Question about Canon Pixma iP6600D InkJet Photo Printer
Paper will not feed through. The roll bar that normally grabs the paper will not move any quick fixes for this.
    Scholar:
  • 59 Answers
If you can get to the rollers, get some fine grit sand paper and rough up the surface a little (Make sure you do it even around the roller, and on all rollers).
I had a similar problem on an old Xerox multifunction fax / printer and it worked fine.
Good Luck
Posted on Apr 25, 2010
I have an old Sharp EL-1701C calculator and for some reason can not feed a new roll of paper into the unit? Batteries are new and the feed option works well, just doesn't grab the paper roll to start?
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
Dec 10, 2014 | Sharp EL-1701C Calculator
Paper will not feed
Both paper tray and rollers are spring loaded.
If you have paper stuck in the feed area, it will not pick up paper.
Try removeing all from unit and power blowing the inside try area.
Feb 11, 2014 | HP Laserjet Pro Cp1025nw Color Printer
Mp 530 error code 103.0.0
you will see small levers were the paper passes. check if one of them are not stuck.
Oct 20, 2011 | Canon PIXMA MP530 All-In-One InkJet...
It will not feed the paper to start printing. It says that it is out of paper. How do I fix this?
Check the paper supply tray and look inside. I'm assuming it's a vertical feed - look down into it and check the take-up roller. Make sure it springs towards the paper as if it will roll and grab one sheet. Sometime the roller gets stuck - reach in and try to make it motion in both directions.
Nov 19, 2010 | Dell Office Equipment & Supplies
My printer won't feed the paper through. the spindle rolls but won't grab the paper in the paper feeder
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle white roller. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned.
Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Please remove the paper access door from back of the printer and clean the white rollers inside with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust, close the paper access door. Reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Turn the printer ON.
2. Press the down arrow button till the screen displays “Maintenance". .
3. Press the "Check" button.
4. Press the "Down arrow" button till the screen displays “Print Test Page.”
5. Press the "Check" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed.  If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 02, 2009 | Lexmark X7550 InkJet Printer
Fax will not grab paper
Ther is a separation pad that developes a divot caused by the feed roller. Simple fix. order a new separation pad. It's located under the top cover. Just move slowly and identify the latches that hold the cover down. Don't force anything.
Another possibilty. If a document was forcably pull out of the document area the "White paper bar above the scanner glass might have been jerked out of it's normal position causing a blockage in the path. Investigate this possibility before ordering parts.
Jun 15, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
BOUGHT A HR-8TE CALCULATOR AND CANNOT INSTALL THE PAPER ROLL
The V tip worked...but cut it not fold it like I first tried to do...and it worked perfectly
Mar 17, 2008 | Casio HR-8TEPlus Calculator
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Canon Pixma iP6600D InkJet Photo Printer Logo
124 people viewed this question
old marine
old marine
