Question about E-Machines eMachines Desktop PC
I have windows Vista OS, and some dll files are corrupt, is there a fix available.
  • Adnan Bhatti
    Adnan Bhatti May 11, 2010
    Search over the internet with the names of DLL files one by one. Hopefully you will find working files for download. Just replace the old ones with the new ones. If you cannot then use the Vista DVD to perform a repair install.
  • 358 Answers
Hello Abel,
Sorry about the problem.
I will try as much as possible to give you a detailed steps you can try.
Put on your Computer,
While it is booting, Keep tapping the F8 Key, and this will bring up the Menu where you will have to select the different options of booting.
Select safe mode.
If it boots in Safe Mode, then click on start---> Accesories--->System tools---> then System restore. Then restore you system to an earlier time.
Now, If that still doesn't work, then Select Safe mode Command prompt.
When you get to command prompt, type: chkdsk or chkdsk /f and press enter.
This will scan your system for errors and correct it.
If this still does not work,
Get a Windows Installations CD.
Insert it into your CDROM Drive, then when you put on your system,
Go into the system BIOS/Setup by pressing 'Del' key or any other key (e.g F10) required to enter setup, while the system is booting.
Now look for where you have Boot Sequence or Boot Order.
Select the CDROM to be the one where the system will boot from.
After selecting it, select save and exit.
Your system will then automatically reboot or restart.
Next follow the On-Screen instruction closely and press any key to boot from CD when you are prompted to do so.
Then follow the on-screen instruction again after it has finished loading the necessary drivers from the CD.
It will give you different options like Repair, Restore, Fully Restore to Factory settings e.t.c.
Just pick your choice, and repair it.
Meanwhile, PLEASE be VERY careful while you are doing this so that you do not format your system TOTALLY and lose everything on it.
Unless of course you have backed up your system first and you have ALL the necessary drivers.
Hope this helps you out.
Kindly keep me posted and let me know how it goes.
Thank you for using FixYa.
Good luck
Posted on Apr 25, 2010
    Guru:
  • 163 Answers
Cannot syart an 18+ game, applications says dll file is missing.
DLL stands for Dynamic Link Libraries and are external parts of applications that run on Windows or any other operating systems. Most applications are not complete in themselves and store code in different files. If there is a need for the code, the related file is loaded into memory and used. If the OS or software is not able to find the concerned DLL file, or if the DLL file is corrupted, you could receive a DLL file is missing message.
If DLL files are missing on your Windows computer, the best ways to fix such errors are as follows: 8 Safe And Useful Software Sites
  1. Run the built-in System File Checker tool to replace missing or corrupted operating system files
  2. Run the DISM tool and repair the Windows system image and fix a corrupted Windows Component Store
  3. Repair or re-install the software if some application throws up this error
  4. Copy the DLL file from another system and restore it on your PC, followed by re-registering the dll file.
Sep 24, 2017 | Computers & Internet
I have a MSI A6000 laptop. I recently had to set it back to factory restore.Now I get the message MagCore.dll is missing from your computer.Arccon.ac-system error.How do I fix this?
I strongly advise against fixing arccon.dll errors manually. Doing so could take several hours, do more harm than good, and end up not even resolving the underlying problem.
The most recommended solution is to use a reliable software application that can quickly diagnose and fix arccon.dll errors (and much more). Programs such as RegCure Pro run a variety of troubleshooting and diagnostic tests on your computer in order to pinpoint and fix almost all known issues. The result is an error free PC that is actually much faster than before.
Download available to fix arccon.dll errors. Recommended: To repair arccon.dll errors, use this software package: RegCure Pro. This repair tool has been proven to identify and fix arccon.dll errors and other Windows problems with very high efficiency.
Download Now
File Size 5.6MB Requirements Windows XP / Vista / 7 / 8 Downloads Over 500,000 Download Time Broadband: 6 sec / Dial-Up: 3 min End User License Agreement
Uninstall Instructions
Jan 31, 2014 | Computers & Internet
I got problem on SoundMAX.dll error
The missing dll SoundMAX.dll is the dynamic link library module of Staccato Systems SynthCore 3 Library software program.
The dll file as well as the included Staccato Systems SynthCore 3 Library program is produced by Staccato Systems.
SoundMAX.dll is an important component for the program and in the case it is corrupt or not found you can get Windows problem warnings similar to; "SoundMAX.dll is deleted" or "Staccato Systems SynthCore 3 Library failed to start because SoundMAX.dll is not found".
To fix the error, you need to replace the corrupted or missing SoundMAX.dll file with a working one.
The current version of dll file available on our site is 3.0.0.0 with a size of 1008 kb.
You may download the file for legally licensed software only.
You can download SoundMAX.dll for free by clicking the link below.
After you download the file, unzip it to Windows system directory ("Windows/System32" for
Windows XP, Vista, Windows 7). You can use Winzip or Winrar to extract files.
Press "Start" and select "Run".
Type CMD and press Enter.
Type regsvr32 *dllfilename* and press enter again.
Download SoundMAX.dll v3.0.0.0
Please note : No guarantees or warranties are given or implied.
Please download and install the file at your own risk.
Always take a backup of the original file in case something goes wrong
hope this helps
Sep 15, 2012 | Computers & Internet
Says windows root>\system32\hal.dll. is missing or corrupt, can't use laptop Please advise, regards Jason
some system on your windows has corrupted, it caused by a virus or bad disk
you need to restore your system to fix this issue
if your laptop build in windows xp and you have a restore disk just follow these steps
1. turn on your notebook
2.quickly press ctr and f11 simultaneously
3. click restore when "Dell PC restore" message appears
4.click confirm (it means you will lost all data in drive which contains your old operation system)
5.wait and click finish when the process of restore finish
if your laptop build in windows vista you can follow these steps
1. turn on your laptop
2. quickly press f8
3. when "Advance Boot Menu" message appears just click repair
4. select language and click next
5. log in and click ok
6. click dell factory restore and click next
7. click yes on the box "format hard drive and restore the system"
8. when the process finish click finish
if you don't have a restore disk build in your laptop you need a windows cd installer to reinstall your os
Jun 06, 2011 | Dell Inspiron 6000 Notebook
Acer Aspire One Netbook D260A.Windows XP not booting. Message Reads Windows could not start because the following file is missing or corrupt. Windows Root System 32 Hal dll No recovery disc or USB...
Sometimes you can get the needed .dll file online, and manually place it on that drive, of course in the correct directory.To do this, you need a functioning computer and you hook up the hard drive with the problem VIA USB. You can get USB Hard drive adapters from most retailers.
You may want to extract all data before you do anything, just in case. Have you been doing backups????
Usually, you reinstall the OS to resolve this issue, but without disks, not so easy to do.
Feb 03, 2011 | Computers & Internet
My laptop wont voot to windows
Sounds like you have a corrupt ntldr.dll file. You will need to insert you windows disk and repair the dll file, here are links with detailed instructions,
This is for windows xp
http://pcsupport.about.com/od/operatingsystems/ss/instxprepair1.htm
This is for windows vista
http://pcsupport.about.com/od/toolsofthetrade/ss/windows-vista-startup-repair.htm
Jul 06, 2010 | Dell Inspiron 6400 Notebook
C:\Windows\System32\DRVSTORE what is this?
Hiii
This actly stores the drivers on ur windows vista. Assuming it may hav bn corrupted, If u hav a Vista OS CD, DO follow the steps below, it wud chk for any corrupt files of the OS and wud repair it wid out losing or harming ur data.
Make Sure U login wid a ADMIN rights on vista. and RUN the following command
sfc /scannow
or u can verify the files before repairing it. Chk the image below. a522ba0.png
This wud solve ur problem.
Regards
Sep 06, 2009 | Microsoft Windows XP Home Edition
Hal.dll file of version 6.0.6001.18000 for windows vista version
probably you need a bootable cd to resolve this issue or else try to create a bootable cd through other computer using NERO software tool.
Jun 17, 2009 | Microsoft Windows Vista Ultimate Edition
Windows Media Center proplem ( unknown Audio Error 80040155 )
Go to start : All Programs: Accessories: right click on Command Prompt, click run as administrator. click continue: you should see C:\Windows\system32> type there regsrv32 wmp.dll It should look like this C:\Windows\system32>regsrv32 wmp.dll
(make sure to put the space in between 32 and wmp)
An info box will appear. Click Ok then restart.
That should fix it!
Mar 23, 2009 | Microsoft Windows Vista Home Premium with...
XP upgrade to Vista install error code 0x800705AA
This error is something to do with the "Product Key" I think I have Googled this error and this is what shows up the most? I googled ... vista install error code 0x800705AA .... so perhaps ya can follow up in this vien... Good Luck
Feb 08, 2008 | Microsoft Windows Vista Ultimate Edition
E-Machines eMachines Desktop PC Logo
62 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
