Question about GE JGBP28 Gas Kitchen Range
I spilled water on the range. 3 burners have blue flame BUT 1 has orange flame. What do I do?
    President:
  • 2,468 Answers
You need to clean out that particular orfice with an orfice wire cleaner available thru a welders supply or appliance parts store as the water minerals have dried and partially plugged the orfice tube and it can't get the right amount of air to burn the gas completely
Posted on Apr 25, 2010
Why does my burners not ignite into a blue flame
The color of the flame can be affected by a few different things. here are three of them: 1. If there is a food substance contacting the burner where the flame comes out, this will give the flame an orange tint. 2. If the propane is being burned at a very high rate, the flame can become invisible in daylight-like conditions. 3. If the propane is being burned at a very low rate it can also have an orange tint. Hope this is clarifying.
May 24, 2014 | American Range AF45LP Deep Fryer
The flames from the front left burner is 1/3 orange and 2/3 blue; whereas the flames from the other burners are all blue. There is a strong odour from the front left burner when we turn it on and also the...
The flames should be all blue - except when you first turn it on, where the flame begins, & only when you turn it on. Orange flames mean incomplete combustion is happening. Carbon monoxide is being released. Orange flames can also mean your getting low on gas. Clean it & try moving the disk around. An uneven disc means some flames will be higher & burn your pots. The flames are wrapping around your pots if they're burning on the sides. Keep flames under the pot. Regardless of the being clean, the odor means you need to check your gas level. Once filled back, the odor should be gone if that's the only problem. That is placed in the gas as a safety feature. Don't try to fix this problem yourself if the "easy" solutions don't work. It could be very dangerous. Invest in a carbon monoxide detector especially when you have anything gas.
Sep 15, 2011 | GE Profile JGS968 Gas Kitchen Range
Large flames licking the sides of our oven from under the flame spreader. We adjusted the burner as close to mostly blue flames as possible but there still is a lot of white flame. It seems extreme. How do...
Something spilled and got into the burner assembly. You will have to remove the assembly and clean it. It's not a difficult job and most burners can be removed in just a few minutes without any tools.
Your manual should tell you how to remove it ... if not then go on line to your manufactures web site.
Feb 15, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Dynasty gas range - orange flames
It is normal, it will disappear after a little while, when you bang on the burners, particle fell off form inside of the burners and it caused the orange flame. Yellow flame means not enough air or burner is internal clogged.
Feb 15, 2010 | Dynasty DGRSC 36-6 Gas Kitchen Range
Top Burners have a poor flame. How do I access the burners to adjust the flame ?ps No Owners Manual available. Tappan Millennia.(w/digital clock.)
you dont adjust the burners,either you have dirty burners and need service or your gas pressure is wrong,is the flame blue?or has it some orange flickers in with the blue,then you need to clean orfices and tubes
Jul 16, 2009 | Tappan TGF320 Gas Kitchen Range
Burner flame orange instead of blue, problem just started today
The only thing that i can think of is that it is not hot enough. try turning up the heat. Orange fire just means that it is not as hot as the blue fire.
May 21, 2009 | Maytag MGR6775BD Gas Kitchen Range
Kenmore range broiler burns orange not blue and leake gas
The only real important thing is blue flame with a orange tip,
also ranges have different nozzles for Natural Gas (NG) or propane(LPG)
he can check for leaks with soapy water at the flex line connection
Jan 05, 2009 | Kitchen Ranges
JGBP89SEMSS BURNER HEIGHT
Sounds right long as you did the conversion okay did you change the spring in the reg ? lp gas does burn lower than nat gas smaller blue flame . you could see if the aeration can be adjusted to the burners You could also check the pressure at the burners lp working pressure is 14in wg .
You could check the reg outside . That's all I got .
Mar 17, 2017 | GE JGBP88SEKSS Gas Kitchen Range
GE JGBP28 Gas Kitchen Range Logo
120 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
