Question about Electrical Supplies
I want to put a kill switch on a Honda EM5000x
  • 2,841 Answers
I do not understand why you would want another kill switch installed. It already has a kill switch for the engine and a circuit breaker that kills the output power. I want to put a kill switch on a Honda EM5000x - d87e9a3.png
Posted on Apr 25, 2010
My 1981 honda elsanor 2 stroke dirt bike has a kill switxh instaled already but tje wires have been cut
If the kill switch has two wires: All the kill switch does is join both wires together. Find the two wires and ensure they are kept separated. If you want to kill the motor, join them together.
If it only has one wire: In this case, it usually bridges the coil to earth via the handlebar without blowing the fuse. An auto electrician may explain it better. Personally, I'd simply use the key to turn off or if no key, put a simple switch into the coil low tension lead. Also good anti-theft device as nobody knows it's there...
Jul 19, 2015 | Honda Motorcycles
My 1982 honda cr80 has no smark but has compression and its not the spark plug
check thd kill switch ! remove plug cap off the ht and see if you can feel a voltage as you kick over the engine ! it wont kill you but easy way to know if coil is working ! plug caps resister break down !
Mar 20, 2014 | 2005 Honda CRF 250 R
Honda ev6010
If you have an ohm letter or continuity tester, put the probes across switch and depress kill while reading meter for a change in resistance. Possible the switch is just bad. If the meter doesn't indicate a change in resistance, switch is definitely bad.
Jan 14, 2014 | Electrical Supplies
Motorcycle Question
Check that the kick stand switch is not faulty. this will kill the engine when it says the kick stand is down.
May 22, 2012 | Honda VF 750 C Magna Motorcycles
1992 Honda CB 250 Nighthawk how to replace the kill switch
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Replacing Motorcycle Kill Switch Starter Button and right control group...
KILL SWITCH BUTTON FIX
Honda CB250 Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB250 Nighthawk Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 04, 2012 | 1992 Honda CB 250 Nighthawk
I just bought a 2004 honda shadow custom. It idles perfectly but when I put it in gear it dies as iff the clutch is not engaged. I have check the cable and it is tight what else can I do?
Did you check the kickstand kill switch? I had the same problem on my yamaha, Ran fine, could throttle it up no problem, but when i put it in gear it died. Found that the kill switch was bad. Hope it is that simple.
Nov 21, 2010 | 2004 Honda VT 750 Shadow Aero
My 250 honda rebel runs fine in neutral but shuts off when i put it in gear. When i don't have the cluch engaged it lurches foward slightly then shuts off.
Check the side stand kill switch. Broken, loose or out of adjustment it will kill the bike when put in gear. The idea is to prevent starting out with the side stand down. Check the wires and connections also.
Jul 01, 2009 | 2000 Honda CA 125 Rebel
I have an 03 Honda 750 Shadow. I start the bike in nuetral and then put it in gear and it dies. It dies instantly.
Your kickstand switch is either broken or out of position. The bike kills the engine as a safety feature if it thinks the sidestand is down and the bike is put in gear while the engine is running.
Apr 12, 2009 | 2003 Honda VT 750 CD Shadow A.C.E. Deluxe
Honda Shadow 600 c won't start in gear after battery change
The kickstand switch is either bad or bent out of position. See if you can activate the switch manually. Does the bike run now? If so, the switch is bent out of position. If it still won't run, jumper the wires together until you can replace the switch.
Apr 11, 2009 | 2002 Honda VT 1100 C3 Shadow Aero
Electrical Supplies Logo
180 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
