Question about Whirlpool Duet GHW9150P Front Load Washer
During cycle...F11 is showing on panel. What does
During cycle...F11 is showing on panel. What does that mean???
  • 5,081 Answers
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
If all the connections look fine , then its possible the CCU is reading wrong and will need to be changed
Posted on Apr 25, 2010
Indicator light showing F 11 what does this mean
one might be able to find out if one had a make /model shown to us
Jul 31, 2016 | Washing Machines
Error F11 during the wash cycle
The error means that the controller is not talking to the other components. It is very expensive to repair,. If you want to run tests on it, there is a tech sheet behind the kick panel under the door.
Feb 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Flashing F 11, drum spins by hand.unplugged for 30 sec and plugged back in started to fill then stopped .flashed F11 again
The F11 error can be difficult to resolve even for us technician's.
The F11 error occurs when the central control and motor control don't talk to each other.
If one of the controls was actually bad then I'd expect to see the error code every cycle. If it does, start by checking all the wiring connections from the panel to the CCU. Post back your results.
Dec 02, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My front loader wirlpool washer is having problems it starts out fine then it flashes a F- symbol. And does not finish spin cycle. Why? And what does that. Mean?
The F is showing up saying there is a fault somewhere. Since you don't say what comes after the F code (F11, FdL, Etc) it's hard to say what the problem is. If you remove the lower panel below the door (3 screws at bottom of machine) ther should be a packet taped to the inside of the machine. This is the repair guide for the machine and it says what the different codes mean. Good luck.
Jan 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F11 washer stops mid-cycle
The F11 code means that communication between the CCU circuit board at the top of the machine and the motor control circuit board at the bottom of the machine has been lost. The problem most often found is cold solder joints on the CCU board that make and break causing the F11 code and sometimes an FdL code. To fix this you need to remove the CCU circuit board at the top of the machine and have the larger solder points of the relays and the spade connectors resoldered. If your not to handy with soldering you could just print out this response and a good appliance repair shop should be able to help you out. Good Luck.
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer is flashing F and H
F11 and FH are two completely different error codes. "F11" is a Serial Communications error between the Central Control Unit (CCU), the Motor Control Unit (MCU) and/or door latch. The "FH" error is a No Water Detect error code that means the CCU is not detecting ANY water or INSUFFICIENT water during the fill cycle. The following two links explain each error code and some things to look for to diagnose your problem:
"F11" Error:
http://www.fixya.com/support/r3608695-f11_error_code
"FH" Error:
http://www.fixya.com/support/r3608753-fh_error_code
Read through the information provided and let me know if you have any questions. I hope this helps you.
NOTE: There is a technical data sheet inside the washer that explains all diagnostics procedures, troubleshooting tips, error code explanations and wiring diagrams. To access, remove the lower toe panel under the door by locating and removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off. You can prop the two front feet of the washer up for better access to the panel screws (a 2x4 works well for this). The tech sheet should be located directly behind the panel, or affixed to one of the cabinet interior walls. I hope this information is helpful.
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The water is not draining during the spin cycle. I'm getting an error message f11
F11 means there is a serial communication error. The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. Check the wire harness connectors to the MCU, the motor and the CCU. Check the drive system for any worn or failed components. Check the MCU, the CCU, the motor and the wire harness.
Nov 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
F11 occurs during spin cycle what can i do?
hello f11 means serial communication error. the central control unit (ccu) and the motor contol unit (mcu) cannot be sent correctly things to check / check the drive system for any worn components check ccu/mcu check motor check wire harness i hope you get it sorted
shaun
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
