Question about Dymo LabelWriter 400 Thermal Printer
Network instalation i am trying to install the program on one computer, the printer is on another on a home ethernetwork, the printer is shared and shows on the network map, but isnt an option on the instalation,,under lan,, please help
    Genius:
  • 1,913 Answers
Hi
u know IP ADDRESS OF SYSTEM WITH WHICH SHARED PRINTER CONNECTED.THEN GO TO START MENU RUN UTILITY
THEN RUN THAT IP ADDRESS PRESS ENTER
U GET YOUR SHARED PRINTER THEN RIGHT CLICK IT AND CONNECT IT THEN PRESS YES TO INSTALL PRINTER.
YOUR PRINTER IS CONNECTED .
BYE
Posted on Mar 23, 2008
    Genius:
  • 3,587 Answers
Hmmm..ok...i'm assuming you can see that printer through your workstation, right? then the reason the lan can't is due to the sharing settings for the printer. open it under printers, and set the sharing,
let me know if that helps you
SOURCE:
Printer sharing
Sounds like You have it installed via network share so it's no in real term installed on your computer ,to delete it rift click in the printer icon and press delete
Oct 11, 2013 | Kyocera FS Office Equipment & Supplies
CAN THE DELL AIO 948 PRINTER BE USED FOR SHARING
Yes, If it is connected to a computer on your home network, right click the printer, setup sharing. For example, if you have a laptop on the same home network, Add a network printer to the laptop and print wirelessly without a wireless printer. This may help clarify: http://windows.microsoft.com/en-US/windows7/Install-a-printer-on-a-home-network OR http://windows.microsoft.com/en-US/windows-vista/Install-a-printer-on-a-home-network
Dec 31, 2012 | Dell 948 All-In-One InkJet Printer
I am installing Kodak ESP-C310 All In One Printer on my home computer. If I want to use this printer for more than one computer (I have 3), do I need to load it on all three? I am using a wireless setup.
For best results, yes. I'll assume you're using a Microsoft operating system. You'll have to "share" the printer from the computer it is connected to by setting the appropriate options in the printer settings. Then, on the other networked computers, you'll have to add a "network printer" and provide the drivers when prompted.
http://www.microsoft.com/windowsxp/using/networking/expert/honeycutt_july2.mspx http://windows.microsoft.com/en-US/windows-vista/Install-a-printer-on-a-home-network
Note: There are other ways to do this as well. For instance, if you router has a usb port, it may be capable of sharing the printer for the network or if all your computers have wifi NICs, that printer supports simply browsing for it wirelessly and will install itself if you're running Windows Vista and up. XP will probably still ask for the driver.
Mar 14, 2011 | Computers & Internet
How to conect a printer
Install a printer on a home network
There are two basic ways to make a printer available to the PCs on your home network:
  • Attach it directly to one computer and share it with all the others on a network.
  • Connect the printer as a stand-alone device on the network itself.
This article explains how to do both in Windows. However, you should always first consult the information that came with your model for specific installation and setup instructions.
Setting up a shared printer
Traditionally, the most common way to make a printer available to a home network has been to connect it to one of the PCs and then tell Windows to share it. This is called a shared printer.
The advantage of sharing a printer is that it works with any USB printer. The downside? The host PC always has to be powered up, otherwise the rest of the network won't be able to access the shared printer.
In previous versions of Windows, setting up a shared printer could sometimes be tricky. But a new home networking feature in Windows 7 called HomeGroup has greatly simplified the process.
When a network is set up as a homegroup, printers and certain files are automatically shared. (To learn more about what homegroups do and how to use them, go to the Windows website and search for "HomeGroup: Recommended links.")
If you've already set up a homegroup and want to access a shared printer from another homegroup PC, just follow these steps:
To manually connect to a homegroup printer
  1. On the computer the printer is physically connected to, click the Start button ?id=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33, click Control Panel, type homegroup in the search box, and then click HomeGroup.
  2. Make sure the Printers check box is selected. (If not, select it, and then click Save changes.)
  3. Go to the computer you want to print from.
  4. Click to open HomeGroup.
  5. Click Install printer.
  6. If you don't already have a driver installed for the printer, click Install driver in the dialog box that appears.
    Note
    • After the printer is installed, you can access it through the Print dialog box in any program, just like a printer that's directly connected to your computer. The computer that the printer is connected to must be turned on to use the printer.
Setting up a network printer
Network printers-devices designed to connect directly to a computer network as a stand-alone device-were once found mostly in large offices. No more.
Printer makers are increasingly offering inexpensive inkjet and laser printers that are designed to serve as network printers on home networks. Network printers have one big advantage over shared printers: they're always available.
There are two common types of network printers: wired and wireless.
  • Wired printers have an Ethernet port, which you connect to your router or hub via an Ethernet cable.
  • Wireless printers typically connect to your home network using Wi-Fi or Bluetooth technology.
Some printers offer both options. The instructions that came with your model should tell you exactly how to install it.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Devices and Printers.
  2. Click Add a printer.
  3. In the Add Printer wizard, click Add a network, wireless or Bluetooth printer.
  4. In the list of available printers, select the one you want to use, and then click Next.
  5. If prompted, install the printer driver on your computer by clicking Install driver. ?id=18abb370-ac1e-4b6b-b663-e028a75bf05b If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  6. Complete the additional steps in the wizard, and then click Finish.
    Tips
    • Make sure that you have permission to use these printers before adding them to the computer.
    • You can confirm the printer is working by printing a test page. For details, see Print a test page
Feb 14, 2011 | Acer Aspire One PC Notebook
How czn i install my printer so that can network
You first need to check if the printer is compatible with Vista. Then, if it is,Install the printer on one of the machines. Once it has installed, go into printers and right click on the printer itself, then select Sharing or Sharing and Security and allow the printer to be shared. You may have to switch on file and printer sharing before you can share the printer. Then, go onto the other machine and go to install printer. In the dialog window that opens, choose network printer and then search. When the printer appears in the search area, select it and choose install. The system will then download the appropriate drivers from one machine onto the other through the network and install the printer. This assumes that you have both machines connected to your home network and file and printer sharing is turned on, on both machines. To use the printer over the network, the machine the printer is connected too MUST be turned on.
Dec 12, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Remote printing was working and then it stopped.
If this is a network printer. You can reinstall the drivers that came with the printer as a local printer, then go into control panel open the 'printers and faxes' right click on the printer that you reinstalled, 'properties' go to ports tab, select add port, -> 'standard tcp/ip port' -> 'new port' -> next -> put in the ip address for the printer, it will be the scheme of you subnet for example if your ip address for your computer is set to 192.168.1.1 you would use the ip address for the printer port of 192.168.1.2. after that is done press next-> after that you will be set as a network printer. Try to print a test page.
If this does not work, you can install the printer locally on a separte computer, such as your home pc, and make the printer a share. Then simply add the share printer on your laptop. for example; after you install the printer on your home pc, go under control panel, -> right click the printer -> sharing-> enable printer sharing... -> Next -> You will be prompted on the sharing tab-> select 'share this printer' -> type a share name, such as 'Lexmark2' -> click ok. at this point you will see a hand under the printer, showing it is shared.
Note: you will need to get the computer name of the pc that the printer is locally installed, your home pc. for this example lets name the pc 'home' you can find the name of your pc by right clicking on my computer and select properties. go to the computer name tab.
also remember we named the printer share 'lexmark2'
now go to your labtop, go to the control panel and select 'printers and faxes' select add a printer on the right column. a windows will pop up, click next -> select 'A network printer, or printer.....' click on the radio buttion that reads 'Connect to this printer (or to browse.....' should be the 2nd option. this is where you are going to use the computer name and printer name.
put in
\homelexmark2
click next -> then finish
print a test page, from your labtop.
If you need further help please contact me.
[email protected]
Dont forget to vote!
Sep 06, 2009 | IBM ThinkPad T61 Notebook
Home Network sharing issues using 2wire wireless modem
Did you manually assign the IP address to your shared devices? If so, the Linksys and the 2wire have different IP schemes.
2wire Gateway IP address:
192.168.1.254
255.255.255.0
Do an ipconfig /all on your computer and compare it to the ip scheme on your devices.
Feb 07, 2009 | 2wire 2700HG-B Router (2700HGB)
How to install the lexmark E120 network printer
to clarify this, you need to install the printer in a computer that is connected to a Local Area Network lets call it computer 1. Once the printer is connected to the computer 1, share the printer by going to the start/settings/ printers. Right click on the lexmark e120 printer and click share. Click share this printer. Once done the printer that is connect to computer 1 is now on the network. on the other computer lets call it computer 2, to to start/settings/printer and click add printer/ select network printer and then browse the printer in the network and select it so that it will be added. Now you computer 2 has a network printer installed. try printing, make sure not to turn off the computer 1 when printing, or else it wont print.
Dec 22, 2008 | Lexmark E120n Laser Printer
Setting up 16 port switch
Dear This is the step You can get a complete home network up and running in 10 easy steps. Here's a summary of what's involved: Take stock of your existing hardware. If you wish to share an Internet connection using Internet Connection Sharing (ICS), choose which computer will be your ICS host. Decide what type of network technology you wish to use. Make a list of the hardware you need for each computer. Install the network adaptors and install your modem on the ICS host computer. Physically cable the computers together. Switch on all computers, printers and other peripherals. Make sure the ICS host is connected to the Internet. Run the Network Setup Wizard on the ICS host. Run the Network Setup Wizard on the other computers on the network. Let's take that step by step. 1. Take stock of your hardware Note each computer's location and its hardware, including peripherals such as printers and modems. 2. Choose your ICS host If you wish to share an Internet connection between your computers using Internet Connection Sharing (ICS), choose which computer will be your ICS host. The ICS host has a direct connection, either by dial-up modem or high-speed link, to the Internet and provides access to the Internet for other computers on the network. Ideally, the host should be a computer running Windows XP. I'll assume you have made this choice in the following steps. Apart from XP's easy handling of ICS, by using an XP computer as your ICS host you get the benefits of using the Internet Connection Firewall. 3. Choose a network technology The most common choices are Ethernet and wireless LANs. For an Ethernet LAN you will need to install a network interface card, or NIC, in each computer and run cabling between the computers. If you don't like the idea of opening your computer to install a network card, look for a USB adaptor instead. Depending on the size of your network, you may also need a network hub or router to provide interconnection between PCs on the LAN. Two PCs can get by using an RJ-45 crossover cable; three or more computers require a hub or multi-speed hub (called a switch). If you have a high-speed Internet connection, a high-speed router is a good option. The Network Setup Wizard includes links to detailed advice about configuring your network, including help on designing a network layout to suit your home. If you opt for a wireless LAN, you'll also need a NIC for each PC (there are versions which use USB adaptors as well). The big benefit for home environments is that a wireless LAN does away with the need for cabling. On the down side, though, wireless LANs tend to be slower, less robust and appreciably more expensive than traditional Ethernet LANs. In particular, wireless LANs do not always live up to their stated working range, and you may find factors such as your home's construction and design, plus interference from other devices affect your wireless LAN's performance. You may need to add an expensive Access Point to extend the range of the LAN and, even so, it may not be sufficient. The bottom line is, if you decide to go the wireless route, make sure the store will refund your money if the LAN will not provide reliable performance within the specified range. 4. Make a list of hardware needed Make a list of the hardware you need for each computer, not forgetting any cabling, and buy it. If you're a little dazzled by the choices and configurations, consider purchasing a networking kit. These kits contain all you need to set up a two- or three-PC network. If possible, look for hardware which features the Windows XP Logo, indicating it is fully compatible with XP. 5. Install the adaptors Install the network adaptors and install your modem on the ICS host computer (you can also let the computers connect to the Internet independently by installing modems on each). 6. Cable the computers Physically cable the computers (and hubs or routers) together. Of course, you won't need to do this if you've chosen to go the wireless route. If you're installing an Ethernet network and have a lot of cabling work to do, you may prefer to get a professional to come in and do this work for you. It won't be cheap, but you can be sure you get the job done correctly and hopefully with minimal damage done to walls, ceilings and floors. 7. Switch it on Switch on all computers, printers and other peripherals. 8. Connect the ICS host Go to the ICS host computer and make sure it is connected to the Internet. 9. Run the Network Setup Wizard on the ICS host To run the Network Setup Wizard on the ICS host, click Start -> Control Panel -> Network And Internet Connections -> Setup Or Change Your Home Or Small Office Network. Follow the instructions in each screen and press Next to continue. XP's Network Setup Wizard takes much of the pain out of setting up a home network. The Network Setup Wizard will guide you through: Configuring your network adaptors (NICs). Configuring your computers to share a single Internet connection. Naming each computer. (Each computer requires a name to identify it on the network.) Sharing the Shared Files folder. Any files in this folder will be accessible to all computers on the network. Sharing printers. Installing the Internet Connection Firewall to guard you from online attacks. 10. Run the Network Setup Wizard on all computers To do so: Insert the Windows XP CD in the first computer's drive. When the XP Welcome Menu appears, click Perform Additional Tasks. Click Setup Home Or Small Office Networking and follow the prompts. Repeat steps 1 to 3 for each computer on your network. Make sure you maintain an active Internet connection on your host computer as you proceed through this process. geekgirl.tip If you don't have a CD-ROM drive on one of the network computers, you can run the Network Setup Wizard from a floppy disk: While running the Network Setup Wizard on the ICS host computer, select the option to copy the Network Setup Wizard to a floppy disk. Once you've completed setup on the ICS host, take the floppy to the next computer and insert it in the drive. Double-click My Computer. Double-click 3½ Floppy (A:). Double-click netsetup.exe. The quickie XP network If you want a really easy networking experience and you have the hardware to support it, consider clean installing Windows XP on two or more computers. First install your network hardware (network interface cards, cabling, et cetera), then perform a new installation of Windows XP. During installation, XP will sense your hardware setup, ask for a name for each computer, and then ask which type of setup you wish to create. Select Typical Settings For A Default Network Configuration. That's it. Provided your hardware is XP-compatible, XP will create a LAN using the workgroup name MSHOME. Using your network Once you have your network up and running, you can easily access other computers on the network via My Network Places (click Start -> My Network Places). The Task Pane in My Network Places lets you access computers on your network and adjust settings. The Task Pane in My Network Places lets you view your network connections and view each of the computers in your workgroup (the workgroup consists of all computers on a network which share the same workgroup name ? by default, XP gives all computers on your home network the workgroup name MSHOME, although you can change this if you wish). When you initially open My Network Places, you'll see icons for the Shared Files folder of each of the active network computers. Sharing a printer With your home network installed, your PC suddenly gains all the advantages of the other PC's on the network. If you've been lusting after your sister's colour photo printer, you can now print directly to it from your own machine. Provided, that is, your sister decides to share her printer. (You might offer to let her share your laser printer in return as an inducement ? sharing works both ways.) To share a printer, on the computer which is directly connected to the printer: Click Start -> Control Panel -> Printers And Other Hardware -> Printers And Faxes. (Note: These steps will be a little different if you're sharing a printer on a PC running a version of Windows other than XP. For example, under Windows Me, you click Start -> Settings -> Printers.) Click the printer you wish to share. Click Share This Printer in the Task Pane. In the printer's Properties dialog, click the Sharing tab. Click Share Name and OK. Make a printer accessible to others on the network by sharing it. Once a printer has been shared you can access it from other computers on the network. To do so: Click Start -> Control Panel -> Printers And Other Hardware. Click Add A Printer. In the Add New Printer wizard, when asked whether the printer is a local or network printer, select the latter. In the next screen, select the option to Browse For A Printer and click Next. Select the appropriate printer from the list and continue with the wizard. Sharing files and folders Sharing a folder is even easier than sharing a printer: Open a folder (such as My Documents), click Make A New Folder in the Task Pane and name your new folder. With the new folder highlighted, click Share This Folder. In the Sharing tab of the Properties dialog box, select Share This Folder On The Network. Provide a descriptive name for the folder. This name should make it easy for others on the network to recognise the folder; it doesn't have to be the same as the folder name you selected in step 1. You can let other people on the network view and edit your files or view them only. If you want to protect your files from tampering, remove the tick from Allow Other Users To Change My Files. There are a variety of ways to access a shared folder. Here's one way: Click Start -> My Network Places -> View Workgroup Computers. Click the computer whose files you wish to access and then click the shared folder. You can create shortcuts to shared folders to make them easier to gdfgf
Sep 08, 2007 | Computers & Internet
Dymo LabelWriter 400 Thermal Printer Logo
250 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Steve Allison
Steve Allison
Joaquim Martins
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
