Question about Siemens Washing Machines
I have a siemens WDI 1440 and it has just stopped
I have a siemens WDI 1440 and whilst drying my washing it suddenly stopped and started flashing E06 across the screen. I am unable to open the door and no other programmes work. The countdown timer does however work but as soon as it gets near to the end of the cycle it stops and shows E06 again. The machine doesn't spin either.
It did however wash the clothing perfectly but as it neared the end of the cycle it made a very loud whirring sound but did not cut out.
Is the machine completely broken?
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
SOURCE: bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Posted on May 11, 2008
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Posted on Sep 21, 2008
  • 53 Answers
SOURCE: Hotpoint BWD129. Door lock flashing rapidly,
sounds like your pump/filter is blocked. clean everything out.POWER OFF.
Posted on Oct 16, 2009
SOURCE: my seimens washer dryer - wdi 1440 - keeps coming
need step 7 v5.4 can you help
Posted on Nov 10, 2009
Siemens Wdi 1440 washer/dryer
It means your machine is not draining, Look out for the water exit open to drain water off.
Jul 21, 2014 | Siemens Computers & Internet
I have a siemens WDI 1640 washer/dryer which is
I managed to find out the fault code E14 relates to faulty Heating element, product code 494069, and have been quoted £65.00 + Vat for the Bosch replacement. I am yet to decide on how I will proceed.
Dec 29, 2009 | Siemens Washing Machines
I have a Siemens Washer/Dryer WDI 1440. The problem is that when I put it to dry, no heat is produced and my clothes are staying wet. What do I do? Many thanks
take top off. you will see dry manifold running across the top with various stats mounted on it. one of these stats will be resetteble ie with a small knob in middle. press and stat will reset. also check continuity thro the dryer heater and the other stats.
if a resettable stat has popped out, check also for lint blockage in the dryer duct
Nov 17, 2008 | Siemens Dryers
Washing Machines Logo
792 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
