Question about Lenovo ThinkPad T61 Notebook
On the right hand lower screen was a green display that told me the hours left of power or the % of charge. it dissappeared, how do I get it back?
    Guru:
  • 163 Answers
Reinstall the drivers from driver CD & install all the drivers properly and let the system itself install them. It will reboot several times.
Posted on Apr 25, 2010
Where is the power button on the mac computer
The power button is on the back of the LCD screen in the lower left hand corner. You should power down by clicking on the Apple Logo in the upper left hand front corner and choose "Shut Down". If your screen freezes, you can power off by pushing the power button and holding it.
Jan 22, 2013 | Apple 24" iMac Desktop
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
Tomtom go 510 do disply
Same here and with aftermarket mount. The light comes on but its not really charging. I was acutally able to find a sweet spot basically by pushing it down and to the right slightly (into the base) and held it in place with left hand and put the unit in the upper left part of the windshield, elbo in the window frame and move the unit around until the low batter warning dissappears, then don't move. Theres a specific screen that will tell if its charging or not if you tap the lower right part of the screen after booting up if you can get that far. I forget what it was, I think displays speed and miles to go. (But definatley hold the whole unit down and to the right and hold it for a while so it can charge up a little.) Then try turning on and you should have enough power to tinker with it. I would up putting the tom tom in the upper part of the windshield, then stuffing balled up napkins between the roof and the unit to keep pushing it down.
I also plugged it in the the original computer hook up base to see if the problem was on the winshield one or the tom tom itself. Both chargers do it so I am assuming that its the tom tom itself. I still CANNOT figure out why the charge light could be on and still not charging.
I am going FRD and taking it apart. (Fix Or Destroy) Since they are getting pretty cheap, nothing to loose I guess.
Thanks back to all the posters on this site!!
Feb 23, 2009 | Tomtom GO 510 GPS Receiver
No power no red or green light
Check the hidden master power switch is 'on' - located under the lower left hand corner of the screen.
Aug 20, 2008 | Fujitsu Plasmavision P42HHA10 42 in....
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Tomtom won't turn on
  1. Fully charge the unit
  2. Reset with paperclip at bottom of unit
  3. Hold down Power On for a longer period of time, about 10 sec.
It should start...
Apr 10, 2008 | Tomtom GO 510 GPS Receiver
How to set watch
I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
Apr 02, 2007 | Kenneth Cole RK5034 REACTION
Lenovo ThinkPad T61 Notebook Logo
51 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
