Will not turn on, had blinking green light, unplugged unit over nite, plugged back in , when power button is pressed, 1 click inside unit. when lite was flashing- clicking with each flash. it it worth repairing? model vs-60603, serial 125034. on the circiut board someone changed the nuber with a pen to p-832. looks like it has been apart before, different screws in rear cover. paid $250.00 for it used.
  • 5 more comments
  • saddleandrun Apr 25, 2010
    a friend had one and it needed a board replaced for $100.00 parts. how old is it? i would spend $250.00 to get it going just to not have to move it. i don't get around very good anymore
    i will spend around $250.00 to fix it. could it be a power problem going to the tubes?
    this unit is a thre tube projetoin unit. i held the menu and input bottons and no flahes from the green lite
    no light flashing
    it was flahing green and clicking inside the unit constantly. unpluged the tv overnite and it quit. plugged it back in and now clicks and the green the green light comes on once. one flash and one click. i also smelled a slight burtnt smell
    if something i can fix for $300 i will fix it. i wave electrinic and electrical experience and know about the charged/ stored voltage. i paid 250 for the tv 5 years ago. my main concern is if it is work putting money in it or buy a lcd or plasma? all comments are welcome
    thank you for the help
  • 4,889 Answers
Ah another mitsi ! Please get me the error code by performing the error code operational check so that I can help you with your problem. To do this unplug the tv to reset the error code. Plug it back in and press and hold the Menu and Input/Device buttons for 5 seconds. You will see a series of blinks a short pause(about 1/2 second) and then another series of blinks The no of blinks before the pause is the 10's digit and the no of blinks after the pause is the units digit. For example if you see 2 blinks followed by 1 blink then the error codes is 21. Please get me the code so that we can determine what the problem is.
Posted on Apr 25, 2010
  • 3 more comments
  • eagle338
    eagle338 Apr 25, 2010
    I know that its a CRT projection tv. And I did not say green light did I? Only one LED will flash during the operational check.
  • eagle338
    Ok.. and the timer light? What color is it blinking in for thats what you have posted in the main problem.
  • eagle338
    That definitely sounds like a power supply board issue. The clicking noise means that the protection circuitry are kicking in and causing the relays to turn off the set to prevent damage to the components. It is possible that one or more lines are over loaded due to a failed protector or a voltage regulator IC. Do you have any prior experience in handling electronics? I am asking coz the set holds potentially lethal voltages for several hours after its turned off and I would recommend risking your life and limb for it. I have a service manual for this model that I can give you but if and only if you can handle it.
  • eagle338
    Here is the service manual. Be careful though. Unplug the set before starting the repair. Discharge the voltages to make the job safer. Use a multimeter that can provide its own voltage to test the circuits so that you dont have to power up the tv to work on it.
    Click here to download the service manual.
  • eagle338
    You are most welcome. If you get stuck somewhere be sure to let me know and I will be glad to assist.
  • 10,594 Answers
Its pretty old model of Mitsubishi and I would recommend not to waste money on its repair as parts would be hardly available.
Thanks.
  • Shahid Electronics
    Shahid Electronics Apr 25, 2010
    Not tubes, problem is in deflection circuit of tv.
My canon ir 5180 blinks only d green light but d screen does not open
Start with the printer OFF:
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
0 - green - Pressing power button will turn off printer
1 - orange - Service Test Print
2 - green - EEPROM Information Print
3 - orange - Initialize EEprom data
4 - green - Reset Waste ink Counter
5 - orange - Mode to set Destination code
(1: Overseas, 2: Domestic)
6 - green - Refresh printhead (cleaning mode)
I assume the printhead is cleaning and you need to wait for it to finish cleaning. That could take over a minute and a half; I don't know what that delay is for your printer.
If that is not the issue, you may have to reset the printer. This may be possible as follows:
  1. Hold down HELP + OK button and unplug printer (could experiment with regular power-off, but I opted for brute force)
  2. Hold down HELP + OK button again as you plug the printer back in. Then power it on, if it doesn't power on automatically. Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
  3. Release the buttons and simply power it back on. (If you unplug it without powering it down, you may get an improper shutdown error message. If so, click OK on the printer.)
If you are looking at a blank computer screen after all of this, you might try uninstalling and reinstalling the driver.
If this does not fix the problem, you better look into troubleshooting on the manufacturer's site for help for your particular printer.
Jan 21, 2015 | Canon Office Equipment & Supplies
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Apr 11, 2017 | Computers & Internet
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
In my WS 65809 projector tv, when I turn on the power, the green light clicks on for a couple of seconds, then clicks right back off.
DO THIS AND LET ME KNOW WHAT YOU FIND:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
The green light on our mitsubishi tv WE-48511 turns green and turns on for about a second and then immediately turns off. The unit will not power up at all. any ideas?
PRESS AND HOLD “device”(or input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
if this information has helped you rate this solution as I do this here for free.
SD TECH
Nov 27, 2009 | Mitsubishi WS48511 48" Rear Projection...
Ws65511 green blinking light had power failure last nite power came o briefely then off when power was fully restored the green blinking lite appeared have tried numerous things HELP
Replace the dm power board . Its inside the metal box on the left (looking at the back with the back removed). p/n 935C986002
Or if you can solder then replace the 7 electrolytic capacitors on the DM power board. value 1000uf16v.
Jun 24, 2009 | Mitsubishi WS-65513 65" Rear Projection...
My printer is blinking orange lite
Hi there ok try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 18, 2009 | Canon S400 InkJet Printer
Panasonic PT-51HX41 51 inch
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
