Question about Dell OptiPlex GX260 PC Desktop
Hi, will a Sata hard drive with Sata to IDE converter work in an Optiplex GX260?
    Scholar:
  • 59 Answers
If you have enough room for the converter and power adapter you should be fine. Note that the speed of the drive will be reduced to that of the IDE converter which will be slower than a direct SATA interface.
Good Luck
Posted on Apr 25, 2010
HDD Upgrade
That model has standard IDE interface for hard drive. Don't think 500 GB or higher comes with that interface. The standard now is SATA interface for hard drives. Here is a lnk to the owner's manual for you model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-gx60_user%27s%20guide_en-us.pdf
You tell the difference between standard IDE and SATA in that the standard IDE interface uses a wide flat ribbon cable to connect to the drive. SATA uses a small thin cable as shon in the following link:
http://www.google.com/imgres?imgurl=http://www.cooldrives.com/lib/cooldrives/ultraflex-sata-cable-2.jpg&imgrefurl=http://www.cooldrives.com/24seatsaiiul.html&h=514&w=600&sz=35&tbnid=wGLj8F1otpnJYM:&tbnh=97&tbnw=113&prev=/search%3Fq%3Dwhat%2Bdoes%2Ba%2Bsata%2Bcable%2Blook%2Blike%26tbm%3Disch%26tbo%3Du&zoom=1&q=what+does+a+sata+cable+look+like&usg=__57zU4K_H2rpvq5AyZ41v_Ag4RTk=&docid=m3f9D21nEcMb3M&hl=en&sa=X&ei=NZQVUbrfDJD49gSd44CAAg&sqi=2&ved=0CFkQ9QEwBA&dur=81
Feb 07, 2013 | Dell Optiplex GX60 PC Desktop
My dell optiplex GX260 computer cannot see the ATA hard drive
Make sure that the drive is connected in the primary IDE connector. Also put the jumper at the back of your drive to "master".
May 30, 2012 | Dell OptiPlex GX260 PC Desktop
I have a Dell Optiplex 170L mnitower. It has one IDE and one SATA port. I have connected a 1 TB drive to the sata and disconnected the ide drive that came with the system. No I am thinking, what if I add...
Hi there! You don't actually need a IDE to SATA converter. If you purchase a RAID 1 card, it gets hooked up to your computer via PCI or PCI-E. The RAID card will have at least two SATA ports on it - those are what you use to create your RAID. The sata port and ide port on the computer will not be used in the raid1 configuration. If you're going to go ahead with this, I'd recommend trying to find the exact same brand and model of drive as the first one you have. Also, keep in mind that creating a RAID 1 array requires formatting BOTH drives. Your Optiplex 170 only has PCI ports, so this may be a viable RAID card. It is fairly inexpensive, but will do the job. http://www.newegg.com/Product/Product.aspx?Item=N82E16816132001&cm_re=PCI_RAID-_-16-132-001-_-Product If you need any more help/advice let me know! Alex
May 30, 2011 | Computers & Internet
Dell Optiplex 260 IDE hard drive dead. Would like to replace it with external Sun Brite hard drive. Windows 2000 installation stopped because it couldn't gain access to ext. drive. Says that special...
Windows 2000 cannot access USB drives for installation.
You need to replace the dead drive with a new IDE or PATA drive. That machine will not accept an SATA drive.
Feb 03, 2011 | Dell OptiPlex GX260 PC Desktop
I want to get a new internal hard drive but I,m not sure of the hard drive interface type. The specs say Serial ATA 300. The drives I am looking at say SATA?
Dear friend. in fact Serial ATA is SATA.
and i checked your Hard drive out.
your hard drive uses SATA technology to connect with the PC.
please vote
Jan 15, 2011 | Dell OptiPlex GX260 PC Desktop
Can Vantec CB-IS100 IDE to SATA converter works to convert Motherboard ide port to sata or it made only for hard drives,cd-roms and DVD rom ?
It attaches directly to the drive, whether it be IDE hard disk or CD/DVD, and is used in boxes that already have sata connectors on the MB. Connector attaches to drive, cable from connector attached to drive to sata connection on MB.
Note: Sometimes these may not work (for a variety of different reasons).
Here is a link to one seller of the converter, read through the reviews. While it works well for most, sometimes there are issues.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232004
Dec 26, 2010 | Vantec CB-IS100 IDE to SATA converter IDE...
I have dell optiplex gx260 when i power it on its not respond and the fans not work only the light of power switch is being orange its flash, that it being on then off continously. please help me...
First test your PSU or replace it then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive or
replace them they are probably old and faulty ?
good luck
Sep 06, 2010 | Dell OptiPlex GX260 PC Desktop
Does the dell gx260 have a sata hard drive in it? or can it have one ?
This computer only has a IDE not SATA hard drive, for the complete details about this model you can check this link.
http://support.dell.com/support/edocs/systems/opgx260/en/ug/index.htm
Apr 30, 2010 | Dell OptiPlex GX260 PC Desktop
HP Pavilion 7955 main HD failed; my data is on second drive (Maxtor ATA/EIDE) - still good. I want to install this as a second drive in Dell Optiplex 620 which has SATA main drive. The only IDE cables are...
Most IDE cables have THREE connectors:
* one to the motherboard
* one to the "primary" device (CD/DVD or disk-drive)
* one to the "secondary" device (disk-drive or CD/DVD)
If your IDE cable only has TWO connectors, buy a cable with THREE connectors, and connect your disk-drive to the third connector.
Mar 03, 2010 | Dell Optiplex GX260 Refurbished Intel...
Dell OptiPlex GX260 PC Desktop Logo
204 people viewed this question
Alun Cox
