Question about Sony KP-61V75 61" Rear Projection Television
Perfect Picture, but no color. Tried adjusting convergence with no success.
  • 1 more comment
  • cyclicinfini Apr 25, 2010
    I would like to make the repair myself, a service manual would be essential.
    Herb
    Is the color wheel referenced by any other name, I see nothing in the service manual that references the color wheel that you mentioned.
    Herb
    Thanks, the pictorial cleared up a lot of questions.
  • 4,889 Answers
You have the inevitable color wheel problem. The DMD module reflects the picture on to the color wheel which spins at a high speed of several thousand RPM. When the motor is damaged or the wheel itself is damaged you will have problems like the one you are having. You can get one along with the motor for under 200$ and not a very tough repair but its slightly tricky as getting it into the housing is slightly tough. A tv tech would charge you about 100$ for this or if you wanna do it yourself a service manual will be of mighty help. I will see if I got one if you want to DIY.
Sai.
Posted on Apr 25, 2010
  • 2 more comments
  • eagle338
    eagle338 Apr 25, 2010
    Uploading it now. Will get you the link as soon as its done.
  • eagle338
    Here's the service manual
    http://www.mediafire.com/?zyhnuxw0xuz
  • eagle338
    No it is just called color wheel. In a rear projection tv it is found near the ballast behind the set. The Service manual must have skipped it. regardless of the brand it is located at the same location in an RP tv.Only the number of screws/locks will differ while sliding the chassis out. Here is a nice pictorial for you
    http://www.jangro.com/electronics/samsun...
  • eagle338
    eagle338 Apr 26, 2010
    Cool1 Good luck with the repair..
My hitachi big screen has red shadows on picture how do i fix it
What you described sounds like a convergence problem. When convergence has failed the colors will commonly look 3D,warped, etc. This tips page here on Fixya has more details.
Jan 27, 2013 | Hitachi 43FWX20B 43" Rear Projection...
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Picture is bowed at top and bottom picture perfect in middle of screen; colors seperating in corners convergrence is perfect
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Nov 01, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
Fuzzy picture
never adjust the tubes themselves( No-NO) these are affixed to the chasis in one position and not to be moved. no adjustments should ever be attempted to anything directly attached to the tubes. this will throw off centering, soft-focus, & convergence alignments. it can be corrected but a huge burr on the bottom of the foot! what you have are faulty convergence ic's and maybe sme low-ohm resistors that are bad. repair in-home should not exceed 350.00. parts and labor. mch
Mar 09, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Blue convergence
DO you have 2 possible solutions
1.--Look under the CTR ( picture tubes) for leak coolant , all the times this set leaking, if is positive, use alcohol 90% with a bottle spray, clean the area, tied screws gasket ctr and let dry for 6 hours minimum.
2.--Loose connections on the left chassis ( convergence board), re solder ( look for possible resistor born)
Aug 05, 2008 | RCA P52926 52" Rear Projection Television
Picture color
I discovered that the red input from my DISH receiver had come loose. I plugged it in and all is well.
Certainly glad I didn't call a technician out!
Feb 11, 2008 | Panasonic PT-65WX51 65" Rear Projection...
Bad ghosting of all colours
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 09, 2008 | Samsung PCL545R 54" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
