Question about Panasonic Televison & Video
I need fitting instructions for a Aarton lcd mount 129...bought one new with all the bits but no instructions...thanks Ken
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Samsung 101cm lcd Mounting??
Yes they are the mounting holes but I would not trust a universal mount to hold an expensive TV set on a wall.
Posted on Nov 27, 2007
SOURCE: attaching the portable friction mount
It should be the same as mounting it to the suction mount that came with the 660. Check the sizes, they should be the same. There are instructions on the supplied cd, but also in the built-in memory, visible when you connect it to your computer, and if that is missing, on Garmin's website. It does take some force, but it shouldn't feel like it's going to break something.
Posted on Apr 17, 2008
wiqi546
  • 1511 Answers
SOURCE: how do i fit a new screen to a nokia 6500s
You can check a pictorial representation here
Note: Always user proper tools to disassemble, otherwise you will end up in further trouble.
I hope this will help you out.
IF your Problem was solved, Kindly do Rate!
Regards, WAQAR.
Posted on Oct 26, 2009
Cannot put new hoses on the carb. I didn't take them off, and don't know what hose goes to the tank, primer, etcThank YOU KEN
Hi Ken,
If this is a chainsaw, you have fuel filter in the gas tank. Take the fuel filter with you when go to pick up new line. If it fits the filter, it will fit the rest.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 14, 2011 | Garden
I cannot running my scanner (UMAX 6700) on my Windows7 64 bit with 32 bit photoshop pragram and I found eror code 129. I wish anyone in FixYa could help mu problem. Thanks
Hi
in order to run 32 bit programm you need 32 bit opareting system
or 64 bit program you need 64 bit system
download from canon oficial site the 64 bit software
Jan 23, 2011 | Umax Astra 6400 Flatbed Scanner
Cant fit nania first car seat
We just fitted our 'new' secondhand narnia yesterday with instructions and it was a bit of a fiddle, but once in was very secure. Place the lap/diagonal belt through the slot in the back so that it comes out the front, it then goes over the arm rest, back through the other slot, across the back of the seat, then through the slots in the other side over the arm rest again and click it in.
May 15, 2009 | Nania Dreamer LX
Nikon D40 I bought a set of macro lenses that said they were compatible for the d40 but i cannot figure out how to fit them. They are 52mm lenses - should i have bought an adaptor or something? where...
Macro lenses are mounted to your camera body in place of the lens you currently have mounted on the camera. If you bought the camera with the lens already mounted you may not have realized that the camera and lens are 2 separate objects. To remove your lens see page 8 in your user manual for instructions and an illustration. If you don't have your user manual handy, you can download a PDF file from NikonUSA Here.
If what you bought are macro rings, they go on the camera, then your regular lens mounts onto the ring. You can use one or more of the rings between the lens and camera to produce different macro settings.
If what you bought are macro filters, they screw on to the front of your lens. If you have a UV filter on your lens you need to remove that before you attach another filter.
Dec 22, 2008 | Nikon Cameras
Attaching the portable friction mount
Apr 12, 2008 | Garmin Nuvi 660 GPS Receiver
42'' LCD PLTV-4250 MOUNTING
The universal mounts generally have a selection of screws that are to fit different makes and models of tvs.
If you bought the appropriate size mount for the size of your TV, there should be mounting holes that match your TV, and screws that will secure it.
I have not seen any mounts that use more than four.
Apr 07, 2008 | Protron PLTV-4250 42 in. LCD Television
Nov 26, 2007 | Televison & Video
Kenwood microwave (KEN GJ/SS25) heating doesn't work but grill works
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 24, 2007 | Sharp R-303CW Convection / Microwave Oven
Wall mounts
i had the same problem! return the tv and get a different one! ilo tv's are useless!!!!
Jan 13, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
793 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
