twice like this then trips the thermostat out. I have cleaned filter, washed the condenser out and...
never really heard of a condenser model dryer before however it does seem like internally its full of lent inside of the dryer housing itself around the heating elements if you have a large air compressor open it all up and spray air into everything in the dryer where you see lent build up this will force any lent out of the dryer and it should hopefully run as the day you first got it ;P found this to be an issue even with an LG TROMM dryer i opened up and wasnt drying very well
May 06, 2017 | Bosch Axxis WTL 6307 Electric Dryer
I have a Bosch Classixx Condenser Dryer which wont turn on - have cleaned out the filter - checked the fuse on the plug - still wont turn on. The model is WTE84107GB
Many thanks
Feb 14, 2011 | Bosch Axxis WTL 6003 Electric Dryer
Have a Bosch logixx condenser dryer. key sign on screen
You have activated the child lock, basically you have held the start button for over 3 secs. turn the dryer to the cycle you want and keep your finger on ther start button to deactivate. If this doesn't work you may have a module problem. Double check your manual for child lock info. if no module go to link and enter you Enr number.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Jul 02, 2010 | Bosch Dryers
Good luck.
Sam
Sep 02, 2009 | Bosch Dryers
Error Code
open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
Aug 25, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
153 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
