Question about Whirlpool Duet GHW9150P Front Load Washer
Removing the bottom front panel from my duet washer
How do I remove the bottom front panel from my whirlpool duet washing machine? I cannot locate any screws to remove. When I pry it a little I can see where it is stuck, but still can't find where to release it.
Thanks for you help!
  • Whirlpool Master
  • 3,361 Answers
I have a F6 code problem with my Whirlpool Duet FL Washer, any ideas?
F6 is an issue with the motor drive tachometer. Most often this is caused by poor connections at the machine control or motor controller. Locate the main machine control by removing the top panel and the motor control by removing the rear panel. Remove each connector, ONE AT A TIME, and reinstall. If this does not work, you likely have a faulty control.
Kelly
May 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer is flashing f2
F2 on a Whirlpool Duet means their is a problem with the Drain Pump or Drain Pump Filter. The Drain Pump and Filter are located at the bottom of the Washing machine. You must remove the front, bottom panel to gain access to the Drain Pump and Filter. Disconnect the Filter and Drain Hoses and clear them out. If they are clear, you may need to replace your Drain Pump.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The doo rof my HE Whirlpool duet washer is locked and light says add garment now". I have tried the manual's instructions, and I have unplugged the washer. I have clothes stuck inside the machine,...
Unplug washer and remove lower front panel by removing 3 screws on bottom of panel. You will need "torx" or nutdriver. Reach in and up on right side of inside of washer, right were the door latch is, at the bottom of the mechanism is a manual release. Pull downward on the release and the door should open.
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer wfw8300sw02 won't unlock
Hi, I'm not sure why your door won't unlock but you can manually unlock it by removing the front panel under the door (3 screws at bottom of machine) with the panel off reach up just under the lock mechanisim and there should be a plastic tab hanging down, that is the manual release. Pull it down and your door should open. Remember, power off first! Good luck.
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 clogged line on a new Duet Sport less than a year old???
Hi, regarding the F21 Error on the Front End Whirlpool Duet, I was able to resolve the problem with the instructions from here, just want to stress cleaning out the filter by removing the front panel. Very easy and the error code is now gone. (screws are underneath front panel at bottom, remove stacker drawer for easy access, remove screws, pull panel off, remove the filter cap, turn to the left and pull out-that's where you will locate the clog.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer not level
unit has four feet, to level, however, the "shock absorbers" with in the unti may have come undone, try removing the lower acess panel( 3 torx 20 screws) across the bottom front of unit, youl be able to see inside and posibly locate the broken shock(s)
Apr 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
HOW DO I GET FRONT PANEL OFF OF WHIRLPOOL DUET TO GET TO MOTOR CONTROL UNIT
If the model number is correct, the Motor Control Unit (MCU) is located in the bottom of the washer on the right hand side (as viewed from the front). You can access the MCU by removing the lower toe panel under the door, or by removing the back panel of the washer.
The access screws for the toe panel are under the bottom front edge of the washer. You may have to prop the two front feet of the washer up for better access (a 2x4 works well for this). With the screws removed, the panel will drop down, then come off.
The removal of the back panel should be self explanatory. Just remove the screws around the entire perimeter of the back panel and remove.
HINT: It may be easier to remove the front and back panels to have full access to the MCU from both sides.
The following websites have excellent exploded view parts diagrams of your washer to assist you in locating and properly identifying the components of your appliance:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
The MCU is listed as item 1 under the "Pump and Motor Parts" section.
If you have any questions about this repair, please post back and let me know. I hope this is helpful to you.
Apr 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer error code is F 11. will not let me reset
There is a small cover on the front bottom of the washer. Remove it and there should be a door release rod that you can pullto unlock
Apr 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet washer is not draining. I am
If you hear the pump running and not draining, then take the toe panel off. Should be 3 1/4" screws on bottom. Remove the "coin catch". It looks like a BIG screw and it's white. Turn counterclockwise. There may be a sock, change ect...clogging it up. Dump it out and run machine. Have towel or bucket ready when removing coin catch.
Mar 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet how to enter diagnostics
look for tech sheet. this will tell you how to enter machine into service mode. Its located either behind bottom kick panel. or under top panel.
Feb 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
722 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
