Question about Liebert (PS1440RT2230) UPS System
Battery Recharge for Liebert PowerSure PSA
Unit was beeping for 2-3 days. Found unit was not plugged in correctly to mains so assume PC was running off unit batteries. Plugged unit in correctly. Beeps stopped. 1 green power light and all running fine. But when power disconnected from unit there is no charge in the battery so no emergency power for the PC. Does this mean batteries need replacing? Should they not charge up while in use? How long does it take to charge the batteries?
Many thanks.
  • 608 Answers
Yes, is the short aswer to your question. The battery should charge as you use the ups. If they don't then its likely the battery/s have failed. Lead acid batteries do not like being left discharged for any length of time. In a motor vehicle the battery gets a bit of shaking around, but in an ups they don't. If not used and left discharged, the plates quickly sulfate up reducing the efficiency to nearly zero. Test and replace any battery that cannot support a test load, such as a bright12v light or a 12v soldering iron connected to it. The length of time required to charge the battery/s depends on their capacity (in ampere/hours) and the charging rate. A 14.4 amp/hr battery charged at say 1 ampere will take 14-1/2hrs to charge.(just as a sample)
Posted on Apr 25, 2010
Testimonial: "Thanks. Looks like new batteries then. Pity, didnt think they were left discharged for long. Was hoping there was something I missed for charging. TY"
  • woozie38 Apr 25, 2010
    If there are a number of batteries in your bank, then it only takes one bad one the stop it from working. Load test each one and replace those that fail the test. Premium lead acid batteries have a finite life of 3-4 years in ups applications. Cheaper batteries need replacing every two years.
    Problem Solver:
  • 35 Answers
Yes battery need to be replaced
Posted on Jul 05, 2012
Where can I down load a manual for the PSA650MT-120 WHEN IT SWITCHES TO BATTERY BACKUP IT BEEPS AT TWO SECOND INTERVALS
Hi
Most of what I found on this subject was not helpful, but here:
http://www.emersonnetworkpower.com/documentation/en-us/brands/liebert/documents/discontinued%20product%20documents/sl-23270qs.pdf
I found a document with what looked a comprehensive table of lights and beeps and their corresponding meaning. It was clear to me that whilst under battery power a regular beeping was normal, although the timing looks a bit different to your experience.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 22, 2015 | Liebert PSA 650MT UPS AC 120 V 390 Watt...
The unit is not functioning. There is mains light indicator but the unit does not respond to operation
The mains indicator is just indicating that your UPS is plugged in to the power source.Try pushing the circuit breaker located at the back of the unit some are located in the front panel and some brands call it "reset"button.If this does not do the job,either have it serviced if under warranty by the manufacturer.Doing the work yourself kinda like disassembling a small engine(meaning-it is hard and also breaks the tab for the warranty).If you open it check for broken fuses(hi-amps fuses),and it is possible you'll change some relays and semiconductors.
Dec 15, 2010 | Liebert PowerSure ProActive PSA700 UPS...
My Liebert PSA itON 600 UPS keeps beeping when i turned it on
To figure out what's wrong with the UPS, first you have to do a few things.
When calculating the rating a UPS can handle, it's voltage x amperage. If it's Watts multiply the number by 1.67 to give the rating of the device.
Add up all the devices (use the power supply rating in the computer) as well as any other device, and add them up.
If this rating was exceeded, then you have overloaded the UPS. If it was too long that you did this, then you wore out the battery.
When a UPS beeps even when not connected, that means the battery is very weak.
If the battery is more than 3 years old, it will need to be changed. If the online tests of the unit were done and the battery doesn't need replacing, then other parts of the UPS need fixing.
Check the battery.
Jul 27, 2009 | Liebert PowerSure ProActive PSA700 UPS...
Liebert PS700MT-230
Emerson/Liebert do not release diagrams, if the u nit is less than 2yrs old it is still under warranty.
Jul 22, 2008 | Liebert PowerSure InterActive PS700MT...
Help with my liebert powersure interactive 1000?
The wiring fault light indicates that the polarity of your power outlet is wrong (positive and negative wires have been inverted) or that the ground is missing/faulty.
This have nothing to do with the configuration of the UPS. Unfortunately (for liability reasons), I have to tell you that the only person who can fix that is an electrician.
Just for testing, try plugging it into another power outlet elsewhere in your house to see if it is any different.
Feb 21, 2008 | Liebert PowerSure InterActive PS1000MT UPS...
Lieber PowerSure UPS
How does it react when you simulate a power lose? Unplugg it from the wall to test it to see if it turns to battery power. If the unit goes to the battery backup normally then check to see if it has a reset button on the unit. Please let me know what size unit it is.
Jan 14, 2008 | Liebert PowerSure PSI UPS System
Liebert Power Sure UPS
the battery is bad, you will need to replace the battery or the whole unit. you can find batteries on ebay. just source the model number. also depends on the size of the unit. you may need to just replace it...just a better value to do it that way.
good luck
K.
Liebert (PS1440RT2230) UPS System Logo
413 people viewed this question
Top Liebert Computers & Internet Experts
Computer Links
Marco De La Fuente...
Are you a Liebert Computer and Internet Expert? Answer questions, earn points and help others
