Question about Hunter 27185 Remote Control
I have the remote 27157 and trying to hook up to the five minute fan, the strathran. The problem is there are three wires out of the top of the wall, two are the electrical cord which give the fan power, the other green wire. I have six wires from the remote, which wire goes where??????
  • 10,865 Answers
Hello. The green wire is a ground wire. The black wire is the hot wire and the white wire is the neutral wire. Here is the manual for this remote which includes all of the wiriing diagram options
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/41316.pdf
Joe
Posted on Apr 25, 2010
Instruction for a hunter remote model 27157
this is the hunter technical support--1-888-830-1326 just ask for support. then you should be able to order the instruction manual.
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
I purchased a hunter universal remote and have a hunter fan with canopy I am trying to get it hooked up to. I have all wiring configured the way it shows on diagram and still nothing. From the box in...
If everything is wired correctly, disconnect power at the source, then reconnect power and experiment with every possible combination of wall switches and the remote until the fan works correctly. At that point, do not use the wall switches again, ever.
Apr 17, 2017 | Hunter 27187 Remote Control
Can this remote (hunter 27157) be paired with a fan that is already installed and has a remote. I want to use it as a backup. the remote i have is not a 27157.
I know you can use many different remotes of the 27157 model to control one receiver. There are several different reason why you may not be able to use the remote from one brand/model with another. The first is the frequency range may be different. One could be 27mhz and another could be 49mhz. Another reason is the code that is sent to the receiver by the remote to turn on the light or the fan varies from manufacturer to manufacturer and even from one model to the next from the same manufacturer. This is so there is less chance one remote/receiver commbination will interfere with another in the same location. That is why I say you will be very lucky to find an off model remote to work with your receiver.
Aug 06, 2010 | Hunter 27185 Remote Control
I installed a Hunter On"Off fan and light control model 27157 on a Hunter Augusta fan model 21338. I tested the remote control and the fan and light on, however, after a period of time, the fan turns on...
Most likely this is caused by radio interference from some other device nearby. Try changing the "channel" by changing the dip switches on both devices and make sure they match. :)
Mar 27, 2010 | Hunter 27185 Remote Control
Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
No dip switch in Hunter 27157 remote control.
Those aren't transistors in the transmitter they are jumpers. Match the jumper settings with your dip switch settings in the receiver. You can move the jumpers in the transmitter using a small needle nose pliers. An open jumper in the transmitter equals an OFF setting on the dip switch in the receiver.
Jun 24, 2009 | Hunter 27185 Remote Control
Im changing out a ceiling fan.
hook black to black white to white and the blue is a ground wire that you hook to the metal bracket that holds fan in cealing ( anywhere is fine just loosen a screw and place the wire anywhere!
Dec 09, 2008 | Dryers
Fan and light control model 27157
yeah, if you take off the battery cover on your fan remote there should be something called a "dip switch". it wiil be numbered 1,2,3,4, just flip these switches up or down to match the receiver that will be located in the fan houseing or in the fan canopy.
Sep 19, 2008 | Hunter 27185 Remote Control
Ceiling fan, remote control
I call some one here is the USA a he walked my thru it, Its is a big different when you deal with some that speek your language
Jun 08, 2008 | Hunter 27185 Remote Control
Televison & Video Logo
233 people viewed this question
Top Hunter Televison & Video Experts
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Henry  Thomas
Henry Thomas
Paul Bade
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
