Question about Krups FME2 Coffee Maker
Coffee maker just blinks with 8888. I have tried hitting on off button, setting the timer, pushing the prog button, 1-3 cup button and unpluggin it.
5 Suggested Answers
  • 3 Answers
SOURCE: Lid won't open - coffee won't
For those of you having problems with your KRUPS KP1010 Pod brewer stopping brewing in mid-cycle and then having the blue led power light blink rapidly, I have found the cause of the problem as well as a solution.
I have a Krups KP1010 pod brewer at home that is nearly 2 years old and has NEVER had a problem. Having enjoyed it’s continued great performance, when a small group (8 people) of people in my office decided to go "POD", we pooled our money to purchase the Krups.
After 8 months of moderate, not heavy, use, this problem developed. It got worse and worse, so bad that it would stop almost instantly after pressing the brew button. Sometimes it would work as normal, and other times, we found that if you applied pressure to the top lid, it would work completely.
This started me thinking that there must be a sensor switch inside to detect when the lid is open. This suspicion was backed up by the fact that when the Pod brewer was ON, but IDEL, if you open the lid, the blue light would and should blink.
Here is what I did to fix it.
If you are at all handy with taking things apart and making small minor repairs, this problem can be easily fixed rather quickly.
There is a total of 8 screws to remove. Four are located at the bottom of the unit and are the same size. Two more are located under the water tank reservoir, so you will have to remove the water tank to access them. These two screws are the same size at the four that you removed from the bottom of the unit. The last two screws are located at the top of the tank, BEHIND the lid, but can easily be seen when you remove the water tank. Turn the KP1010 around so that the tank is facing you. When you have the tank removed, look at the top area of the body of the pod brewer. These are the last two screws that you will have to remove. They are NOT the same size as the other six, and you will likely need a smaller jewelers sized Philips screw driver to remove them.
Once you get the back of the unit off, with the water tank side of the brewer facing you (coffee pod area facing AWAY from you), look in the upper right corner. Unlock the latch at the front of the brewer. Now while looking in through the back water tank area, in the upper right corner, gently raise and lower the brewer lid. You will notice that there is a LID SENSOR SWITCH. The switch is defective and, like a washing machine, when the lid is OPENED, the switch cuts the circuit (power) to the brewer, the same as when the washing machine stops when you open the lid.
The Fix: While Pod brewer is UNPLUGGED, gently grasp one of the two connector wires attached to the lid sensor switch. BE SURE TO GRAB IT FROM THE METAL CONNECTOR AND NOT THE BLACK WIRE ITSELF AS YOU MAY PULL THE WIRE AWAY FROM THE METAL CONNECTOR AND WHILE IT IS STILL REPAIRABLE AT THIS POINT, IT WILL BE MUCH MORE TIME AND SKILL CONSUMING.
Once you have removed the wire and it’s metal connector from the lid sensor switch, repeat this process with the OTHER black wire connected to the lid sensor switch.
(I tested this fix by at FIRST using basic tape) The fix for bypassing the lid sensor switch is to connect both black wires together. I initially used basic tape to ensure that my suspected cause of this problem would be fixed by my suspected solution. I then brewed 3 tanks of water back to back and the "stop brewing, rapidly flashing blue light" problem NEVER appeared. FIXED!
Now to be a bit more professional about it……… I removed the tape and soldered the metal connectors of both black wires together, and then wrapped with electrical tape. You COULD just wrap them together snugly with electrical tape if your NOT into soldering, but for the best, most secure connection, SOLDERING is the best option as there is no chance of vibration causing the black wire metal contacts from intermittently losing contact with each other. Again, if you are un-comfortable with soldering, at least try wrapping the wires snugly together with electrical tape.
Today our Krups KP1010 brewed flawlessly all day. The ONE downside to consider in this procedure is that now after having this "fix" performed, should you leave the lid of the brewer OPEN and start a brew cycle, the brewer WILL operate and shoot hot water & steam out everywhere. However, for those of you that own this brewer, you should know that having the lid open nearly completely obstructs you from easily reaching the brew button AND, what moron would leave the lid open and try to make coffee? If someone does that, they DESERVE to get burned!!
Best of Luck!!
Ed
Posted on Aug 12, 2008
SOURCE: Broken Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker?
My Krups was not working after I accidentally forgot to place the black plastic lid on the coffee carafe BEFORE starting to brew a new batch of coffee. The coffee will not drip into the carafe without the lid
in place. Because the lid is hidden when placed in the coffee maker, it's easy to forget! The coffee all backed up in the filter area and overflowed. The display got wet. Not good.....
If your buttons and or display is not working ( mine got wet with coffee) simply flip the coffee maker over. Unscrew the bottom. expose the display circuit board carefully, DRY it with a HAIR DRYER and put the unit back together! Presto! Mine is working again.
If you need a new circuit board, you can get one for $35 from Appliances.com I found. They also have the Duo filter and extra parts cheaper than the Krups website.
Posted on Feb 23, 2009
SOURCE: Need instructions on setting clock and timer for
I know this is an old post, but I had the same issue. Go to this website for the manual.
http://www.applianceinsider.com/krups-user-manuals/
Posted on Feb 10, 2011
  • 343 Answers
SOURCE: I have Krups KT 406
Did you try it this way?
Before descaling, remove the filter holder (f).
• You may use either the Krups descaling solution diluted in 8 ounces of water or
8 ounces of white vinegar.
• Pour the solution or vinegar into the water reservoir and start the coffee machine
(without coffee).
• Allow half the liquid to run into the carafe, then switch off and let stand for 1 hour.
• Restart the coffee machine to complete the cycle.
• Rinse the coffee machine by running it through 2 full cycles with water only
I would make vinegar stronger and leave it in for a few hours or more.
I have attached a copy of the owners manual for you to download. Thanks for using FixYa; if you could please click accept solution
http://www.krupsusa.com/NR/rdonlyres/28C9969C-D788-4136-B298-EA43960B582C/28300/KM4065dahlstromUS.pdf
Posted on May 22, 2011
How do you set the time as well as the timer? I have looked but can not find the manual.
Good Afternoon,
Programming Your Coffee Machine
• Plug in your appliance: the display will light up briefly in blue, blink "8888" and then remain
fixed.
• Press the O/I button if you wish to make coffee without using the programmable mode.
• The display will light up in blue and alternately show "ON" and the current time.
• Press the O/I button to shut off the coffee machine. The display will no longer be lit.
Setting and Adjusting the Clock
• The machine must be "off".
• Press and hold the prog button (o) for 3 seconds: the hours will blink "88 _ _".
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink" XX 88".
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Setting Auto On
This programs the coffee machine to start automatically at the set time each day.
• Press the prog button (o) briefly : the display will blink "prog" for about 1 second, followed
by "8888".
• Press the prog button briefly: the hours will blink "88 _ _".
• Press the prog button briefly: the minutes will blink "XX 88".
• Adjust the minutes in steps by pressing the h/min button .
• Confirm the setting by pressing the prog button briefly:
• The display (q) will show the time and a " ".
• Press the h/min button to cancel the programming.
Click the link below for the maunal:
http://www.krupsusa.com/NR/rdonlyres/A50B1840-2CD9-44C1-87E8-260B92D96D3A/7244/FME124_FMF345_usa.pdf
Hope this helps!
zeppelinx12
Feb 23, 2011 | Krups FME2 Coffee Maker
Machine stopped working and both buttons are flickering, if I push the left (small coffee) button then the machine starts to pump cold water. If I push the left (large coffee) button nothing happens. Not...
May be busted, but before you take it to the shop try these few things. 1. Unplug machine for 30 seconds 2. Then plug back in, (lights should still be blinking) Take silver handle that you lift when you put in coffee pods and gently push back handle as far as you can for 3 seconds. This should reset your machine,back to factory settings. To then reset coffee cup settings to your personal taste by: 3. You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. Do the same for small coffee side. Hope this works,it has for me; just not sure because of the cold water pumping out issue. good luck
Nov 11, 2010 | Nespresso Essenza C100 Espresso...
How do i turn off the sound on the alarm
Setting Audible signal
This function gives an audible signal when the coffee is ready. The factory setting is "On".
  • The display (q) will show " " with the current time.
  • To turn off the audible signal :
  • Press prog button then the 1 - 3 cup button (p).
  • The display will show "YES": indicating the audible signal is on.
  • To turn the audible signal off:
  • Press the 1-3 cup button again.
  • The display will show "NO": the audible signal is off.
  • Press prog button to confirm.
Sep 24, 2010 | Krups FMF5-14 Stainless Steel 10-Cup...
I lost the manual and i can't reset the clock on the machine. how do i do this?
reference: Setting and Adjusting the Clock • The machine must be “off“. • Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“. • Adjust the hours in steps by pressing the h/min button (n). • Press the prog button : the minutes will blink“ XX 88“. • Adjust the minutes in steps by pressing the h/min button. • Confirm the setting by pressing the prog button.
Mar 17, 2010 | Krups FMF5 Stainless Steel 10 Cup Coffee...
Blinking on/off light won't turn off
It means it's time to "decalcify" your machine. Not sure how to do that, I assume run vinegar or something like that through it. You can turn the blinking light off by holding down the "set clock" and the "set timer" buttons at the same time.
Oct 23, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Mar 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Need help on using Timer feature on Melitta Mill & Brew
My second one just died, and I am very sad, but I can help you with your question.
First you have to set the time. Do that by pressing the hour or minute buttons until the time blinks. Then you can press the buttons to set the time. AM/PM are differiented by a red dot coming on in the time display. You can set that as preferred.
To set the timer feature, press the time button until the time blinks. Then use the hr and min button to set your timer setting. Pay careful attention to match the am/pm button with what you want.- if you don't you will be 12 hour off. To use the delay, set up the coffee pot, then push time. The red time indicator will light. If you are using ground coffee press the mill button. If it is lit, the mill will not turn on. This goes for either timed brewing or present tense brewing.
THe coffee pot has a timer - it will shut itself off after 1 hour. If you want to restart it, just push the mill button and press the on/off button.
Mar 15, 2009 | Salton Melitta Coffee Maker 10 Cup - white...
SHUTS OFF AFTER 1 HOUR
Here ya go!
Setting Auto Off (units with timer only)
On models with a glass carafe, the auto off can be set to shut the coffee machine off from 1 - 5
hours after the brew cycle is complete. The factory setting is 2 hours. On models with a thermal
carafe, the coffee machine shuts off after 20 minutes.
Note : On models without a timer the coffee machine must be turned off manually. It
will not automatically shut off.
• Press the prog button (o), immediately followed by the h/min button (n).
• The display will show the time setting.
• Press the h/min button in steps to set the auto off time.
• Press the prog button to confirm the setting.
Dec 30, 2008 | Krups FME2 Coffee Maker
FME2 Coffee Maker
From page 9 of the manual:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={FA4AA2D9-9799-4F8F-8136-8FEB029407FD}&SelectedProdRef=FME2
Aug 28, 2008 | Krups FME2 Coffee Maker
Lost manual
The manual is here: http://www.wholelattelove.com/manuals/Krups/FMF5%20Manual.pdf
Here is the relevant information from it:
Setting Auto On
• Press the prog button (o) briefly : the display will blink “prog“ for about 1 second, followed
by “8888“.
• Press the prog button  briefly: the hours will blink “88 _ _“.
• Press the prog button briefly: the minutes will blink “XX 88“.
• The display (q) will show the time and a “ “.
Aug 19, 2008 | Krups FMF5-14 Stainless Steel 10-Cup...
Krups FME2 Coffee Maker Logo
54 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
