Question about Sony RCD-W10 2-Disc CD Recorder
Sony RDC W00
Hi have a new cd recorder but will not record plays both decs comes up data cd
    Problem Solver:
  • 18 Answers
Don't know if this will work, but I have an older JVC CD recorder, and it will ONLY record on CD's marked "MUSIC". Worth a try!
Posted on Mar 24, 2008
SOURCE:
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
I have a sony CFD-S01 which will play commercial cd's but when a cd-r is inserted it either won't recognize the disk or it jumps constantly after appros 10 sec, any ideas?
The CFD-S01 is designed for use with CD-R and CD-RW discs. With that in mind a few things come to mind. Are the CD-R discs you are using music or data discs? There is a difference and some CD players do not get along with data discs and won't play them well if at all. Also the burn rate used can have an effect - too fast and it won't play well. If a disc doesn't play at all it might not be finalized. A disc must be finalized on the recorder it was burned on before it is playable on any other machine.
Nov 27, 2010 | Sony Boom Box With CD Player & Cassette...
For sony rcd-w500c/w100 won't go to record mode.
Make sure you're using CD-R AUDIO or MUSIC blank discs. It won't record onto data discs.
Jul 20, 2010 | Sony RCD-W500C 5-Disc CD Recorder
Sony RCD-500C I get a data disc message when pressing record
It wants a CD-R Audio or CD-R Music blank disc to record on. It won't record on CD-R data discs.
Feb 28, 2010 | Sony RCD-W500C 5-Disc CD Recorder
Sony RCD-500C I get a data disc message when pressing record.
You need to use CD-R Music or Audio blanks, not Data. It's part of the spec for home CD recorders to reject blank data disks.
Jan 25, 2010 | Sony RCD-W500C 5-Disc CD Recorder
I want to hook up a RDC-W500C CD player/recorder to a Satellite recieverHD to a Philips 50PFP5332D/37 plamsa TV and a Panasonic DMR-EZ485VK DVD recorder Thanks much FCZimmerman [email protected]
HI THERE,
DID YOU HAVE THE USER MANUAL FOR BOTH OF THE UNIT,
YOU WILL NEED A INSTRUCTION MANUAL FOR THAT.
KINDLY ACCEPT MY SOLUTION AND I WILL SEND THE MANUAL INTO YOUR EMAIL
Mar 25, 2009 | Sony Audio Players & Recorders
GoVideo Dual Deck VCR Model#GV6015with one touch copy
It seems to be fixed. I ran a new tape through the machne as suggested. To be sure, I also used a VHS head cleaning cassette.Works fine, now. Thanks
Feb 22, 2008 | Televison & Video
Sony DW-Q30A Problem
the dvd writer needs to be replaced,the laser is faulty or miisaligned, the cost of a repair is no longer viable because a new one would cost about $60 (£32.00)
May 30, 2007 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Sony RCD-W10 2-Disc CD Recorder Logo
109 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
